  • Russ
    EDF Enthusiast
    • 63
    • Houston, Texas
    RcJetDude,
    My 64mm Freewing Panther uses nylon hinges stock. $90 plane.
    Here is what they say on Motion RC site:
    Nylon hinges on all control surfaces (superior to a foam hinge)
    I've had the Panther for many years now.
      The 70mm Hawk did not.
      • Quickstop
        • 275
        What? no screwdriver....then I'm not getting one!:Silly: oops never mind, I already did!
        • Russ
          EDF Enthusiast
          • 63
          • Houston, Texas
          Good news is your Hawk has lasted, right?
          • fredmdbud
            • 450
            From the many screwdrivers included in previous kits (Su-35, 64mm F/A-18E, T-45), it was no biggie for me. That the screwdrivers were also magnetized (from the handle) sure came in handy. :)
              I put the 80mm Mirage 9 blade and 100A ESC in mine :Silly:
                Yes the hinges have held up. Even through a vertical fin separating in flight because I failed to install the screws that secured it after having to remove it for transport. :Loser: Even with that though I have found foam hinges are fairly easy to fix with a little Foam Tac and some Blenderm. If they get really bad then nylon hinges are the answer but so far I haven't had to resort to any.
                • Captain Moron
                  • Jun 2019
                  • 213
                  So what C of G did you fly yours on .The manual puts it at the leading edge of the wing but on this forum they are saying 60mm aft of the leading edge .I am confused on where to put my C of G .Need to sort this out before I fly mine HELP
                    • 5383
                    Cool, have you flown it yet?
                      Hi CaptainMoron, see James' post on the previous page for better clarification and photos:
                      Click image for larger version Name: Views: 0 Size: 144.5 KB ID: 194114 attachment Shipment on the water.... Pre-Order now! https://www.motionrc.com/products/fr...mm-edf-jet-pnp (https://www.motionrc.com/products/freewing-f-35-lightning-ii-v3-70mm-edf-jet-pnp) Motion RC and Freewing are excited to announce our all
                      I balance my finger where his are in his picture according to those markings, and that's where I've been flying the majority of our test flights.
                      • scootergenie
                        Jet lover
                        • 261
                        • Stuart FL.
                        Here's the foam hinge fix. Its called welder contact adhesive. Rich Baker did a video on YouTube as the rc informer, and shows how it's done. Just did it on my 70mm f16, and it's bullet proof. The video is a must see. Even on a new plane, if you coat the hinge line with a brush it will likely never come apart.
                        • scootergenie
                          Jet lover
                          • 261
                          • Stuart FL.
                          • Captain Moron
                            • Jun 2019
                            • 213
                            Thanks Alpha, that is different to the manual but looks about right so I will try your C of G .I am sure you are right
                              Yes, I have 4 flights on it...pretty fast ;)
                              • Russ
                                EDF Enthusiast
                                • 63
                                • Houston, Texas
                                Will FoamTac work the same way for hinge bolstering?
                                • Apriliamgt
                                  • Oct 2017
                                  • 73
                                  This currently where I have the 5000 set to. And using the points James has set out for cg?
                                  look about right?
                                    That is where I have my Admiral 4000 Pro. I would think the 5000 is a heavier battery.
                                      Yes. The stuff is great for it.
                                      • Quickstop
                                        • 275
                                        I've used this to great effect, made a hinge for my freewing f-16 elevator and has worked great for over a year now, very strong and very flexible. There are a bunch of different kinds. plumbing household, etc. but they are all exactly the same.
                                        • dahawk
                                          Augermeister
                                          • Jun 2013
                                          • 1006
                                          • Keller,Texas
                                          Scooter- +1 on Welders glue in the red tube. Light bead.
