  • Waconut
    • Feb 2020
    • 310
    • Cincinnati, Ohio
    The actual shipping time is running about a week. I am getting shipping notifications. The orders were actually shipped 2 weeks after being received. I can understand a shipping delay due to the post office, waiting 2 weeks to process and ship is not acceptable IMO.
    • themudduck
      -TMD- Foaming at the Mouth!
      • 1041
      • Burton OH (near Cleveland)
      True... I agree 100%
      By the way I've watched what you're doing with interest. its going to look fantastic. I doubt the added weight will matter much - you may have to land at a very slightly higher speed but other than that it will be fine.
      • Waconut
        • Feb 2020
        • 310
        • Cincinnati, Ohio
        I finally received my order of Flite Metal. I am hoping to have the metal finished up this weekend.
        • Waconut
          • Feb 2020
          • 310
          • Cincinnati, Ohio
          I finished adding the flite metal to the fuselage. It’s far from perfect but should look good after polishing. Once I get it polished I can add the rivet details and mask for the trim colors.
          • EA-6B Geek
            EW Misfit
            • 485
            • South Central Ohio
            That’s going to look amazing on bright sunny day.
            • Waconut
              • Feb 2020
              • 310
              • Cincinnati, Ohio
              The aluminum is now polished. Ready to start masking for the trim colors.
              • timmybeetle
                Warbird addict
                • 133
                • Netherlands
                Hi looks very good, but did you weight yours part before and after putting this flite metal on.
                I saw back that you would do this so maybe when you're done you could post all the data here.
                That would be great to see how much weight you put on?
                Grts Hans
                • Waconut
                  • Feb 2020
                  • 310
                  • Cincinnati, Ohio
                  The Polycrylic, primer and flite metal added 8.7 ounces.
                  • Waconut
                    • Feb 2020
                    • 310
                    • Cincinnati, Ohio
                    I finished up the F-104. Overall I am happy with it. I can’t wait for a sunny day to get it outside for some pictures. Maiden won’t happen until spring.
                    • DCORSAIR
                      • 1918
                      • Selma, Ca.
                      Wow is all I can say, looks amazing, its going to look awesome in the air, good luck on the maiden or should I say your first landing...........
                        • 5401
                        Looks very good. I'd be concerned about the extra half pound...
                        Well done!
                        • Waconut
                          • Feb 2020
                          • 310
                          • Cincinnati, Ohio
                          Well done!
                          We shall see how it goes one spring.
                          • EA-6B Geek
                            EW Misfit
                            • 485
                            I think it looks fantastic! Will I see it at Jet Jam in June?
                            • Waconut
                              • Feb 2020
                              • 310
                              • Cincinnati, Ohio
                              I may be there. I am located just east of Cincinnati so it’s not far.
                              • EA-6B Geek
                                EW Misfit
                                • 485
                                I look forward to seeing it then! I live about an hour northeast of Cincinnati, and attended that event in 2018.
                                • themudduck
                                  • 1041
                                  Bring it to Terry's Ejets event (TORKS near Columbus/Dayton) in Sept and I'll fly mine in formation with yours!
                                  • Waconut
                                    • Feb 2020
                                    • 310
                                    • Cincinnati, Ohio
                                    If it survives that long I will
                                    • gooniac33
                                      The Original Gooniac
                                      • Jun 2016
                                      • 1047
                                      I haven't flown my F-104 in quite some time... But was able to this past weekend!! I have been meaning to make some more changes to get the gyro less twitchy and finally did something about it. I moved the aileron linkage all the way in on the servo arm and that really did seem to help with the wiggle it has! It didn't totally take it away but about 95% of it is gone now! Hoping that some more gain adjustments will help get rid of it all together!
                                      • DCORSAIR
                                        • 1918
                                        • Selma, Ca.
                                        Yep, I posted that along time ago but no one seemed to care I moved mine in as far as the foam would let me and the funny part about it is, you then can crank up the gyro on the ailerons and waalaa, its so much better, it still won't cure it completely but at times it won't move at all and then a slight breeze will give you just a slight wiggle, I had my aileron setting with the little tab on the dial was at 6 o'clock, I even went to 7 and it worked great but kind of felt funny on movement.
                                        • Waconut
                                          • Feb 2020
                                          • 310
                                          • Cincinnati, Ohio
                                          Good tips,
                                          I will follow suit on the aileron’s.
                                          Thanks!!
                                          Anthony
