    • 5416
    Exactly what fan do you have?
    • flazz
      maiden this!
      • 40
      • USA
      Evan D
      Thanks for the reply.
      Is the 90mm 12 blade thats used in the New F-16 ......
        • 5416
        The new F-16 has 4075 1350Kv or 3668-1960Kv depending on 8S or 6S. Assuming 6S 3668-1960Kv many report higher than 120A on a fresh battery, some with HV packs are reporting over 130. I would not use the 100A you have. Of the ones in your post the 130A would be what I would use but you'll need a BEC.
        Originally posted by flazz
        Hi guys,
        I've got a new FreeWing f-16 that's an ARF since I already have a couple 90mm 12 blades.
        The specs on the motor 3668-1926 kv that calls for an ESC 120a and 7a. I have a freewing 130a with no Bec and a Predator 100a with a 7a Bec, and a Dlux Tunagy 100/120a with a 5.5 Bec.
        Also, I have several inrunner motors from 1000kv to 1920kv. I'd like to be able to use the Predator 100a and the 1920kv, but I don't enough about the combinations of these things so I'm asking.
        Thanks for any suggestions or feed back.
        • flazz
          maiden this!
          • 40
          • USA
          Thanks Ev D,
          I was trending to go that way. I'll be running a 6v pack and a 1920kv, I have 2 5a Bec's comming from Motionrc. Do I need a 7a with the 130 or will the 5a be ok.?
          steve
            • 5416
            The BEC powers your servos, lights and retracts. I would get at least a 7A. I don't see a 5A BEC listed under BECs.
            Not sure what 1920kV motor you have, what brand is it?
            • flazz
              maiden this!
              • 40
              • USA
              the 1920kv is a FreeWing I've had for quite a while. and I thought I ordered them, but checking, I didn't ..............lol
              You have a sorce for 5's and 7's ?
              thanks
                • 5416
                I have few from when the FreeWing sytems had separate BECs. Motion has some but try Amazon.
                • flazz
                  maiden this!
                  • 40
                  • USA
                  Will do, thanks Evan
                  • Ricardopr54
                    • 9
                    Why has no one clarified the ESC issue this jet came with, specifically the fact that the ESC installed from the factory is not beeping the battery's cell count? Some are saying that these ESCs count the battery cells differently, but to this day, nobody from MotionRC has clarified this issue to clear this new jet's reputation.
                    Motion RC is aware of this issue but has not provided any clarification on the matter. Why is this? What are they hiding from us? I have spent thousands of dollars on airplanes from their store, but when I asked them this simple question, their response was that they referred my inquiry directly to Freewing and are waiting for their response. In the meantime, my plane is still grounded in my hangar room. I was going to send the "bad" ESC back and wait for a replacement, but replacements are on backorder without an ETA on availability.
                    I'm going to maiden fly my jet as is and publish a video including screenshots of all my chat conversations and emails from MotionRC related to the aforementioned "ESC issue." If the plane crashes due to ESC failure, I'll blame them for it. Of course, I'm fully aware that if that happens, I won't be able to claim compensation for it because I decided to fly a plane that was shipped with defective parts. However, at least I'll create awareness for others to think twice about whether or not to trust this store with their money.
                    Order 802627 and Ticket number T415054.
                      • 5416
                      You really come off in a bad light. I could use different words that, while appropriate, might make me look like a douche.
                      It is a FreeWing issue and is specific to the 6S version. Motion as a vendor has sent replacement blue ESCs to all that have asked and I have to say many that have asked did so with no issue other than the different way the red one beeped which is how those ESCs were designed by Hobby Wing.
                      "because I decided to fly a plane that was shipped with defective parts." Really? What defective parts? The truth is that you are complaining about nothing. And I laugh about your spending thousands, I did that last month alone.
                      A couple have noted an ESC fire and those should be rightfully warrantied.
                      If you wanted a blue 120A bad enough, maybe this would help. Freewing 120A ESC with 8A BEC and Reverse Thrust Function [092D002001] Motion RC​
                      • Local 40
                        • Oct 2024
                        • 2
                        Hello
                        i am using a 6s and 2s setup. The 2s always comes in with like 20 percent left. The 6s will have approximately 50 percent left. Both batteries are from same manufacturer and both are 6000 mah. My question is. Is this normal?
                          • 5416
                          Not at all. Should be the same.
                          • Local 40
                            • Oct 2024
                            • 2
                            I have two different sets of batteries. Both sets do this. Any ideals? Thanks
                              • 5416
                              Can you post a pic of them and your adapter?
                              • Jon @ Two Bros RC
                                • Feb 2024
                                • 16
                                Forgot to post this here!
                                • EDF-Jetpilot
                                  Jets are a lot of fun
                                  • May 2024
                                  • 137
                                  • Aarburg, Schweiz
                                  Originally posted by Jon @ Two Bros RC
                                  Hallo Jon, deine Videos und Erklärungen sind für uns Piloten sehr viel Wert und bringen Mut und Experimentierfreude in das Hobby. Ich bin genau deiner Meinung und auf das Video E-Flite F-16 80mm 6S vs. Freewing F-16 90mmm V2 (8S) gespannt! Ich habe meine Freewing 90mm V2 genau mit deinen AS3X+ Werten eingestellt und werde so den Erstflug machen. Natürlich mit 3-Stufen-Schalter: aus-an-halten. Du siehst, ich vertraue dir! ...und übernehme natürlich die Verantwortung selbst, das ist ja klar. Ich kenne mich mit F-16 Jets aus. Aber deine Eingaben sind auch für geübte Piloten sehr interessant. Grüsse aus der Schweiz.
                                  Quick Translation:
                                  jon @ Two Bros RC
                                  Hello Jon, your videos and explanations are very valuable to us pilots and bring courage and the joy of experimentation into the hobby. I agree exactly with you and am looking forward to the video E-Flite F-16 80mm 6S vs. Freewing F-16 90mmm V2 (8S)! I have set my Freewing 90mm V2 exactly with your AS3X+ values ​​and will do the first flight that way. Of course with 3-stage switch: off-on-hold. You see, I trust you! ...and of course I take responsibility myself, that's clear. I know about F-16 jets. But your input is also very interesting for experienced pilots. Greetings from Switzerland.​
                                  • urrl
                                    • Oct 2013
                                    • 508
                                    Morning flight
                                    • ArmorBolt
                                      • Dec 2020
                                      • 72
                                      So for the 90mm F16 6S version, does anyone know if Motion finally resolved the burning ESC problem or not. Thanks.
                                      • shortround91
                                        • Nov 2023
                                        • 301
                                        • Princess Anne, Maryland
                                        From what I understand from several owners you want the blue ESC red and black ones have had the only issues I’ve heard about
                                          • 5416
                                          Exactly and it’s FreeWings issue to fix or not.
