HSD 105mm F-16 EDF Jet
    • 2709
    Originally posted by Aros
    Okay I was able to get a more accurate CG measurement. Here is the location of my Admiral 6000s (photo below) for a 175mm CG which a lot of flyers have found success with. It's quite a bit aft of where I had them for the maiden so no wonder I was having takeoff roll issues and maxing out my up trim. I was probably flying around 160mm if that! Yikes. I am feeling a lot more confident with this placement for the second flight. I also found out about a church in Graham, WA (about an hour drive from me) that welcomes RC flyers and it is a nice relatively long runway with no immediate obstructions. So I may go check that out this weekend.
    Can't do better than to fly on the church property, doesn't hurt to have the big guy on your side and an angel on your shoulder!
      • 8228
      Exactly! I always call on my "Flight Angels" for all my flights and being on Church grounds can only help!
      • PaulZ
        Crashing less
        • 279
        • DFW Area
        That looks right. I have my batteries as far back as they will go.
          • 8228
          Yeah I had to carve out some of that side foam where the port-side 2S battery resides in order to get both to fit that far back. Feeling much better about this second flight.
          • PaulZ
            Crashing less
            • 279
            • DFW Area
            I only fly 5000s in this bird since they fit better, still all the way back. 3:30min flight times are fine for me.
              • 8228
              Nice. When I get some extra funds I plan on grabbing some more RT 5500 70Cs which I have had great success with in this jet.
                • 8228
                Alright PaulZ Hugh Wiedman and other thread members, I am prepared to offer up the second sortie for better or for worse. I think the former, hopefully. Someone I know through selling him a plane and is relatively local to me has found a decent spot to fly this big girl. A church parking lot/roadway that is 45 minutes from my house. More than worth the drive as it looks to be the place I have always coveted to fly my bigger models which is free of light poles, buildings, trees, curbs, houses, etc... He sent me a photo and it looks like a long paved road with flat surroundings. (Happy Dance).
                I have NEVER flown this jet (I've owned all three...V1/V2 and now V3) without major obstructions and high approaches so I am ECSTATIC. I installed my Demon Cortex gyro so that's ready to go. I moved my batteries back appropriately to get within what I believe is a more "pilot-friendly" CG within the 175-ish range. So other than Dumb Thumbs or some Series of Unfortunate Events, I am ready for a nice flight. Video to follow.
                • PaulZ
                  Crashing less
                  • 279
                  • DFW Area
                  Alright PaulZ Hugh Wiedman and other thread members, I am prepared to offer up the second sortie for better or for worse. Video to follow.
                  Good luck! Once you get the CG right you will love this F-16! I am maidening my A-10 tomorrow morning.
                    • 8228
                    Thanks PaulZ I am looking forward to it! Good luck with your A-10, you are going to LOVE her!
                    • Lcacing
                      • Dec 2017
                      • 155
                      I also have the A10 (90 mm upgraded), Start with CG 10mm further back from book CG.
                      • Lcacing
                        • Dec 2017
                        • 155
                        Aros Good luck on the re-maiden flight!!!
                          • 8228
                          Holy Hell it's always something.
                          After driving an hour to a place we were scouting to fly this bird (and found it wasn't viable) we eventually made our way to White River Amphitheater which is the usual spot. It was a great day for a Sunday Drive so all good. We also stopped off at a local club's new field (actual full scale grass 2500ft runway) and chatted with some members. Looks like it will be a viable place to fly! They plan on mowing the grass even shorter than it already is and right now as is I could probably take off on it. The winds were whippin' pretty good but I decided to fly anyways. Rotated a good 50-100 feet earlier than the maiden so I could immediately tell the CG was better. However, it still was really wonky on the roll...She seems to want to really roll to the left. At times nearly 90 degrees and I have to fight to get her level! Upon thinking about it, I think my aileron throws are simply too low. I think I lowered them so much because I recall the recommended were WAY too sensitive, but I must have over-compensated and now I don't have enough.
                          So I had to switch to high rates. Still bouncing around pretty good (you can see it in the video) so I couldn't fine tune the trim like I was hoping due to the winds. But once I switched on the Cortex gyro WOW what a difference! Immediately smoothed her out. Unfortunately as I went to change the rate switch I inadvertently hit the throttle kill switch! At first I didn't realize it and I just said "Holy $$$$ I have no power!" Right as I am heading for the tree line. I was about to cut over for an emergency landing when I realized what I had done...Hit the switch, gained power back and barely missed the trees by the skin of my teeth!! That was a disaster I don't want to think about how close it was to happening.
                          So I came in for an emergency landing aka "I May Have Just Soiled My Shorts So I Need To Check" and managed to get her down without too much fan fare thanks to a strong head wind.
                          Takeaways:
                          1) CG felt much better.
                          2) Still wonky on the roll. Need to increase my throws for more authority when it's needed. Lateral Stability check only showed a minor lean to the left from the RunCam2 placement.
                          3) Power was much improved over the old system. Will really be able to tell in calmer conditions.
                          4) The Cortex gyro ROCKS! I have my gain set to 40 and it felt about perfect. Might even increase it to 45. What a difference.
                          5) Thank God for this robust gear. While these first two landings haven't been my best or worst, they still show how durable they really are.
                          6) I need to fly this jet away from buildings, light poles, tall trees, highways, neighborhoods PERIOD.
                          7) My BP meds have been put to the test lately, lol!
