[QUOTE=GliderGuy;n221730]
The bird is FAST and has tons of power. It is considerably faster than my Freewing F-4 Phamtom II. I ended up cruising around at 20% to 30% power most of the time. Apply full power, and you'll be yankin' and bankin' to keep it close enough.
The 5100 mah battery ends up with 40% charge after a 4 minute flight...mostly crusing, but also with a few loops and/or fast passes. This leaves enough charge for an emergency go around. Also, LiPos will last a lot longer if you don't drain them too low. Leaving 30% to 40% of charge will extend the life of your LiPOs a lot. Without any acro or fast passes, a 4 min, 30 sec flight is a good target and your batteries will love you for this.
The aerodynamically clean design allows the bird to glide without power a LONG, LONG, LONG way. I have no doubt that with half flaps in the summer, it'll thermal soar well.
That the Problem and not Scale-Like for this Airliner
