  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1676
    • Catalonia
    • WarbirdFan66
      • 85
      • Berlin, Germany
      Originally posted by WarbirdFan66
      and here something from my workbench, just a little bit of detail work to pass the winter time...
      ...and for those among you who might be interrested, i just uploaded my cockpit *.stl-files to thingyverse, just put Freewing and JAS39 into the search bar and you should be able to find them, cheers
        • 2708
        Outstanding, and your 3D HUD display is spectacular!
        • The swede
          Bulten10
          • Dec 2018
          • 15
          Hello,
          I can not find the post now but now O got the same problem as others, the gear door will not be closed when you retrac the landing gear. what is the solution to this? I do not see that something is bent or so.
            • 5401
            On mine it’s a sign to tighten the set screws holding the strut to the retract.
            • The swede
              Bulten10
              • Dec 2018
              • 15
              Thanks Evan D, I will check that! I didn’t know where to start 😁
              • Radar-Guy
                AirBorn Jetworkx
                • 364
                Originally posted by The swede
                Hello,
                My Gripen is 8s powered and it always happens when I don‘t retract the landing gear ASAP after take-off, it’s obviously related to higher airspeed. When it happens, reducing the airspeed and cycling the gear helps every time.
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1676
                  • Catalonia
                  I usually go straight from take-off into high alpha to retract the gear at low speeds, then I proceed with the flight. ;)
                  • jasmith41
                    EDF-obsessed
                    • Sep 2021
                    • 317
                    • AZ and NE Ohio
                    That's because you're a crazy man... 🤣🤣🤣👍
                    • kallend
                      • 1877
                      I go gear up as soon as there's no way to abort to the runway, which is generally immediately after liftoff since our runway is short.
                      • Radar-Guy
                        AirBorn Jetworkx
                        • 364
                        Not working with a decent 8s fan, she accelerates vertically
                        • Airguardian
                          Post Stall Svengali
                          • Aug 2020
                          • 1676
                          • Catalonia
                          Well, that's entirely possible...
                          I'm using an 8S Jetfan with HET 1865kv motor so it's not like I'm lacking power... going straight into vertical and pull gear up while on the climb is my second go-to strategy!
                          That said, my addition of a mosquito net on the cheater to protect the EDF limits my fan performance and also, despite my attempts at protecting it, the rotor is getting chipped already.
                          Anyway, I crashed again the Gripen and in the repairs I'm getting rid of the wing spar and spar sleeve so that should improve substantially my thrust output. Weight savings are about 30g.
                          • Husafreak
                            • Dec 2018
                            • 125
                            • NorCal
                            Haven't visited in a while but another thread got me going so I gotta share. I absolutely love my Gripen now. I'm flying it with an XFLY 80mm 12 blade 2200 Kv fan, 6s 4000 mAh 60c batteries, and Eagle A3-L gyro. I have the canards working pitch only. It is sooo light and the power is good. Nothing I own is better for super tight maneuvering and it just will not stall. With the power I can always blast away from any "situation" without sinking. But yeah, those main gear doors! I take off into a vertical, reduce power and raise the gear while doing a hammerhead stall, works like a charm :)
                            • WarbirdFan66
                              • 85
                              • Berlin, Germany
                              If one of you guys need a few unnecessary but cool looking 3d printed extra parts for your Gripen , like for storing or on Display at the field, here a few intake and exhaust covers for your GRIPEN (but keep in mind you need a bit of a 4mm softrubber cord to complete them )...you can find them on thingiverse under JAS39, blue skys
Name:	20220529_143802_front engine cover_k300.jpg
ID:	348694Click image for larger version
Name:	20220529_143704_rear cover_k300.jpg
                              • Icarus the 2nd
                                • Aug 2018
                                • 164
                                • Pajottenland, Belgium
                                very nice!
                                • Icarus the 2nd
                                  • Aug 2018
                                  • 164
                                  Nice demo of an 8S powered Gripen in strong winds, recorded at a German EDF meeting 2 weeks ago.
                                  Enjoy!
                                  • Airguardian
                                    Post Stall Svengali
                                    • Aug 2020
                                    • 1676
                                    • Catalonia
                                    Greetings from Sweden!
                                    Bonus:
                                    • Airguardian
                                      Post Stall Svengali
                                      • Aug 2020
                                      • 1676
                                      • Catalonia
                                      Also got to see the Gripen's daddy... huehuehue!
                                      • JetFun
                                        • Jul 2022
                                        • 24
                                        • Germany
                                        How many mm are your deflections for the elevator functon in the rear (ailerons) and the canards? Not sure how many mm I should use on the elevators for the pitch function.
                                          • 8814
                                          Everyone will have their own preference based on their experience and flying style, so it's a bit of a loaded question as is what expo others are using. You should start with what the book says, which also states that elevator travel should be the same as aileron travel. If you have switches that give you 3 rates, use the book values for low and high and dial in either a lower one OR a higher one depending on how you feel about it. Or do what I do to start with ................... dial in a slightly lower rate than the lowest book value and a slightly higher rate than the high book rate and do an average for the middle rate. Go fly it and adjust accordingly. It will also be different if you have the vector nozzle.