                            • 2709
                            Aros Still in one piece with no repairs needed is a win in my book! Really noticed when you kicked in the gyro! Hardly noticed when you cut the throttle, but it did look like you were heading in for a kill shot on a bogie hiding in the trees!
                            • PaulZ
                              Crashing less
                              • 279
                              • DFW Area
                              Aros sounds like a great RC day! Congrats! She will reward you. Not sure why you have an induced roll to one side? Double check the aileron trims. It's weird that plane does not roll. The A-10 however rolls to the right and I had to trim that out.
                              • Lcacing
                                • Dec 2017
                                • 155
                                Aros sounds like the CG is almost there. I would check the elevators to make sure they are even, that would induce the un commanded roll. Also mine came with a slight twist on Vertical stab so had to add couple of clicks on rudder, double check that. You did end up turning the throttle/elevator mix correct?
                                  • 8228
                                  Hugh Wiedman I should have offered up a version of the video sans music so you could hear when the power cut out. It went from sounding like a typical WOOSH jet to silence! Like a glider! Only the sound of airflow. Spooky! And don't you worry my friend, next time I am killing that bogie!! LOL!!
                                  PaulZ I will definitely be hyper-examining the aileron settings for sure. Throw may be part of the issue but I suspect there's more going on. I have always had a cam on the port wing tip and had many flights without a roll tendency to the left like that.
                                  Lcacing I will most definitely recheck the elevators for symmetry...They "look" even to me but granted that's at a few feet away glance. Rudder will also be double-checked. Yes, Throttle/Elev mixing was turned off from the start. This bird is going to get a thorough re-examination of ALL control surfaces. I see enough videos and hear enough from others with this model where it flies super stable. I have to think there's something missing...I may not be the best pilot but I am better than this jet makes me look sometimes I swear it! LOL!
                                  Also, if you guys don't mind can you give me a quick callout of your aileron settings? Low/Hi/Expo? I apologize if you mentioned them somewhere earlier in the thread. I want to do a quick sample size of where others are at compared to me. MUCH appreciated!
                                  I am at 15% expo and I will measure the throws and post them here to compare to your guys' settings...
                                    • 8228
                                    Okay some interesting things here. First off Lcacing for the first time ever with this new model I looked straight down "Bird's Eye View" at the top of my Vstab/Rudder and wouldn't you know it? It indeed had a curve to the left! Not massive but certainly noticeable when looking for it. So I straightened it out using my hands (the foam is pretty malleable) and now it looks much straighter. That alone makes me wonder how that was contributing to the flight characteristics I have noticed thus far?
                                    Secondly, I measured the throws as accurate as I could with my digital caliper...Here's the numbers. I measured from the trailing edge outboard side closest to the wing tip. Note: The trim setting is to the right to compensate for the left roll. Not a lot but just as an aside...
                                    Not sure what to make of them:
                                    AILERONS
                                    LOW RATES:
                                    LEFT UP THROW MEASUREMENT: 4.3mm
                                    LEFT DOWN THROW MEASUREMENT: 3.7mm
                                    RIGHT UP THROW MEASUREMENT: 7.2mm
                                    RIGHT DOWN THROW MEASUREMENT: 7.1mm
                                    HIGH RATES:
                                    LEFT UP THROW MEASUREMENT: 8.5mm
                                    LEFT DOWN THROW MEASUREMENT: 8.2mm
                                    RIGHT UP THROW MEASUREMENT: 9.9mm
                                    RIGHT DOWN THROW MEASUREMENT: 8.2mm
                                    So looking at these numbers what immediately stands out to me is the limited throw especially on low rates coming from the left aileron. 4.3/3.7mm versus 7.2/7.1mm right aileron. High rates also shows a discrepancy in throw between the left up aileron (8.5mm) and right up aileron (9.9mm). Now bless it all I am just a pixel pusher and not an aeronautical engineer, lol. If anyone can look at these numbers and help me translate based on what I have described with the flight dynamics so far I promise you 10,000 Good Karma Points. Also, I am highly interested to hear what your throws are in mm's compared to mine. I need to crack this nut once and for all.
                                    • Lcacing
                                      • Dec 2017
                                      • 155
                                      Aros go into the MFC and verify both aileron servos have the same end points/travel. You probably need to adjust the left ( more travel) or right (less). Another option would be to split the ailerons so each have their own channel, thus adjusting capabilities can be done independently in the TX.
                                      When it comes to aileron travel, can’t help you since from day one never used ailerons for roll control.
                                      look at the elevators and double check they are even to each other rather than to the fuse. That will also give you adverse roll, specially since all the attachment points are glued in and easily can be misaligned from the factory.
                                        • 8228
                                        Good stuff Lcacing thank you I will check those points...
                                          • 8228
                                          Lcacing I checked the MFC and the ailerons are showing 100% travel all around. I checked my radio and the travel menu shows 100% but when I move the stick to the left the monitor reads like -26 and when I move to the right it shows like 60 or something. So I am not sure what's going on with such a travel discrepancy. It's almost like it's set up for aileron differential. The only thing I can think of is to extend the travel end point on the servo that needs it to make up the difference of the others. If anyone has alternative thoughts on the matter I am all ears. Mixing/programming isn't my strong suit in the hobby, lol.
                                          As for the elevators they have so much play in them that I get different measurements every time I toggle the stick up or down. However, the difference seems to be very minute to where I would be shocked if that was the roll issue.
