  • Capt G
    Always learning
    • 18
    • So. Nevada
    New innrunner - 77A on 35% battery. Ready for maiden
    • Husafreak
      • Dec 2018
      • 125
      • NorCal
      Jumping in at the end here but has anyone put the Freewing 80mm 9-Blade EDF Power System w/3658-1920kV Inrunner Motor from the T-33 into this jet?
      I have been completely blown away by that fan in my T-33. For years it was SOP for me to replace Freewings fans with FMS fans so I don't have really high expectations for the stock fan, I expect good but not great. But I would like to put the factory T-33 fan in all my 80mm jets now! FWIW I don't have the Mig-21 yet and they only have the motor less version in stock right now...
        Husafreak The 1920kv inrunner will make this MiG-21 a rocketship, even more spritely than it already is with its current PNP setup. The MiG-21 has a larger battery bay with more fore/aft leeway for CG adjustments if you go with a bigger pack to feed the power system.
        • Husafreak
          • Dec 2018
          • 125
          • NorCal
          Sounds promising... I run 5000 6s. In my T-33 with voltage telemetry those are good for 5 mins of hard and fast or 8 min of taking it easy. Which is crazy! That is a great fan. Powerful AND efficient is the new normal, wanting both!
          • yf22raptor
            Love to fly
            • 75
            Here is my mig , just finished painting and weathered and she is turbine powered with a x-45 micro turbine ...
            • Husafreak
              • Dec 2018
              • 125
              • NorCal
              It would be cool to see the turbine installation. I think the Xicoy X-45 is a great spec turbine. Let us know how it flies.
              • Husafreak
                • Dec 2018
                • 125
                • NorCal
                Looking forward to collecting mine. A flying buddy decided to sell me his. It's in mint shape. I'll get together with gooniac and make sure the throws and CG are reasonable before I fly it, plus I'm going to need another firebooty! I did see your recommendations are all pretty consistent, just have to avoid too much aileron throw or an overly forward (or aft) CG. Actually the scariest flight I ever witnessed was a turbine Mig-21 maiden with aft CG, it was only controllable at high speed, every time my buddy pulled power to slow it would loose control, LOL, needless to say we all ended up hiding behind our cars until it finally bought the farm in a spectacular crash, nothing left. I checked out the MRC video and was a little disappointed that it was gulping down a 5ooo mAh pack in 3 minutes. The only other EDF I have that gets a 3 min timer is my FW 90mm F-104. I have some 6200 mAh packs too but never thought they would be in an 80mm EDF. I won't know exactly which power system is in it till I get it. Was this jet ever offered with different power systems? Or are all the stock PNP set ups the same?
                • Mizer67
                  • 374
                  If you're looking for efficiency in a stock FW fan, buy the new 9 bld 1920kv inrunner.
                  From what I've read, it's the most efficient FW 80mm setup they've offered (with decent performance). It might be tough to get a CG aft enough with the lighter EDF though.
                  It's new , so I'd expect that unless it's a very recent purchase it won't have it in there already. If it's the 1857kv inrunner (or pretty much any other EDF this plane has had in it), I wouldn't expect more than ~3 min.
                  • Husafreak
                    • Dec 2018
                    • 125
                    • NorCal
                    Maybe if the used Mig-21 is inexpensive enough I'll buy it a 9 blade 1920kv fan. That power system is the single best reason to buy a T-33 IMHO. Superlative performance. I have my T-33 timer set to 5min and with pack voltage telemetry as a back up I regularly fly it for 7 minutes and land with 25-30%. It would be very interesting to see if that 1920kv fan can perform as well in other 80mm airframes. The T-33 is very slippery and a great glider so a lot of the flight can be done at very low or no power. Delta types like the Mig-21 typically require more thrust to keep them moving.
                    I'm pretty happy with MRC, it used to be an FMS fan was a nice upgrade for a lot of FW EDF's but lately they have upped their game.
                    • Mizer67
                      • 374
                      I like the direction. I have no experience with that power plant so far but do want to try one soon. While I'd like more flight time, more flight time is not my goal. I go for greater performance first, either speed or thrust. I have the FMS 2100kv Pro in my Mig-21 and it's a good combo. 2850 grams of thrust at peak for about that weight in the plane, which really helps it out as the performance I had out of the 1857kv 12-bld was not impressive. Made me not enjoy the Mig initially.
                      Top speed of low ~110's, with ~650ft of vertical with the FMS fan, which is respectable. Makes the Mig much more enjoyable to fly, even if it's only ~3 min. of useful throttle on a 4000.
