  • t33jetman
    • 515
ID:	251916Click image for larger version
ID:	251917Click image for larger version
ID:	251918Click image for larger version
      Originally posted by t33jetman
      Click image for larger version  Name:	69799711_2301106643257996_5982376405189525504_n.jpg Views:	0 Size:	147.3 KB ID:	251916Click image for larger version  Name:	94504798_2776575252377797_4508796413244604416_o.jpg Views:	0 Size:	98.5 KB ID:	251917Click image for larger version  Name:	94220720_2782266828475306_2678323828915961856_o.jpg Views:	0 Size:	111.9 KB ID:	251918Click image for larger version  Name:	92860923_2756489144386408_4243804490223845376_o.jpg Views:	0 Size:	115.7 KB ID:	251919
      Looks great!! I still do a lot of "old school" mods with Styrene, Epoxy Putty, Basswood and such although I am designing more 3D printed stuff. No where near the level of Elbee, Dirty Dee or apmech1 but I am getting better. Hey, whatever it takes.
        • 4856
        t33jetman, Your antennae are perfect, T33 and RCjetdude, I like your 'old school' work, sometimes that's the only way to get it right. Best, LB
        • RCRT2018
          • 8
          • Ft. Worth, TX
          t33jetman or anyone else that might know. I want to redo the antennas with styrene that might be a little thicker. What thickness is advisable to use?
          • t33jetman
            • 515
            I use credit cards for my antennas and a small brass pipe for my exhaust. Click image for larger version
ID:	252713Click image for larger version
ID:	252714Click image for larger version
ID:	252715Click image for larger version
            • RCRT2018
              • 8
              • Ft. Worth, TX
              Thank you, I never would have thought of that.
                I did mine in .06"/1.5mm Styrene.
                • t33jetman
                  • 515
                  The middle one is a pipe.
                  • sam51401
                    • 368
                    • Sellersburg IN
                    Yep, it's the fuel dump
                    • sam51401
                      • 368
                      • Sellersburg IN
                      Crap, great idea on using a credit card as I just cut one up to throw away. I guess I could cut up another, it would make the wife happy:face_with_hand_over
                      • RCRT2018
                        • 8
                        • Ft. Worth, TX
                        Jetman, what was the size of the pipe you used for the fuel dump?
                        • t33jetman
                          • 515
                          You wont like this , but I just took a round brass tube and flattened to shape it to an oval by eye balling it to size with the antenna , the cut it on the bandsaw.
                          Click image for larger version  Name:	20200502_214627.jpg Views:	0 Size:	120.4 KB ID:	252773
                            Yep, I knew that, but I'm not as ambitious as you. But at least it's in the right spot.
                            • BobinAZ
                              Older than dirt
                              • Oct 2015
                              • 12
                              • Phoenix, AZ
                              Excellent!
                              • 1rcflydog
                                Can anybody send me a copy or a PDF file of the decal placement sheet for my A-10 I would appreciate it
                                  Replied on the RCG thread as well. Here it is:
                                  https://cdn.shopify.com/s/files/1/10...cal_Layout.pdf
                                  • Lon
                                    • Jul 2014
                                    • 1202
                                    • Miles, Iowa
                                    This Covid virus must be effecting me....I was always so happy with the stock power system in my A-10. I just finished installing and flying her with the Freewing 1857kw inrunner 12 blade power system. First thing I noticed was the sound. Less motor whine sound. And I was very happy with the vertical power improvement. Increase in top end speed not real significant, but noticed. Click image for larger version
Name:	DSC04238 - Copy (1024x681).jpg
                                    Lon
                                    • Dirk.S
                                      Pilot
                                      • May 2019
                                      • 15
                                      • Sydney, Australia
                                      Has anyone tried the FMS 80mm fans as an upgrade from stock?
                                      • MikeT
                                        Here......Hold my beer.
                                        • 1060
                                        Is there something wrong with the stock one's? They seem to work just fine.
                                        Mike
                                        • Warthog
                                          • Feb 2020
                                          • 119
                                          • Crockett, TX.
                                          I haven't had mine for very long, but one thing I noticed was a better "Jet" sound. I talked with a tech at MRC before I bought mine, and he did say there is a big difference in performance over the 80mm 9 blade EDFs. I also installed 130 amp ESCs and all 10 awg wire. I'll post when I get more stick time with it.
