  • DCORSAIR
    • 1918
    • Selma, Ca.
    Originally posted by Aros
    Freewing (with Motion's guidance and partnership) have made great strides in improving these EDF jets with each passing year. What I would really like to see in the next generation of EPO EDF jets is improving overall AUW. The 90mm F-16 is a looker but as pointed out, she really needs to go on a diet. It has kept me from getting another one since I bought one when it first came out years back. I think the F-22 and F-4 are great examples of two new gen jets that have the size and looks, but not the weight. In the prop world, I feel the same about the FlightLine P-38. Wonderful model in many ways but the wing load/weight is too high for my preference.
    There are so many factors that contribute to heavier models I understand. I can only imagine the difficulty in providing world-class EPO jets with the scale looks and features we love while maintaining a lower AUW. But I have seen many advancements over the years and I am convinced if anyone can do it Freewing can.
    Yep your are right and yes it could go on a diet, but I like heavy jets and planes actually, the weight is what makes this one fly like it does, scale flights are really fun when you see it skidding around in the turns, take it up into a loop and pull full elevator and watch the tail skid up and the nose drops, flies scale thats for sure, I hope they keep it as is myself, maybe sell it with the 1835 already in it though.
      • 8203
      I can see that actually. I just prefer the lighter wing-loaded aircraft personally. But to each their own, and there's no wrong or right, simply preference. I am totally tempted to snag another one...Get the ARF + and add that inrunner system most are using and paint her up Arctic Camo and enjoy the girl for what she is.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        My buddy had the 70mm Artic Camo F-16, talk about hard to see, that camo paint job works.........
        Hope you do get another one and try it with the 1835kv, still a heavy bird but with some thrust.
          • 2816
          • Arlington, TX
          One of the reasons I love using the FMS fan in mine is the lighter weight. It made the airplane feel significantly lighter between the higher thrust and lower weight. Either option seems like it provides great results though!
            • 8203
            I have heard nothing but good things about that FMS fan...Do you mind posting all the details (links)? I may go that route. Many thanks!
            • gooniac33
              The Original Gooniac
              • Jun 2016
              • 1047
              Originally posted by Phantom
              Well I purchased the ARF plus 90mm F-16C T-Bird. Then I placed a 9bladed 6s 90mm 3748-1750kv outrunner. I was hoping by saving a couple of ounces on a lighter setup, 9 blades instead of 12 for a little more efficiency, l would have a somewhat scale flight profile minus full blown aerobatics...
              Let me start off by saying, DAMN this bird is heavy! It was heavy when I took just the fuselage, absent of a power system out the box.
              I spoke here before about going to 8s... I've got a couple of re-power options coming. One 6s and two 8s...
              The current power system, is good for take off after a very long ground roll at 100%, and limping around the pattern at 70% or greater once she's in a clean configuration, anything less results in a descent. I'll keep you folks updated...
              The plane will fly heavy if you don't let it pick up speed. These birds are a lesson in energy management. Even when they are overpowered they can seem heavy but they really just need to be flown properly. When they first came out the fan was a 1450kv outrunner and they flew fabulous! You just couldn't take off and yank the nose up the whole time and expect it to power through. Take off at full power and climb out at a 45degree angle or less then drop throttle to about half, level off pick up speed and then climb a little more. That is usually about one lap around the field. By that time you should be at least 400-600 feet in altitude. You then turn all of that altitude into momentum. Point the noise down and get some speed. Its really good to learn how to do this and then you will never say that a plane has no power and is a pig. You just need to learn how to use what you have...
              Now that being said.... the new F-16 is a really nice bird! The upgraded 12 blade rotor and motor has transformed how the plane flies! Merry Boozers posted a video of him flying it at Joe Nall and it looked like it was using an inrunner! It was the new stock outrunner set up and it was really impressive!! I Hope that I haven't posted this already but here it is. Take a look and I am seriously considering getting this new version!
              Or if you want a lighter 6s set up put in an FMS fan. You won't gain a whole lot of speed but the plane will for sure lose weight, climb like crazy and also gain some flight time as well! It made a huge difference in my F-104 and can help this plane as well.
              Now I am also working on a couple new inrunner set ups that will be really good! I will soon have one in my F-22 that I will share...
                • 2816
                • Arlington, TX
                Sure! I used this fan/motor: http://www.fmsmodel.com/fms-90mm-12-...fan-with-motor and upgraded to this ESC: https://hobbyking.com/en_us/yep-150a...ontroller.html. Using the stock ESC is possible, but has has mixed results. My stock ESC died when using the FMS fan (even set to low timing), but others have used it with success. As Gooniac said, it is not all that much faster, but is much lighter and has much improved vertical climb performance.
                  • 8203
                  Good to know, thanks!
                  • Phantom
                    • Mar 2019
                    • 504
                    • M.D.
                    Originally posted by DCORSAIR
                    I've had five of these so far, I tend to wear them out, put the 1835kv in it and fly it, it is heavy no matter what you do really, the thing is with the F-16, give it a chance and put as many flights on it as you can, move your CG around until you get it right, usually around 118mm-120mm is good, yeah it is nose heavy but flies better I think and landings are so much easier. This jet takes time to understand how it wants to be flown, I take off and do rolls with it as the gear is coming up and it loops right after takeoff as well, I know this sounds kind of strange, but when you watch the full scale demos it actually likes to be flown like that and it is faster than you think, do a high speed pass and pull vertical, that is with the 1835 installed and see, its not bad and you can do a few rolls on the way up, I just love the looks and the gear is nice and scale, don't give up, put some flights on it and get used ot it and I bet you will begin to like it......
