Freewing 80mm A-10 Modifications
  • RCjetdude, thanks for documenting your modifications and making this thread, your plane is extremely well done!
    I just started assembling mine last night and am planning on doing the euro green scheme as well. do you have the paint codes for the colors you got from lowes, or can they make the paint based on FS numbers?
    I'm also planning on CADing up various detail items for 3D printing, so I'll post those on this thread so others can print them for their hogs too.
    • Thank you DD. The paint I actually used came from Ace Hardware but when I get home I will see if I can find the color swatches they matched it to.
      • Click image for larger version  Name:	 Views:	2 Size:	79.4 KB ID:	91955Click image for larger version  Name:	 Views:	2 Size:	90.8 KB ID:	91956 I used Model Master Enamels both the gray and green were rattle cans and the Euro Green was bottles I shot thru a airbrush.Painted right over the original grey. I've got the numbers if your interested.
        Mike
        • I based my paints off of the Model Masters FS36081, FS34102 and FS34079 but to me there wasn't enough difference between the two greens. ACE tried to color match the samples I gave them but in the end I selected some color swatches that were to my liking and I cannot find those color swatches now. Sorry. I looked at so many pictures of real Euro Green A-10's and they all varied because of lighting so I just picked something close to what I was after.
          I spent some time this evening working on a drop tank.
          • Love the drop tank!
            • Originally posted by MikeT View Post
              Mike
              Thanks for the offer Mike, but I'm looking to stick with latex paint for this repaint. BTW, your Euro hog turned out great too!
              • Originally posted by RCjetdude View Post
                Thanks looks awesome.
                Mike
                • Originally posted by Dirty Dee View Post
                  No worries.
                  Mike
                    Go to home depot with the FS numbers you want.....they can mix them from their database
                    • Got more done on the centerline drop tank. Mounting brackets are installed and made the hard point for it. Applied first coat if primer and some filler.
                      • Where did you get the centreline tank from? It will look great when it's flying by.
                        • Now you just need to throw several thousand milliamps in it to extend your flights
                          • Originally posted by sam51401 View Post
                            A friends using 2 of the HRB 6S 6000ma 50C and getting almost 5 minutes.
                            Mike
                            • Originally posted by slamdance64 View Post
                              I am making it from a couple rocket nose cones, a section of rocket body tube, part of a 90mm F-16 drop tank and 0.040" styrene sheet for the fins.
                              • Gray primer, ready for paint.
                                For size reference
                                • Looks awesome Steve!
                                  Found out a friend lost his Hog recently and he has spare parts. I'm asking for some of his ordnance to get the mounting tabs to fab the rails. In return I would
                                  upgrade a few for him to hang on his replacement Hog. I'm looking at making JDams from the the plain Jane mk83's and some scratch built Mavs
                                    Mike
                                    Let us hear how they hold up. I bought a set to test out also then also placed an order to Andy for two sets of the RT 6250's. Could be a possible alternate battery if they don't start dropping cells.
                                      There you go. I have dug those things out of the ordnance from crashed planes as well. Recycling.... I will get you details on the rails shortly.
                                        Has this been a problem with the RT batteries? I only have one 3s2200 25c and it's been a good battery so far.
                                        • I am referring to the eBay batteries not Andy's. The Roaring Tops are leaps ahead in the quality department over the HRB. Only time and fellow postings will tell the tail on the HRB.
