  • Markopolo
    • Aug 2020
    • 5
    Guys I just got the 90mm high performance F-16, I have the 70mm but don’t need to use flaperons. Is it advisable to use them on the 90mm or does it not make that much of a difference.
    I fly on a proper runway with plenty of room and have several other 90mm edfs that come in hot.
      • 8202
      Flaperons are helpful for those of us who fly on shorter runways but if you have plenty of runway I wouldn't worry about it.
      • DCORSAIR
        • 1918
        • Selma, Ca.
        The F-16 needs room to land that's for sure, but it can be slowed way down for a short landing roll out once you learn how it likes to land, get the flare just right and you can hold it off as the speed bleeds off for a nice touchdown, I have flown well over a 150 flights with the F-16, be surprised how short it can land.
        • gooniac33
          The Original Gooniac
          • Jun 2016
          • 1047
          Proper landing attitude is really important with the F-16. It needs to be pitched up slightly to create the drag needed to slow down or it will come in really hot. The full scale uses flaperons but with the models I found them not to work as well. I prefer using spoilerons (reflex or slightly up) on planes that require a high alpha type landing because it helps with getting the nose pitched up for drag but then also keeps the model from being prone to stalling like flaperons tend to do. I don't have them programmed in mine because I don't have enough channels to do it on this one. It has worked wonderfully on other F-16s and the F-35 as well.
          This is my take on it but there are several way to do it. This is just what has worked for me.
          • gooniac33
            • Jun 2016
            • 1047
            Originally posted by DCORSAIR
            The F-16 needs room to land that's for sure, but it can be slowed way down for a short landing roll out once you learn how it likes to land, get the flare just right and you can hold it off as the speed bleeds off for a nice touchdown, I have flown well in over a 150 flights with F-16, be surprised how short it can land.
            YESSS!! Its cool to get that perfect landing with this bird. I just try not to flare and fly it to the ground....
            • DCORSAIR
              • 1918
              • Selma, Ca.
              Really, not me, I flare early and ride it in high AOA with throttle, I mean I have done some really slow landings, I fly it stock with no mixes at all and CG at 118, but I have flown it to the runway as well and it all works great actually.....
              • Cape Jets
                Member- Jet Jockey
                • Dec 2020
                • 120
                • Cape Cod, MA
                Getting ready to start my build on the 90mm - F-16 Thunderbird. I want to run a sound card (MrRCSound V4.1) and it also has the afterburners. What do you guys suggest to use for a 1S or 2 s battery to supply power to the sound card? I will use the balance port on the 6S to use for power to the afterburner.
                • gooniac33
                  • Jun 2016
                  • 1047
                  Flew mine again this past weekend. So much fun with the new FMS 1500kv 8s set up! Was able to get some decent landings with it too! The gear on this plane are s thing of beauty!
                    • 2690
                    Depends on the voltage requirements of the sound card, usually 2S to 6S, but on my prop warbirds I use a minimum 2S jst connection, usually just solder jst connection to the main 6S pack. Also installed an AB in my F16 that works in addition to the factory ring burner. For that I use a 450mah 2S. But I'm using an 8000 mah 6S main pack in my F16 with the 12 blade inrunner. Get over 5 minutes of flight time on that battery and about 25-30 minutes for the AB 450 mah battery. The factory ring AB I left powered thru the main battery. Adjust as required depending on flight times and throttle position you set the additional AB to ignite. I have the ring starting at 50% throttle and the cone LED AB ignition at 35 %, but then I like a lot of fire up my .......
                    • Cape Jets
                      Member- Jet Jockey
                      • Dec 2020
                      • 120
                      • Cape Cod, MA
                      Answered my own question. Seems the afterburner that comes on the F-16 only needs throttle input, no need for a power source. So will have the open balance lead on the 6S to give the sound card power.
                      • Cape Jets
                        Member- Jet Jockey
                        • Dec 2020
                        • 120
                        • Cape Cod, MA
                        Spoilerons make sense to keep the nose up. What mm up do you have yours set at for landing?