                    DCORSAIR,
                    I kicked around the idea of the 1835kv as it seems to be the top of the line power option on Motion. But that power option along with the ESC will be 260.00 to 300.00 and add additional weight. Not a big deal as this hobby can be expensive especially for jets, I have to balance between cost and the flight experience gained.
                    I hesitated on it due to my experience re powering my FW F-86 80mm with the FMS 80MM with the 2100 or 2150kv motor, can't remember which off the top of my head... The results were positive all around, the setup was lighter, more efficient, more static thrust, a little more speed, but a lot more vertical. It woke the bird up and gave me an additional 30 to 60 seconds of flying time depending on what maneuver I'm preforming.
                    So I am heading the way of FMS and another manufacturer to try to repower her using the same money or less to try and duplicate my success I experienced with my Sabre. You don't have to worry about my fondness for this bird, I love the looks and the way she flies, I'd just like to fly her without having my throttle stick permanently buried at the 12 O'clock position.
                    I apologize for the delayed response, Hobbysquawk seems to have to have stopped sending me notifications. Thanks for your advice.
                    • Phantom
                      • Mar 2019
                      • 504
                      • M.D.
                      I hear what you are saying Gooniac, I am more than capable of flying her in the rollercoaster style, I just don't want to be locked in to only one style, she's capable of so much more.
                      The 1650kv it comes with didn't impress me on Merry Boozers flight, that video is the reason I purchased the ARF plus. The performance prior to the upgraded 1650kv was the reason this was one of the last jets I purchased from Motion.
                      • DCORSAIR
                        • 1918
                        • Selma, Ca.
                        DCORSAIR,
                        Ok, I understand the cost thing for sure, I bought the FMS 90mm 1900 kv after all the hype I heard about it and installed it in my F-15, I didn't see anything as far as performance, actually thought it was worse than the stock 1550 myself, then I went with the 1835 in the F-15 and loved it, so I put the FMS unit in the F-4 Phantom and the same thing, not much better than the stock 9 blade, so I went with the 1835kv in it as well, I didn't bother installing it in my F-16 after those results and it requires a little surgery to install the FMS unit and I didn't want to do that. I will be wanting to hear from you if you install this unit and see how you like it, I enjoy flying mine as is with the FW 1835kv and will keep it in there for now.
                        • Bellke
                          • 118
                          • AZ
                          Does anyone know what size the bullet connectors are on the original EDF that comes with the plane?
                          • Phantom
                            • Mar 2019
                            • 504
                            • M.D.
                            Ok so apparently in my passion for re-powering this bird I purchased an 8s 90mm from MRC. As it is the first one to arrive it gets first dibs. It's the 90mm, 12 blade, 4075-1390kv inrunner I believe it's the same one out of the 8s YAK-130. My question is what it's the second servo connector coming off the hobbywing ESC for? The short one?
                            • Skyboom
                              Foam flyer
                              • Nov 2018
                              • 344
                              • Chilliwack, British Columbia, Canada
                              It's saying it's for a programming cable. I've never used one before. Hope it helps.
                              • PaulZ
                                Crashing less
                                • 279
                                • DFW Area
                                The extra lead is for attaching the Hobbywing programming card to change ESC settings. I would advice to check these settings before you fly as you don't know what they are set to in the factory. Most important is timing, these motors work best with "medium" timing setting. The rpm of the motors change with with different timing. I am curious how the model will perform with 8s? I found that the 1835kv 6s setup was the best compromise between weight and thrust.
                                • Phantom
                                  • Mar 2019
                                  • 504
                                  • M.D.
                                  Thanks for the responses guys, I absolutely hate programming ESC's but let me see if I have a hobbywing esc programming card around here. PaulZ, why do you advise medium timing? In other words what are the negative effects of using high or low timing. My programming of ESC's usually consists of setting the throttle limits on initial start up lol.
                                  • Phantom
                                    • Mar 2019
                                    • 504
                                    • M.D.
                                    Got one, what's your recommendation on the programming?
                                    • Phantom
                                      • Mar 2019
                                      • 504
                                      • M.D.
                                      I'm thinking
                                      brake-off
                                      Batt type-Li-xx, (obviously)
                                      cut off type-soft cut
                                      cut off voltage-low
                                      start mode-normal
                                      timing-middle, (per your suggestion)
                                      Music - don't care
                                      Reserved item- have no idea what this is it has an option 1 and option 2
                                      Your input is appreciated
                                      • PaulZ
                                        Crashing less
                                        • 279
                                        • DFW Area
                                        I'm thinking
                                        brake-off
                                        cut off voltage-low
                                        start mode-normal
                                        Music - don't care
                                        That looks like the right settings. I confess I am not an expert on timing settings but I noticed that all the Freewing PNP models come setup on medium which is actually "auto" where the ESC figures out best timing for the motor. I had a friend set timing to high once on a 90mm jet to test and yes the thrust was a bit higher but it drained his battery so fast he LVC'd in the air and had to land after just a 2min flight. Maybe someone here can explain the timing issue better?
                                        • e4dragongunner
                                          Living the dream!
                                          • 876
                                          • Arlington Heights Il.
                                          Just stuck this same 8S set up in my ARF FW F-15
