    • 4878
    Originally posted by thmprusmc
    The latest update on my build.
    TMPR, Beautiful work, Sir. Best, LB
    • RC30Flyer
      • Aug 2013
      • 60
      So today I had a pretty bouncy landing... nose gear and one of the mains feels like the struts are loosey goosey. Is there any way of tightening these up?
      • Bobaroo
        If it Ain't Right on the Ground...
        • Dec 2017
        • 327
        • Newburgh, IN
        Mine got Hammered and Hog'd out from some Gravel Strip Operations. Always had to mess with them. The Struts are rather Long and with the aircraft weight, I find keeping all the Landing Gear Parts together and Tight a real challenge on this one. I've purchased 'Spares' for the NoseGear stuff but honestly, the Mains could use a different Strut assembly (More Robust). One of these days I'll get around to it. GL
        • RC30Flyer
          • Aug 2013
          • 60
          So, I was advised to change the CG from 180mm to 190mm... man what a difference. She lands a lot slower and more predictable, even tho the landing in the video doesn't show it, it was getting dark and I couldn't see very well on the last landing.
          • Topshot19
            Pilot
            • 189
            • logan utah
            I’ll I know is that I had to put 2 weight bars in my nose to get her to cg
            • GBLynden
              • 198
              • Lynden, WA
              Awesome flight! Which batteries are you guys using in this beautiful jet?
              • sheva99999
                • May 2019
                • 3
                Has anyone tried this jet on 8s??
                Wondering if it is not too heavy a wing loading?
                • scootergenie
                  Jet lover
                  • 261
                  • Stuart FL.
                  I'm going with 6s because I fly off of grass, and want to keep it as light as possible. But if I had access to a paved runway, I would try 8s. There's plenty of room inside to shift battery weight around.
                  • sheva99999
                    • May 2019
                    • 3
                    Yes, Our field has a paved runway. So it will go off pavement. Just wasn't sure if the 8's would make it too heavy. Clearly I will get more umph!! but don't want the landings to be impossible to execute.
                    • apmech1
                      Warbirds old and new
                      • 266
                      • CVG Airport, Kentucky
                      Did my maiden and second flight. All I have to say is wow. This plane flies so well! Stock 6s setup. It seems to have gobs of power. As everyone else has pointed out the roll rate is crazy. I got video with my soloshot 3. No aerobatics, just bomber patterns so far.
                      • GBLynden
                        • 198
                        • Lynden, WA
                        https://youtu.be/pNFRUr4lYhI
                        Good stuff! Which packs were you using and what are your settings?
                        • apmech1
                          • 266
                          Thanks. Admiral 6s 50c. The short flight was the maiden, 2 circuits and then down. The second flight I flew until my battery capacity warning of 2500mah (50%). I use the e-fuel gauge, It is awesome. My flight time I believe is just under 4 minutes. As I get used to the approaches better, I will probably set the alarm @2750mah.
                          Cg was where the manual called for 180. All controlls were low rate, 75% of manual full deflection. I was using 50 % expo. . I am going to move ailerons down to 60% throw and decrease all expo to 35%.
                          • RC30Flyer
                            • Aug 2013
                            • 60
                            Thanks GB... I'm using the Admiral Carbon 6S 5100mah 70C
                            • RichJ53
                              • Nov 2018
                              • 342
                              • Southern Oregon
                              Hi Guys,
                              This winter I built many of my MRC airplanes and the A4 was one of the first projects. So much fun to build and the waterslide decals (lots of them) were easy to work with. Actually I have not applied waterslide decals in a long time. nice plane to build and went together easily.
                              So today, I did the maiden flight using my Thunder power 5000 6S packs which are about 60 to 90grams heavier than the MRC new Admiral batteries. I put the pack back 1/4" behind the front edge of the plywood that gave me the CG slightly aft of the normal call out.
                              The plane flew beautifully on low rates with lots of power. very agile and quick to turn. Rolls were fast and predictable. Full flap landings were spot on with high Alpha flares. So much fun and reminds me of my old Byron Originals A4 just slightly smaller scale. Great plane and good job by MRC and Alpha to bring this plane to us with great scale fidelity. One of the club members shot some videos of my flights but I did not get them yet. Hopefully I will post them once I see them for myself :)
                              I highly recommend this jet to anyone with some EDF flying time
                              Rich
                              Click image for larger version  Name:	IMG_2810.jpg Views:	0 Size:	198.3 KB ID:	195369Click image for larger version  Name:	IMG_2811.jpg Views:	0 Size:	336.1 KB ID:	195370
                                Hello fellow Oregonian! The A-4 is a sweetheart and I love flying it. One of my favs.
                                • Topshot19
                                  Pilot
                                  • 189
                                  • logan utah
                                  I have always had a really hard time with this jet.
                                  • RichJ53
                                    • Nov 2018
                                    • 342
                                    • Southern Oregon
                                    Hello and right back at you.
                                    I agree this jet will be one of my favorites..... I flew my L39 first after reading all of the hype and watching the videos. Yes the L39 flies great too, but the A4 is sweet and agile
                                    All the best
                                    Rich
                                    • themudduck
                                      -TMD- Foaming at the Mouth!
                                      • 1041
                                      • Burton OH (near Cleveland)
                                      Try dialing down the control throws a LOT, especially for the ailerons. Plus use expo as well. Its much happier that way IMHO.
                                      (With the original throws, mine was sensitive as hell and rolled so fast it was like a freaking drill bit - and after about 3 or 4 revs it actually induced a snap roll! Or that may have been because I touched the elevator :Cool:)
                                      • RichJ53
                                        • Nov 2018
                                        • 342
                                        • Southern Oregon
                                        So, this jet needs an second chance :) Try turning down your rates and adding some more Expo My Aileron low rate is 60% and 30% Expo plus the expo can be turned up even more depending on your flying style.
                                        all the best
                                        Rich
                                        • GBLynden
                                          • 198
                                          • Lynden, WA
                                          Originally posted by RichJ53
                                          Hi Guys,
                                          Rich
                                          Looking good and I love the stand! I am not quite in Oregon, but I am from the PNW too :D
