The manual does not give a cg range, just a single measurement and fuselage mark for the cg. My battery (5200mah) is well aft in the compartment to achieve that cg and although the jet flies ok, it's a little sensitive/pitchy on landing...kind of like the cg is a little aft. I was going to experiment with moving the battery forward. The only real risk I see is maybe running out of elevator on landing. Wondering what others have found and/or tried regarding cg.
Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
It's hard to reason with someone with blinkers on.
There is a very easy solution to this. Make adjustments minute. Trial and error can be tedious.The manual does not give a cg range, just a single measurement and fuselage mark for the cg. My battery (5200mah) is well aft in the compartment to achieve that cg and although the jet flies ok, it's a little sensitive/pitchy on landing...kind of like the cg is a little aft. I was going to experiment with moving the battery forward. The only real risk I see is maybe running out of elevator on landing. Wondering what others have found and/or tried regarding cg.Comment
After the failed single engine take off and subsequent flat spin , the F14 is rebuilt and ready for a re maiden this week. During my rebuild i ordered a new ESC and sent the old one back to Freewing. I connected the new one for a test and all ops normaol.
Finished the re connection and went to test all functions and found that on plugging in the ESC REV wire , one motor failed to work !!! After many hours fault finding a tearing my hair out in frustration , i found the error ! I had a bad line of programming in the EdgeTx software. In my enthusiam for multiple safety measure I had made a mistake!
I love this hobby as I am always learning something new. At least its ready to go again and have a new as a spare.
I have reverse on a switch and providing that the GEAR is down , The TROTTLE is active, it will provide a certain level of reverse. Got to love RC!
Further update on the plane after i thought i solved the issue. All was working perfectly and i powered on the model and the fault re appeared, no motor on one side. I disconnected the REV cable to the RX and powered up again....Bingo , both engines live. I then connected the REV to CH 6 as before and now all working as intended.
On RCG i was told this is an issue with some ESC firmware that gets confused when the RX is an an uknown state, IE bfore the radio connection is established. This is because ELRS receivers do not output on the PWM ports until a link is established.
Now to solve it I have to wait till powered up and then connect reverse! Another lesson learned about RC and ELRS.
Hope this may help someone down the line.Comment
Every time the lipo is changed, the reverse signal lead needs to be unplugged prior to power and then plugged back in? Cannot be the design intent or end user expectation.Further update on the plane after i thought i solved the issue. All was working perfectly and i powered on the model and the fault re appeared, no motor on one side. I disconnected the REV cable to the RX and powered up again....Bingo , both engines live. I then connected the REV to CH 6 as before and now all working as intended.
Re maiden complete with a SMC 5900 HV pack. Managed 2 flights with the first landing ok but a little fast. I kept the wings out for the entire flight and felt that it was quite a heart racing first flight. My second landing was not as good as I flared the aircraft a bit too early and did not maintain a steady rate of descent to touchdown, it flattened out too much and I ended up dropping a wing from about 1ft. No real damage , just the pinion to the gear which sheared off. Lucky just 3.99 on Motion so have ordered a few as spares.
I have seen that many people are using lighter packs so have ordered a few of the CHNL HV packs with 4500 MaH, this drops the weight by about 160 gramms. Fingers crossed for the next flight. I think I will use this airframe until I get a bit more confidence before breaking out the replacement.Comment
A reminder, since apparently some didn't get the message first time around.F-14 158984 (this VF-1 Wolfpack one)) was an F-14A. Here is a photo of the real thing:
This Wolf Pack Tomcat was photographed at its home base, NAS Miramar, in August 1976. Like its sister squadron, VF-2, VF-1 was part of Carrier Air Wing 14 (CVW-14) which was assigned to the USS Enterprise (CVN-65). The squadron was established on 14 October 1972 and disestablished on 01 October 1993.
The stock nozzles on this model are not correct for the F-14A (as you can see in the photo). They are not even close.
I have put some 3DP nozzles correct for the F-14A up on Thingiverse, that fit this model and have a properly sized outlet.
Still no V2 wings at Motion, it's been nearly 7 months now.Comment
