Depends on the size and weight of the battery. With my Roaring Top 3300mAH and CHNL 3300mAH batteries, they line up to the first rounded square hollow on the battery plate towards the front - that gives me CG just a little forward of the plastic wing attachment block.
I meant in context of the recommended Admiral 6s 4000 PRO as shown in James' pictures. For other batteries of other weights, you're right, position may change to hit that sweet spot just forward of the plastic wing attachment block as you have it.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
OK - I don't believe AZFlyer mentioned what capacity battery he used, so could very well be the case he used a smaller battery, hence the forward position. Important thing is that he got the CG he wanted.Comment
Sorry to beat a dead horse. But I'm still confused on the CG. Is it 4mm or 60mm? That's a huge difference to get wrong. James, can you show me a picture of where you marked the bottom of the wing?Comment
I with you mtnbiker 63 ,the manual put the c of g at 4mm but everyone else is saying 60mm .Confusing or what .Surely if the 4 mm is not correct ,Freewing should come out and clarify what the correct c of g is !!!!!!!!!!!!!!Comment
Hi guys, please see James' photos in this post #133 two pages ago to clarify the CG at which he and everyone else at Joe Nall flew the F-35:
https://www.hobbysquawk.com/forum/rc...931#post197931
Measurements vary based on the point from which you're measuring... That's what's contributing to the confusion. The downsized reference drawing didn't help. But if you look at James' photos it clearly shows a physical reference point that is on everyone's aircraft that is visual (where the foam and plastic meet), and doesn't require a ruler or any guesswork. Look at the picture, match it, and you're good for maiden with slight nose heavy. Adjust per your preference from there on subsequent flights.
Step 1) Locate this position on your aircraft:
Step 2) Put your finger at that position under the aircraft, with the aircraft upright, as shown in James' picture. That's the CG where all of our F-35 flight videos were flown. It's a more than safe starting point.
Freewing's CG is about 4mm forward of that point, which is still a safe CG, it's just hard to decipher from the diagram, hence these real life pictures.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Thanks ,that clears the confusion up Quite straight forward it is on the plastic square on the wing .Thanks againComment
Just maiden mine, great flyer with the 5000. Elevator definitely needs high rates . Aileron needs no more than low rates.
Using around 45-50%expo.
Only a few clicks of trim needed 👌
this is using the CG point James and Alpha suggested .
I will try with the lipo slightly more rearward and see if that helps with slowing her down on finalComment
To simplify, how many millimeters forward of the plastic edge is your preferred CG located?
James and others are flying at the plastic edge. I fly ~4-6mm forward of the edge. It looks like you're flying about 25mm forward of the edge, if I'm reading your picture correctly. Which would be approaching tail-heavy but as you said, nice for high-alpha flying.
This bird has quite a wide CG range.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Wing tip and nose lights are not included.Comment
That’s because they are NOT giving you a range.They Are giving you a fixed point measured a distance from a fixed point on the aircraft. None of the FW jets show a range in the instructions.
As far as the F-35, FreeWing and Motion should put a note on their sites that the manuals CG is wrong and how to measure the correct CY. And add an addendum to the kit.
I would be happy to add to the product support page any updated CG information. That's what it's for...If I am given the proper updated CG I will gladly add it for folks.My YouTube RC videos:
I'm sure with some practice I can land with shorter distances without flaps. This jet is becoming one of my favorites, although I may decide to install a gyr...Comment
