Official Freewing 64mm F-14 Tomcat Twin 64mm EDF Jet Thread
Thanks!
At least the first ones I highlighted at the beginning of the video were... there were a few others that were 'less than stellar', but I'm still adjusting and getting used to the cat, so I'll take it!
I don't think I'm coming with the same level of throttle on each approach. At the angles I'm coming, the jet can easily transition to reverse regime, and at that point, a small change in AoA requires totally different throttle settings...
But, for the approach, let's say, before I get into muddy waters, it was probably something like 15-25%?
I don't consciously think about it but will try to remember next time I bring it out for a spin! :)Comment
Have you seen the latest warning on the Motion site about doing that sort of thing?
Power System and Electronics Compatibility:
This model is designed to operate using the included ESC and its integrated BEC, which is specifically matched to the onboard electronics. To ensure reliable performance and prevent damage, always power the aircraft's receiver and electronics through the installed ESC using the main flight battery. Do not use any power source other than the main flight battery to power the model, otherwise damage will occur to the electronics.
The receiver, servos, and other onboard electronics included with this model are rated for a maximum input voltage of 5.5V. When selecting your ESC and power system, verify that the BEC output supplied to the receiver and onboard electronics does not exceed 5.5V. Using a higher voltage will damage the aircraft's electronics.
Betaflight receiver? "bad line of programming"
You seem to have a complicated set up.
The setup is pretty straightforward in that it is a 14Ch ELRS receiver that due to an anomaly that the pins are not powered until a connection is made between the receiver and the radio. On my single engine jets this doesn’t cause a problem , just with the twin ESC’s of the F14 when one of the ESC’s does not initialise on power up! Very strange and I don’t have this issue on the Radiomaster ER 8. i just have to remember to disconnect the REV cable on battery disconnect. I have ordered more RadioMaster receivers!
Good luck on the landings!
As always, test the setup first at higher altitude before attempting to come down with it! :D
As for Motion's warning message, I can't say for sure 100% but it totally reads to me like they are oversimplifying stuff like always, explaining recipes without actually telling the complete reasons why.
My guess is the warning is there to prevent people from plugging in their own external power supplies before first removing the red wire from the ESC to disable the ESC BEC. Of course you'll fry things if you have the two power sources competing, short of adding shottcky diodes to both supply lines.
And yeah, FW electronics are sadly fragile, not taking any more than 5.5V. It's one of my biggest recurring gripes with their component quality. Everything should be HV capable from factory, and we'd have a lot less problems.
But I'm fairly confident that running your own BEC at the right voltage and having previously disabled the included ESC one should be perfectly fine. I have been doing it for years on most of my models.
They didn't provide a single reason why this one would be any different from the rest of their jets.
Anyway, don't blame me if you end up burning something, everybody gotta take their own risks! :)Comment
Yeah, gotta be that.
I don't like this 'obscure' way to treat things.
Just state the problems outright:
"If you plug your own power supply without disabling the ESC BEC, you'll fry stuff. Components rated for 5.5V max."
There, two short sentences. How hard can it be?
Thank you. You said Betaflight before and I didn’t know there was such a thing.
This is the Betafpv 14 CH receiver, works fab....except in twin ESC planes!!
https://betafpv.com/products/superp-...guiEO7BdAXHdycComment
Coming up on 8 months now.V2 has arrived! The finest flying foam EDF F-14 on the market. Click the link below to see what the hype is all about!
Get yours ASAP, these puppies will not last, guaranteed.
Freewing F-14 Tomcat Twin V2 64mm EDF Jet - PNP
Buy Freewing F-14 Tomcat "Wolf Pack" Twin 64mm EDF Jet V2 - PNP online at Motion RC. Order online with fast delivery.
Freewing F-14 Tomcat Twin V2 64mm EDF Jet - ARF PLUS
https://www.motionrc.com/products/fr...plus-fj11421ap
When are V2 wings going to be available for retrofitting to the V1?Comment