                      • Quickstop
                        • 275
                        I popped the motor out of my t-33 and put in in the mig21, more umph but the flight times I was getting in the t-33 just weren’t happening in the mig. I not sure if it would be worth the expense to replace the inrunner it comes with. I think the T-33 gets great flight times because it’s a t-33, not so much the fan, I totally agree about the delta needing more power.
                        • Husafreak
                          • Dec 2018
                          • 125
                          • NorCal
                          Thanks for that real world insight! I'll just fly it with the stock fan then, at least I know the T-33 flight times are not achievable with just any jet.
                          I picked up my Mig-21 today, got a good deal for a mint Mig, but the seller realized only after handing it over that the drop tanks are "in storage" somewhere, maybe, not sure :( He said he would look for them. Anyway he's a good friend so I said fine but I kinda doubt that I'll ever get them. Soooo, do you guys prefer the jet with or without them? Surely it is faster and more efficient without the drag, but they look cool, but are they something you generally like or need or don't care about them? Kind of a personal preference question but I would like to know how it flies with or without them.
                          • Quickstop
                            • 275
                            I never fly with wing stores, maybe once and then they go into the closet. The extra drag means you need to use more power and then less flight times. Most of the times I dont even put on the racks
                            • Mizer67
                              • 374
                              I never fly with ordinance. Any performance impact is a big negative in my opinion. I'd only fly with it if I needed additional help orienting on the plane for some reason, and then only in specific conditions. Or perhaps a couple of show passes.
                              • Husafreak
                                • Dec 2018
                                • 125
                                • NorCal
                                Cool, thanks, how about wing rock with this one? Do you guys consider a gyro necessary, nice but not necessary, or not necessary. Generally I only use a gyro if it noticeably helps stability.
                                • Mizer67
                                  • 374
                                  This one does have some wing rock in slow flight, more than say the Mirage but nothing excessive. I think a gyro helps cure that, but it's not necessary at all. I use an A3S3 right now set on 35% gain and 3D. It helps on-center with the rocking without completely numbing the feel of the plane. It's a rock solid airplane in any situation with this combo.
                                  I fly it in any conditions and it handles them all with aplomb. Initially, I flew it into tighter spots because I didn't care for it much, so I wasn't concerned if I busted it up. But it's stability and low speed handling have really grown on me. I can drop it into any field, particularly on grass and get it stopped in ~50 ft. or so. For a max performance T/O on pavement I've gotten that down to 75 ft. and I think I could get it off in a few feet less. I did replace the EDF though, which helped it with more thrust and vertical.
                                  • the snake
                                    I can't help my self dear! I love RC!
                                    • Nov 2013
                                    • 126
                                    Freewing Mig-21 3 year anniversary flight
                                    • Husafreak
                                      • Dec 2018
                                      • 125
                                      • NorCal
                                      So, do you guys think this is the inrunner motor? I guess it must be there’s a housing around it...
                                        • 2137
                                        • On planet earth....right
                                        Even though I'm viewing this on a small smartphone screen, that's an outrunner motor.
                                        • Husafreak
                                          • Dec 2018
                                          • 125
                                          • NorCal
                                          Sooo, I decided to put an Aura 8 in the jet, I bought it for $50 from a club member who complained he couldn't figure it out and now I know why! But after a little "hand holding" from a friend who has several I got it sorted. I used the manual rates except less aileron, and the factory CG. I got the maiden and 5 flights on it today. I really like it! It looks way cool in flight and was quite easy to spot the landings. As you guys told me the gyro is not necessary but here in California right now the smoke haze is a big problem if you are flying a Mig-21 for the first time! Vis was a little poor. So when i started using the gyro on the second flight I was relieved to have it lock in like it was on rails. No wing rock or over rolling. There's not a whole lot of wing to look at and the Aura 8 really impressed me as there was basically no dialing in, just flip the switch and enjoy the ride. I think it is a quality product.
                                          I found the Mig to be a little "old school" in its performance. That is not a bad thing but it is not the fastest or most powerful or efficient Freewing jet I own. But it is a little more "pilot friendly" than my 90mm F-104 and similar to my F-5 if not as fast. Where it stands out is it looks cool! Three minutes is definitely appropriate, all my flights were right around 30% battery remaining after three. I'm a bit bummed about that (considering it's an 80mm and I'm using 6s 5000 mAh packs) but you can really see it in flight, going to idle it slows right down, not much of a glider, must be a lot of aerodynamic drag. But on the gas it rocks! Love the tight turns and axial rolls too. Bottom line I am glad I got it, very cool airplane, fun to fly (no drop tanks BTW), and looks like nothing else on earth. This is why I love FW foam jets, I wouldn't really want a turbine with this limited a flight envelope, but you can enjoy flying and owning a Mig-21 without having to take out a second mortgage!
