All-New Freewing PJ50 Twin 70mm EDF Jet - Official Thread
  • Just about ready 4 my maiden waiting 4 callie and dryer weather,,, my 6000 hrb r here hoping 4 some f.ying info,,,, hav watched amost all u tube vids( seen 2 tip stalls) wanto avoid that,, so i have mixed a small amount of rudder with aileron..( hoping thinking that will help... keep up the speed...... looking 4orward to some advice
    • O boy wrong thread meant 4 al 37 knuckelhead
        For the PJ50…The best advice is PUT A GYRO IN IT!”
        Start with 60% gain. Without a gyro, she gets to Dutch Rolling on final in much wind/gusts and can be a challenge.
        I wouldn’t suggest a rudder/aileron mix.
        To minimize tip stall, set each aileron up 5 mm from the streamlined alignment.
        Have fun!
        • PJ-50 turned into C-20G with the help of Callie Graphics.
          Haven't had it in the air yet, hoping if flies as good as it looks.
            • Originally posted by bylawes View Post
              Nicely done! She’s my favorite bird, BUT ONLY after I put a gyro in her.
              Any wind/gust will set up a Dutch roll on final….making landing a challenge. The gyro stops this.
              Also, adjust each aileron 5 mm up when the stick is neutral. This helps reduce the tip stall.
              Have fun!
              PS - If you heed this advice, you will love the PJ-50! If you ignore the advice….well DON’T ignore it.
                Have fun!
                Thanks! I have a gyro installed and it's set up per the manual. You're saying adjust the linkages so the ailerons are 5 mm up like the manual suggests for the elevators?
                Would you adjust the aileron throws after that or leave them at whatever they are after the 5 mm up?
                • See below…repost
                  • Reposting….edits would not save for some reason.
                    Good deal and I have my gyro set at roughly 60% as judged by the adjustment pot on top.
                    First…Set the aileron throws by the book. After that is done, then adjust each aileron up 5 mm as measured at the trailing edge. You are done.
                    Initial flights on low rate, but eventually you will settle on high rate as the default. High rate is better for aerobatics and windy days.
                    -GG​
                    • Bylaws, beautiful work on your PJ50. What color blue did you use? TIA!
                      R
                      • Hi guys. I will likely be pulling the trigger on the PJ50 in the very near future. I am sure it will be a great addition to the fleet. I have some questions I am hoping a few of you who have experience can help answer and they all have to do with electrical connections. Looking at the "assembly" videos and looking at the manual that is available online it appears the connections from the wings are similar to the connections and assembly with the FL F4U EXCEPT for a few lights to hook up. Ok, I've got that. Transport of a 1700mm ws is going to require removal of the wings for transport for me and of course re-installing those wings every time I take her to the field. Not a problem, but it just seems a bit more difficult than it needs to be.
                        Question: Have any of you come up with a better connection / disconnect solution? Sure I can do quick disconnects for the lights and live with running the ribbon cables to the blue box each time, but there has got to be a better way than flipping upside down, securing the wings, then flip right side up and attaching all the connections inside the bay. I don't want to re-invent a wheel. A lot of you guys are marvelous engineers! What magic modifications have you made that makes it easier? Are you willing to share that information? Please!​
                        • Hi Larry….I leave mine assembled, so I cannot address your question. I will suggest you read all the posts in this forum. Lots to know about the PJ.
                          She’s my overall favorite, but only if…..
                          1) You install a gyro.
                          2) Manually adjust both ailerons 5 mm up from the trailing edge line when the stick is centered.
                          Fail to do these, and she will Dutch roll on final approach on gusty days….a handful to land. If you heed the advice, she’s VERY tame even up to 20 mph gusty wind days.
                          • Successful (and uneventful) maiden last Sunday (04/07/24). Thanks for all the suggestions and recommendations gentlemen. Takeoff roll was slower than I thought it should be but I think it was because of the thick grass on our runway creating a lot of drag on the gear. A couple of tiny issues left to correct but those will be worked out in the next few flights I'm sure. I will have to improve my crosswind takeoff technique with this one for sure. A friend helped me with a quick connect/disconnect harness for the wing/belly lights. All-in-all, very pleased. Excellent flyer. My "fleet" consists of mostly warbirds (prop and edf) so this is a nice change of pace for me.
                            Thanks for the pictures and video on your strobe light connections Tom on what you did. Gave me some good ideas that actually worked!
                            GG - Good recommendations all around. Next flights I'll turn the stabilization on and I'm sure it will fly even better in the wind.
                            Thanks again guys!
                            • Hey Gliderguy...new to this forum, but I somehow get the impression that you are recommending a gyro for this bird...eh?
                              • Originally posted by RCS1313 View Post
                                Welcome! When I first flew it, seemed good with no gyro. But with more windy gusty day experience, she Dutch rolls on final WAY TOO MUCH for fun.
                                Added a 3-axis gyro at 60% gain and she’s a different bird.
                                She is now my go-to bird for windy gusty days.
                                The other item….with the stick centered, manually adjust each aileron up 5 mm from trailing edge streamline.
ID:	402975Click image for larger version
ID:	402974 ​​​ Click image for larger version
Name:	BVM Deer Lodge MT.jpg
                                  • Not new to the hobby--1984ish.....just a smidge of the hanger.
                                    have the PJ50...took note of the 3 to 5mm reflex on the ailerons...great idea! Will do that as I have only flown her one time and did experience the dutch roll on landing. No gyro yet but will take your advice to heart.
                                    I started my jet experience with a Byron F16, the Byron Bullet , the Avonds Rafale and have two turbines, the BVM Mig15 and a Hotspot ---sold by Yellow Aircraft before they went out of business. I have had the Hotspot in about a 70% complete build and bought the kit in the early 90's, not sure I will ever get it finished??? Too many planes, not enough time
                                    Don't tell the wife , but close to 70 planes, some new, some quite old, in the hanger. Probably have built and/or assembled close to 275 + aircraft since starting in the hobby... Rod
                                    • Really enjoy some of these EDF's..... HK Vampire, BH Mig17, Freewing AL37, Freewing B2Bomber, E-flite F-16....this FW PJ50 should round out my EDF hanger just fine....I'm in
                                      TwistedGrin
                                      • Still waiting for a maiden date......deployed a nosewheel support brace which might help longevity for grass operations. I also cleaned up my wiring to make it easier for field assembly....it does make it less fiddly when the wires are bound together and fastened to the fuselage sides. Transport-Storage wing bag protectors incorporate velcro strips for single wing or two separate wings ....ready to go
                                        TwistedGrin​
                                        • Wow this bird flies really nice. It's very quiet and slippery.....easily lands on the rear mains with full flaps like an arrow.....way faster than I expected it could go....but also able to cruise at 30% throttle....looks great in the air
                                          My maiden was totally uneventful and smooth.....three more flights proved the same....smooth flier.....perhaps elegance could be a good description
                                          TwistedGrin
