  • Sky Wolf
    Flying Ant
    • Sep 2013
    • 731
    • Irving, Texas
    As an FYI, there was discussion about whether or not the new metal servo arms would fit the splines on the existing servos. And the answer is “Yes”. I removed the metal servo arm on the new 30mg servo and put the arm from the 17gm servo on it, and it fits perfectly. So for those who are thinking of ordering the kit “minus” the servos, when they become available— know that the new metal arms will fit your existing servo.
    • Sky Wolf
      Flying Ant
      • Sep 2013
      • 731
      • Irving, Texas
      Those who got the 2nd run of the MiG-29 may have already installed the new 30gm servo kit. But thought I’d post a vid of how I got mine done for those who were wondering. Had just a small challenge this time around. But it was a simple fix.
      When I changed out the first MiG-29 to the replaced 23gm servo there were no issues at all.
        • 2716
        Slowly making progress on the Mig 29 and 2nd Hornet build and repaint, just too many "Life Distractions". Probably shouldn't have undertaken 2 at once, but when I'm ready to paint both (Hornet is now ready) at least I'll have the garage set for painting and will only have to put it out of commission once.
        Got the TV units installed along with lining the exhaust nozzles with the aluminum foil for the AB's. I didn't particularly like the way James ran his wires outside on his installation video, so I followed some advice from RudyD54 and put the wires inside the exhaust nozzles, but cut a groove to imbed the wires and then pulled those and the AB wire through the channel under the ESC platform where the rudder wires go. Since I was installing the aluminum foil tape anyway, they covered up nicely without interfering with any fan exhaust. More later, but looks like much later!
ID:	313915Click image for larger version
ID:	313916Click image for larger version
        • Turbinefancy
          Head-tracking FPV Advocate!
          • 294
          • Irvine, California, USA
          Flew some basic aerobatics from the cockpit the other day and some formation as well. Miggy is a pretty stable platform for filming...
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1688
            • Catalonia
            Well done!
            Reached 100 flights today, yay!
            • Airguardian
              Post Stall Svengali
              • Aug 2020
              • 1688
              • Catalonia
              Some more unvectored MiG flying :)
              • GliderGuy
                • 1417
                Glad you got her back in the air! Worth noting: high alpha lock took a bit of forcing to get her outa that.
                Definite proof of needing to be a few mistakes high to get the MiG out of high alpha lock.
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1688
                  • Catalonia
                  These flights were pre-crash though. But yeah, she's already at 103 flights (Crash was at 94) (:
                  With CG at 15mm behind wing marks it usually comes out on its own when cutting throttle but here I was running more aft CG and yep, that wasn't enough (I suspect the severe wing rocking may have not helped either), so I added short throttle bursts to break out of the cycle. Of course, can't keep throttle open or the jet will keep stuck there due to the thrustline condition.
                  • lusek_pl
                    • Sep 2020
                    • 49
                    • Polska
                    What is known when the model will be in stock in Europe ?? It takes a long time, the price increased and in Europe the model was not for sale: /
                    • Airguardian
                      Post Stall Svengali
                      • Aug 2020
                      • 1688
                      • Catalonia
                      They mentioned that it would be at least 2 months, because by the time the US container arrived, the EU one hadn't shipped yet.
                      July I guess.
                      • Tigerman
                        • 62
                        Think we have been forgotten by MRC here in Europe with regards the Mig 29. What with the price increase the £12 handling charge by FedEx. It is becoming a pain to order from Europe now. I have just order the Eflite 80mm F16. Mind you I have not received it yet, it is due out here in the UK on the 14 June . Quite expecting that date to come and go with no F16 arriving. That is the norm now
                        • locharrow
                          • Feb 2020
                          • 283
                          find it very interesting that after adding reflex to my flaps, I had to re-trim stabilator (less up) for level flight. But dropping flaps does not induce pitch change for both half & full flaps. I don’t overspeed my flaps though, only dropping them after speed stabilizes at 50% throttle or lower. I suppose the flap induced downwash increase the negative angle of attack on stabilator to offset the down pitching moment from the flaps. Or is there another explanation?
                          Yes there is......at certain velocities harmonic oscillation of the trailing edge upward vortices from the flaps meet the split airstream of the leading edge of the stabilizer causes a high speed airflow over the top surface ... this decreases pressure and acts like a suction on the top surface of the tail plane, resulting in some instances a nose down attitude change. However, this is largely dependant on the centre of lift. In this instance, flap deployment, the C o L acts as the fulcrum , or more correctly, the moment arm, of the resultant change of pitch. In some cases C of L can be lost altogether and the plane just drops out of the sky. :speak_no_evil:
                            • 5426
                            Normal flaps don’t change pitch but if you program full span flaps it does…
                            • locharrow
                              • Feb 2020
                              • 283
                              Specific to the Mig 29 ?? In my F4 it sure does!!
                              By the way, Friday night is Cab Sauv night!! :wine_glass:
                                • 5426
                                Yes the MiG…
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1688
                                  • Catalonia
                                  Hi Loch!
                                  That's correct :)
                                  Hmmm... not quite.
                                  In any case, extending the flaps will cause the stabs to produce more negative (pitch-up) lift.
                                  If the nose pitches down when extending flaps, it is not because the stabs are being 'sucked up' but because the pitching moment contribution of the flaps is greater than that of the stabs for that particular condition.
                                  Depends on your settings and equilibrium speed.
                                  On my MiG-29 I definitely have different trims for normal, flaps half and flaps-full settings.
                                  • fredmdbud
                                    • 451
                                    Stall tests w/o thrust-vectoring - no "alpha lock", throttle-off recovery:
                                    "I finally reached a level of confidence with the MiG to begin some of the dreaded stall testing. It has been widely reported that deep stalls result in some difficult recovery issues. It has been reported the model is slow to nose over to once in the stall, depending on the placement of the Center of Gravity (C/G).
                                    Fortunately in my case, I believe the C/G location on my model allows for straight forward stall recovery. I entered the stall then added full power while holding full up elevator in an attempt to get the model into a near vertical attitude as the airspeed diminished. On two occasions I managed to flip the model over before initiating normal recovery."
                                    • locharrow
                                      • Feb 2020
                                      • 283
                                      "Hmmm... not quite.
                                      If the nose pitches down when extending flaps, it is not because the stabs are being 'sucked up' but because the pitching moment contribution of the flaps is greater than that of the stabs for that particular condition."
                                      Don't spoil it I thought it sounded credible for a wino !:stuck_out_tongue_wi :wine_glass:
                                      Just visiting at the moment, I'm waiting on my '29 coming from China!! Tried not to buy one but couldn't resist !! :woozy_face:
                                      • SanExup
                                        • 912
                                        • Western Wy.
                                        I thought I heard a statement once along those lines, 'the dark ideas of midnight have to stand up to the scrutiny of the morning sun'
                                          • 2716
                                          Finishing up on the cockpit. Next comes masking and heading to the "paint barn".
ID:	314446Click image for larger version
ID:	314447Click image for larger version
