As I tested various options on this gripen, there is no need for a gyro. However to verify a gyros flying envelope i tried a gyro in the Gripen and of last weekend this was the only canard/Delta jet I've owned and temporarily flying with a Installed hobbyeagle A3 gyro. I few it 10 times and What i found is that there’s zero need to reverse any servos and defiantly zero need for two gyros to make this jet a gyro Assisted jet. I also have the ability yo remove aileron controls to the canards at the flick of a switch. I will make a video of my transmitter settings and of how I set up the jet after work today to help with some of the confusion ive seen here.
This!
A little bit of me dies whenever I read someone talking about whether or not a model NEEDS a gyro.
Your car doesn't NEED power steering or cruise control either, but it is damn nice to have anyway. It is virtually never about need.
Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
Sometimes I really feel like I *need* a gyro but that's only when I decide to fly on a questionable day and the wind is blowing 12 mph gusting to 20 mph. We don't get too many low wind days of under in Oklahoma so almost every plane I own has a gyro. On those calm days the Gripen is super smooth without gyro on, at least it feels that way to me.Comment
Follow up with more details.
This is how I have been flying it.
AR8360T receiver set up for elevons with AS3X on the elevons. Pitch input also sent to channels 6 and 7 which I have previously used for unstabilized canards with 7 reversed to get both canards moving in same direction.
Adding gyro to the canards for pitch only:
I used the A3Pro because it allows the gains of the three axes to be set independently. (Can't do this with the A3L)
Gyro settings:
Normal mode, elevon/flying wing, orientation flat upright. Set aileron gain to zero, elevator to something non zero, rudder gain irrelevant.
Pitch output from receiver (Ch6) to gyro elevator input. Nothing to rudder. *Temporary* 1.5mS (neutral) input to aileron input (not sure if needed but didn't hurt) **
Gyro "Aileron" and "elevator" outputs to left and right canards. "Rudder" output not connected.
A MIRACLE HAPPENED! Everything worked in the correct direction first time. The canards still respond correctly to elevator stick input, move in the correct direction in response to a pitch change, and do not respond at all to roll.
** I don't know whether an input to the "aileron" on the gyro is needed. It flashes a red light if nothing is connected there but everything still seems to work OK. However, leaving a input in an undefined state is not good practice*** and I now have a spare channel (Ch7) so I'm setting that to 1.5mS fixed and leaving it connected.
*** A3Pro manual specifically states that the rudder input need not be connected for an elevon/flying wing configuration.Comment
I've gotten to sort of the same conclusion, I am running the AR8360T and have my elevon, rudder set with gyro. Ran a Y to my canards into my A3pro, then to my open aux 7 on AR8360T and ran Mod wire to Aux 8 port. Im getting a slow flashing red light. But my gyro direction works perfect on my canards and normal stick input for canard movement to match my elevons. However I have not figured out how to get my mod channel to work so I can switch gyro on and off. But if I use the pots on the gyro itself I can turn off and slowly turn up gyro gain and seems to work fine. Although have not flow yet (Looks great on work bench). I am still playing with it to see if I dare fly it.
Gyro settings:
I may resort back to just having one gyro AR8360T and leaving my canards un stabilized.Comment
No one said gyros were 'needed' as such, now, did any?
That said, if you want to make the best out of it, it is not a bad idea. The reasons have been covered quite in detail already.
Gyros helping with wind gusts (for me) is a nice second derivative of having them installed but not the main reason I do install them to begin with so... ;)
VT just showed up at RCC:
This Thrust Vector Upgrade Set is intended for advanced pilots only because it significantly widens the potential agility of the stock Freewing 80mm JAS 39 Gripen. Roll rate, yaw control, and elevator authority are all increased. The aircraft will be able to depart conventional flight patt
Shouldn’t be long now before Motion gets them in.Comment
I decided to go ahead with the LE flap modification I've been considering and got a good start on one wing, cutting out the shape and installing hinges, the servo etc. Nothing is finalized (glued) and it's very much a WIP but looking pretty good so far, I think. The LE drops about 25 degrees right now, which doesn't look like much, but as it's such a large surface span-wise, and on the front of the wing, I'm thinking it may be enough travel, but of course don't know. At the moment I'm trying to figure out a good way to cover the gap on the underside of the hinge line when the flap isn't deployed. Comments and ideas are more than welcome.
Christmas vacation started today so I'll be able to get some quality time in the aerospace facility uninterrupted by work.
TomComment
I don't like the job they did on the nozzle. It looks pretty cheesy.VT just showed up at RCC:
In your experience, how should the gyro pitch gains be apportioned between the elevons and the canards?
Same picture that's been on Motions site for a long time. Like other TVs the outside of the nozzle is foam that can be easily peeled off and a better looking 3D printed part put there.
On yesterdays pod cast James said again the TVs are next year. I wish they would update the web site with more info and a better arrival date.
That looked more like an unplanned landing than a crash. :-) I've got two of those right wing tip stalls on video I guess I should upload them to YouTube also. Mine were both with gear down. On one I was able to take off again. The other one was in a crosswind and required gluing the left retract back in place and straightening the landing gear where it bent at the notorious 4 hole weak point...Comment
Got mine in the main - will not wait. Currently doing my turbine conversion, so great boon to get it all done at once rather than having to pull it apart again later for VT retrofit.VT just showed up at RCC:
Shouldn’t be long now before Motion gets them in.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversionComment
Having seen Harold's videos, I'm thinking I may forget the VT nozzle for this plane. The plane appears to be able to do stuff that one would have previously thought it could only do with VT. In its stock form, the Grip won't hover anyway, so it may be a pointless add-on. (The VT nozzles may serve a more valuable purpose with the big MiG, though.)Comment
