  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1676
    • Catalonia
    Thanks, bookmarked! ^^
    • kallend
      • 1877
      I resized the Meteor missiles to 1:9 scale for the Gripen.
      Print as light as possible except for the mounting lug (if used).To stabilize printing vertically, some breakaway pads are added to the forward section. Remove after printing.Underwing pylons for the Gripen are here:https://www.thingiverse.com/thing:4713773
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1676
        • Catalonia
        Thanks it's appreciated!
        Someday I'll get a friend to print these for mine :)
        • BenOzzy94
          ground magnet extraordinaire
          • Jul 2020
          • 98
          • Kerry, Ireland
          Waiting for decent weather so messing around with my new ordnance instead. Click image for larger version
ID:	358962Click image for larger version
ID:	358963Click image for larger version
ID:	358964Click image for larger version
ID:	358965Click image for larger version
ID:	358966Click image for larger version
ID:	358967Click image for larger version
ID:	358968Click image for larger version
ID:	358969Click image for larger version
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1676
            • Catalonia
            That's so sick, love it! :DDD
            • WarbirdFan66
              • 85
              • Berlin, Germany
              Originally posted by BenOzzy94
              Waiting for decent weather so messing around with my new ordnance instead....
              Really nice job on the armament BenOzzy, did you use the pylons that are on thingiverse and did you modify those? Im asking because i found the originals not to be fitting that well to the wing of the Gripen, or did you design your own maybe?...yours look really nice, specially with all the missles and tanks on it.
              • BenOzzy94
                • Jul 2020
                • 98
                • Kerry, Ireland
                I used the ones on thingiverse. I just slightly adjusted them with heat after they were printed to fit the bulges in the wings
                • HockeyMac!
                  • Nov 2019
                  • 34
                  Ben do you want to let me know the resizing you did for the drop tanks? Those are my design and I can make adjustments to them :)
                  • BenOzzy94
                    • Jul 2020
                    • 98
                    • Kerry, Ireland
                    Will do when I get a chance
                    • kallend
                      • 1877
                      I think he said he used my pylons from Thingiverse. They fit my Gripen perfectly (as you might expect). What problem did you have with them, exactly?
                      If people let me know of issues I can generally fix them pretty quickly.
                      • JetFun
                        • Jul 2022
                        • 24
                        • Germany
                        The Gripen is pretty wobbly with the slightest wind over the roll / aileron axis. Where do you have your CG or do you just add a gyro? First flew the F22 and afterwards the Gripen. Same conditions the F22 stable, the Gripen with lots of roll.
                        • BenOzzy94
                          • Jul 2020
                          • 98
                          • Kerry, Ireland
                          Sorry to change the subject but had a mishap today and need to get parts. Does anyone know which steering arm is needed for the gripen? I know they are listed A-F but can't see which one is needed. Alpha if you could give some insight it would be greatly appreciated.
                          • TangoVector
                            High alpha wannabe
                            • Feb 2019
                            • 142
                            • Leksand, Sweden
                            A quick search shows "Type A" as the correct one:
                            Freewing Landing Gear Steering Arm Type A - Metal - N512
                            These are upgrade parts for the following Freewing aircraft:
                            • Dual 64mm EDF Jets (A-10)
                            • 70mm EDF Jets
                            • 80mm EDF Jets
                            None of the other types show JAS39 as a special version.​
                              • 8814
                              Throw a cheap HobbyEagle gyro in it.
                              • BenOzzy94
                                • Jul 2020
                                • 98
                                • Kerry, Ireland
                                • 70mm EDF Jets
                                • 80mm EDF Jets
                                Thanks buddy. I was looking specifically for it to say "Jas 39 Gripen" that's where I was going wrong
                                • JetFun
                                  • Jul 2022
                                  • 24
                                  • Germany
                                  Never used a gyro...
                                  Looking at the Hobbyeagle gyros. Which is the programming card for the Eagle A3 Super 4? Seems there is none available. Can only find the Super 3 version programming card but no separate super 3 gyro.
                                  Not too keen to use the PC to setup.
                                  Basically I might as well get a second gyro for another aeroplane without a second card so I am looking at options.
                                  Input appreciated...
                                    • 8814
                                    There is no need to get the "fancy" one that needs a programming card. The cheap A3 EVO is more than adequate to solidify the Gripen. It has both 3-axis and 6-axis gyros and can be programmed using the "blink" codes (via the button). The downloadable instructions are easy to follow. 3-axis will give you the stability you need for what you want to do for this plane. The 6-axis will give you the "recovery" or "panic" mode if you so desire to have it.
                                    If you wish to buy one from MotionRC, they only have (at the moment) the A3 Lite. This one will give you the 3-axis gyro and will tame the "wobblies" on the Gripen. Programmed like the EVO via the onboard button and blinky light.
                                    • JetFun
                                      • Jul 2022
                                      • 24
                                      • Germany
                                      xviper Ok thanks that's helpful.
                                      The lite version only uses one aileron. So it seems like that is sufficient?
                                        • 8814
                                        It can be configured as a "delta wing" (elevon), in which case one elevon plugs into AIL and one plugs into ELE. The TX remains as "normal" wing and the gyro does the mixing. It will give you "gyro ON" and "gyro OFF". Don't use "LOCK" mode for this plane. If you don't hook up the "mode" lead, the gyro will simply be ON all the time. You can even have "master gain" control via the rotary knob on the TX. Turning the master gain to zero is the same as turning the gyro OFF. This is great for initial testing of how much gain you need for any given plane. Once you figure out the ideal gain, mark it on the underside of the battery hatch and always set it at that for that plane. OR, you can determine exactly how much gain is really needed and set the gain pots accordingly and disconnect the master gain lead and never worry about it again.
                                        PS. If you choose to go this route, a tutorial can be given at the time.
                                        • kallend
                                          • 1877
                                          Negative. it has a delta wing mode for elevons.