                        • gooniac33
                          • Jun 2016
                          • 1047
                          it doesn't take much. 2-3mm max... it takes some fiddling to get right since you may also need to use elevator compensation as well. Totally worth it thought when you get it right!
                            • 2690
                            gooniac33 and Cape Jets the concept of spoilerons is intriguing to me, but have to admit I had no idea what that was until I looked it up.
                            I've set up my F16 with flaperons primarily to get off grass quicker and have finally gotten somewhat proficient at landing with the nose up, but there is a fine line in stall speed.
                            If I try spoilerons for landing, would I just set the 3rd flap position (switch position 2) to something like 2% +, assuming flaps up 0 position is at 0% and take off flaps position 1 is -8%? I seem to remember that my elevator comp on take off flaps is up elevator and slighly more for landing flaps. Would the spoileron compesation for landing then actually be slight down elevator? And you're saying the surfaces should deflect up only slightly at say 2-3 mm, correct? I do have my gyro gains substantially higher for takeoff and landing flaps, but if I use spoilerons for landing I suspect I'll have to change the FM switch in my as3x rx for gains from Aux 1 (flaps) to the 2 position gear switch as moving landing flaps back up above 0 position will cause the gains to go back to the same as flaps up.
                            This might also work well on the SU-30 pig. I've put the older 7 channel as3x in it to use flaperons (again primarily for grass take-offs) while still keeping the air brake. She's tough to keep the nose up on landings, especially with the air brake, and stalls at the drop of a hat, even though it still seems to be coming in hot.
                            You're thoughts would be much appreciated. Although setting it up correctly and getting it right might be like asking a cave man to perform brain surgery. Hey, what coud possibly go wrong?
                            • gooniac33
                              • Jun 2016
                              • 1047
                              I think that the proper word is reflex... which is when the wing surface goes up slightly.I have had the best luck using them with my super slippery pylon racer. It would not slow down at all unless I was able to get it into a draggy configuration. using a slight amount of reflex did that and made it manageable on landing. When I land my F-16 I always pitch it up into a draggy high alpha attitude to get it to slow down. Adding in reflex has helped on a couple EDF models as well. I think that what you are mentioning will work pretty good. I have seen others do it with them but haven't actually done it myself with this one. Having a switch that will do both like you mention should work pretty good! reflex has also lessened the tendency to drop a wing when the plane gets slow too. Flaperons tend to get kinda tippy at times from what I have noticed...
                                • 2690
                                Thanks gooniac33 , appreciate it. I may try this first on the SU-30 as I think I'm comfortable with the F-16 landing nose up with flaperons for the time being. The Su-30 on the other hand is always a hit or miss on landing. Half the time I got the exact right speed and the nose up, the other half more of a 3 point landing seeming a bit hot. Then there's the occasional looks like a perfect nose up landing 3 feet off the deck but then a quick drop down the last couple feet as I hit the stall speed. Those are the ones that piss me off.
                                • DCORSAIR
                                  • 1918
                                  • Selma, Ca.
                                  I have flown many flights with the F-16, it flies awesome as is, never got it to drop a wing that's for sure, it just quits flying and drops, one time I got way to slow on final and it stood on it's tail, had very little aileron authority so I had to use rudder to steer it, then I gently added in power as it pulled itself out of it, wheeew that was close, I changed my undies after that...
                                  • Icarus the 2nd
                                    • Aug 2018
                                    • 164
                                    • Pajottenland, Belgium
                                    Hi all, here's a short vid of one of my clubmembers flying his F-16 90mm (all stock 6S inrunner version).
                                    Vid was recorded in September 2020.
                                    • e4dragongunner
                                      Living the dream!
                                      • 876
                                      • Arlington Heights Il.
                                      Nice Flight man!
                                        • 2690
                                        Me love my F16! Nice flight and landing. I assume that's with the new 9 blade inrunner. I put the 12 blade iinrunner in mine and it flies great, even with a Hobbystar 8000 mah battery, getting 5 minutes of flight time. Whoopi!!!!
                                          • 8202
                                          Gotta love a greaser!
