  • Swissjet
    • 10
    • Aargau, Switzerland
    [QUOTE=GliderGuy;n221730]
    The bird is FAST and has tons of power. It is considerably faster than my Freewing F-4 Phamtom II. I ended up cruising around at 20% to 30% power most of the time. Apply full power, and you'll be yankin' and bankin' to keep it close enough.
    The 5100 mah battery ends up with 40% charge after a 4 minute flight...mostly crusing, but also with a few loops and/or fast passes. This leaves enough charge for an emergency go around. Also, LiPos will last a lot longer if you don't drain them too low. Leaving 30% to 40% of charge will extend the life of your LiPOs a lot. Without any acro or fast passes, a 4 min, 30 sec flight is a good target and your batteries will love you for this.
    The aerodynamically clean design allows the bird to glide without power a LONG, LONG, LONG way. I have no doubt that with half flaps in the summer, it'll thermal soar well.
    That the Problem and not Scale-Like for this Airliner
    • James
      Administrator
      • Aug 2017
      • 1543
      Originally posted by HondaJet
      Work in Progress.
      Flight Deck Upgrade - Pimp My MAX
      2 SilkAir Captains in Command !
      Click image for larger version Name:	silk air 1.jpg Views:	0 Size:	140.2 KB ID:	221765
      Awesome Honajet! Welcome to HobbySquawk. Did you get the Silkair decals from Callie?
      • HondaJet
        Yes James from Callie.
        Your typo ...."HondaJet".... same as RC groups ..... regards Louis
        • urrl
          • Oct 2013
          • 508
          More mods: cabin lighting and inside fuse wing/nacelle passenger view cam
          • Hoomi
            Cactus Dodger
            • Apr 2018
            • 863
            • Baja Arizona
            P.S. The plywood shelf is where I place other birds.
            I had the same idea, though I had to keep the plywood narrower, or else I couldn't manipulate it into place. I reinforced the plywood with some metal brackets, one of which rests in front of a removable crossbar and keeps the wood from sliding back. I've since added some "eggcarton" foam for the planes to sit on. It not only cushions them a bit from the bumps in the road, but also acts as wheel chocks to keep the planes from rolling.
            • S.W.Warbirds
              • Jan 2015
              • 121
              • West TX.
              I have a dumb question .... Whats the trick to getting wing decals off the sheet ?
              • killickb
                • 118
                urrl, that passenger view cam video is one of the best I have ever seen in these columns -- very nicely done, I almost was checking my seat belt and locating my overhead bags !
                  S.W.Warbirds See our decal tutorial at www.youtube.com/motionrc --Near the end we show how to get the decals off the base sheet, if they're not fully adhering to the top clear layer.
                  Originally posted by Alpha
                  Here's the video James published onto our YouTube channel, as a tutorial for anyone applying the window decals:
                  I enjoy reading everyone's maiden comments and seeing all these customizations. I need to see a tow truck, please and thank you!
                  • S.W.Warbirds
                    • Jan 2015
                    • 121
                    • West TX.
                    Thanks I did watch video and got the windows on but I'm having trouble with the black lines & arrows that go on top of wing looks like water decals to me and the pre cut edges dont seem to be fully cut ????? Do I have to cut them out ?
                    • S.W.Warbirds
                      • Jan 2015
                      • 121
                      • West TX.
                      OK pulled my head out and got it now :rolling_eyes:
                      • the snake
                        I can't help my self dear! I love RC!
                        • Nov 2013
                        • 126
                        Mango Airlines livery freewing Al37 is almost done!
                        Almost done, few more details. The left side is waiting for the last decal. I still wish to add silver around the windows too. Sadly the weather said rain, our field is closed!
                          • 4877
                          Originally posted by the snake
                          Mango Airlines livery freewing Al37 is almost done! Almost done, few more details.
                          TS, I'm hopin' the Flight Crew are wearing Hawaiian Shirts. Outstanding livery, Sir. Best, LB
                            Love it!
                            • Hoomi
                              Cactus Dodger
                              • Apr 2018
                              • 863
                              • Baja Arizona
                              That'll be a great scheme for visibility in the sky! Looks fantastic!
                              • the snake
                                • Nov 2013
                                • 126
                                thanks guys, thanks Motion for this, thanks Alpha for making this happen! still waiting for my left side tail art, poor Callie lost money on me because my livery has a different tail art on each side!
                                • Dirty Dee
                                  • 768
                                  • Northern Illinois
                                  Looks great! Have you offered Callie to send an additional payment make up for the difference since she didn't realize the extra decals needed?
                                  • 4923crew
                                    SoltProductions
                                    • 160
                                    • Syracuse, Utah
                                    Well just finished my KC-37 Prototype Tanker. I’ve always wanted a tanker and thanks to Freewing and Motion RC, I’ve got my opportunity now. Special thanks to Andrew O'Laughlin and Callie Soden for all the special details that made the tanker option even a possibility.
                                    • Marco Polo
                                      Go NAVY
                                      • Aug 2012
                                      • 620
                                      • Illinois
                                      Looking sharp, nice livery choice. Please consider using the photo album feature for future posts, it will allow us to view your photos easier. See below for Photo Album button location.
                                      • urrl
                                        • Oct 2013
                                        • 508
                                        Great work! Looking forward to a flight video! Did you use Rustoleum 2X spray paint?
                                          • 4877
                                          4C, Outstanding! Great looking bird. Very happy to see this one done in the tanker livery. Which Squadron are you thinking? Best, LB
