  • DCORSAIR
    • 1918
    • Selma, Ca.
    Hey guys, wanted to share an old trick I used to do on taking the slop out of bearing play, I did this on my helicopters all the time, worked great for the bearings that were installed in the frames, you helicopter guys will know what I'm talking about, so I tried it on the F-18 elevators and it works great. Just roll the bearing up in one round of masking tape, the tan sticky masking tape works best, trim off the excess with a sharp exacto knife, say goodbye to slop and no messy glue.
      • Nov 2013
      • 2758
      • Cody, WY
      Are there files for printing up the scale ordnance wing pylons for the Flightline F-18C? I bought some F-16 pylons and missiles, but they don’t look all that scale for an F-18C.
      thanks
      davegee
      • Dirty Dee
        • 768
        • Northern Illinois
        some medium detail sparrows I am working on. thingiverse upload in the near future:
          • 8225
          Nice trick, thanks for the tip!
          • Wolfgang Wagner
            Have a bandit day!!!
            • Apr 2019
            • 58
            • Bavaria, Germany
            Hey guys, got my BA yesterday. Unfortunately the mountings of the wings to the fuselage do not fit together. Did anybody have the same issue?
            Second, is there a possibility to eliminate the time delay with gear extension?
            thx
            Click image for larger version  Name:	64C382A3-6D94-4E51-B234-5148D8EFDF2D.jpeg Views:	0 Size:	132.7 KB ID:	206312
            • ken.swa@outlook.com
              • 26
              • Lewisville, TX
              So I have come across something here I have not come across before and not sure if this needs to be addressed with MRC or if there is a simple solution. So everything is centered, servos travels, sub trim and D/R’s as you can see in the pics on my radio, so when I do left and the right on my ailerons one way it shows 30 something mm’s and then the other direction it shows 20 something mm’s. If I adjust travels or anything else, then I am making the other side off by the amount I am adjusting on opposite side. The only other thing I can think of is bypassing the y connection and making each aileron on its own channel that allows me to adjust each individually. I don’t feel I should have to do this, but I don’t really understand what could be causing the differences in deflection that I am seeing. Had friend look at it and he is not sure why it is different either.
              Any more suggestions other than what I have listed above, or do I need to open a ticket with MRC?
              • Radar-Guy
                AirBorn Jetworkx
                • 364
                thx
                Got mine from MRC EU on Monday. No issue here. the wrong part appears to be on the fuselage side. My connection parts on the right wing look the same.
                Click image for larger version  Name:	IMG_3075.jpg Views:	0 Size:	46.2 KB ID:	206324
                • Wolfgang Wagner
                  • Apr 2019
                  • 58
                  • Bavaria, Germany
                  Thx, we'll see.
                    thx
                    Did they get the wing mount in upside down in the fuse?
                    • Wolfgang Wagner
                      • Apr 2019
                      • 58
                      • Bavaria, Germany
                      Ya, you're right. Due to the shape of the plate it should be fail safe. But they made it fitting!
                        • 5401
                        Mine is the same and it flies okay like that. It's mechanical differential.
                        I'm sure the usual's will be on soon with page long explanations about how it won't work even though they don't have or fly the F-18.
                        Any my suggestions other than what I have listed above, or do I need to open a ticket with MRC?
                          • 5401
                          Some things are inexcusable and this is one of them. Amazing!
                          • Radar-Guy
                            AirBorn Jetworkx
                            • 364
                            It’s not upside down. Did they glue the rear wing mounts on the wrong sides?
                              • 5401
                              They put in two right hand sides...:face_with_raised_ey
                              • RichJ53
                                • Nov 2018
                                • 342
                                • Southern Oregon
                                thx
                                It looks like the plastic wing mount is glued on 180* out of sync with the wing. Sorry for your issue, MRC will need to replace your plane. The time delay is built into the control board of the Blue Box and cannot be turned off.
                                Rich
ID:	206343Click image for larger version
                                  • 8804
                                  Where's that "face palm" emoji when you need one? Well, this one will do .................................... :poop:
                                    thx
                                    I got the other one...yours has two right side mounts, mine had two left hand mounts. Just open a ticket and MRC will take care of it
                                    • Wolfgang Wagner
                                      • Apr 2019
                                      • 58
                                      • Bavaria, Germany
                                      Funny, already done. But I had to do it twice, because MRC EU is in charge, not US. This plane has a little bit of bad luck, indeed.
                                      • gooniac33
                                        The Original Gooniac
                                        • Jun 2016
                                        • 1047
                                        How low is low?
                                        Doesn't matter how low when there is a reduction in thrust... putting anything in the airstream will reduce thrust. Better to do it a more aerodynamic way. Thanks for helping with that too! :-)
                                        • RanGee
                                          Ducted FUN!
                                          • Aug 2017
                                          • 64
                                          With nearly 250 afterburners shipped, no one ever complained about any reduction in thrust. I did heard few complains about the "other guy" who uses stupid reflectors in his afterburner which creates a lot of drag and thrust reduction.
