Official Freewing 70mm BAe Hawk T1 Thread
    Yep, it will!!Minwax, Spar Varathane water based is the way to go!
    Before Click image for larger version
    After Click image for larger version
    Dan, did you apply it before or after applying the graphics?
    • xplaneguy
      Clear Skies and Contrails
      • 558
      • Edwards AFB/Rosamond, CA
      Freewing 70mm Hawks at the Arizona Jet Rally 2017.
        • 7337
        After Steve, it helps to lock on the decals. Decals on bare airplane and then three or four coats of Varathane.
        • hotrod23t
          jim jets
          • Nov 2017
          • 312
          • EUSTIS FL.
          hello all new to site thought i would post a pic of my BAe Hawk my version of arctic camo
          • vdanger
            Major Danger
            • 144
            • Oswego, Il
            Wow that is impressive! Youve obviously put a lot of time into it.
            Is that some sort of decal paper with the camo pattern on it?
            I highly suggest you read my post #313 over on the rcgroups forum.
            Super Airliner, Corsair, Viper, BAE Hawk, L-39, A-6, PC-21, B-25, T-28, GeeBee, Wildcat, Stinson, F-16, F-4
            • GregC540i
              • Nov 2017
              • 38
              Great work! Love the details of the pilots and the cockpit! Nice Middle Finger!!!! hahahaha
              • hotrod23t
                jim jets
                • Nov 2017
                • 312
                • EUSTIS FL.
Name:
ID:	104435Click image for larger version
Name:
ID:	104436Click image for larger version
Name:
ID:	104438Click image for larger version
Name:
ID:	104437 a couple pics with belly tank from the green rectangle
                • moxjett
                  Pug Pilot
                  • 4
                  • Wichita, KS
                  Finished up my Grey Hawk this evening. Looking forward to it's possible maiden this weekend.
                    I like the colors! No graphics?
                    • moxjett
                      Pug Pilot
                      • 4
                      • Wichita, KS
                      None yet. Looking to see how the graphics that come with it look, or get something else for it. I might look into getting some graphics from some of the other jets, like the Freewing 70mm F-16.
                      • hotrod23t
                        jim jets
                        • Nov 2017
                        • 312
                        • EUSTIS FL.
                        I like the paint hope it flies as good as it looks. i used left over decals for mine
                        • moxjett
                          Pug Pilot
                          • 4
                          • Wichita, KS
                          Have you made the suggested mods to reinforce the front fuselage from coming off during a hard landing hotrod23t? I plan to reinforce mine before I maiden it. Weather has been cold and windy here, so I'll have time to do it before I get a chance to maiden it.
                          • hotrod23t
                            jim jets
                            • Nov 2017
                            • 312
                            • EUSTIS FL.
                            put carbon fiber rods in my t45 saved my fuse a couple times will probly do the same to this one but it lands nice
                            • hotrod23t
                              jim jets
                              • Nov 2017
                              • 312
                              • EUSTIS FL.
                              thanks for the link .looks like i got some work to do before my next flight
                              • hotrod23t
                                jim jets
                                • Nov 2017
                                • 312
                                • EUSTIS FL.
                                this is my souloution 1 mm thick plastic epoxied in place with gorilla glue filling gaps holes drilled in plactic for adheasion back also pinched between fuse and wing
                                • hotrod23t
                                  jim jets
                                  • Nov 2017
                                  • 312
                                  • EUSTIS FL.
                                  had too do some trimming of plastic too fit wing... but VERY STRONG
                                  • hotrod23t
                                    jim jets
                                    • Nov 2017
                                    • 312
                                    • EUSTIS FL.
                                    THATS A FUNNY LOOKIN BLUE JET AT THE TOP OF THIS THREAD THE PAINT MAKES IT LOOK LIKE A PROP PLANE WHERE DO I BUY THIS LOL:):):)
                                    • vdanger
                                      Major Danger
                                      • 144
                                      • Oswego, Il
                                      Running that doubler all the way forward to the second rib in the cockpit (last picture) is really a good idea. Will make it a lot stronger.
                                      • hotrod23t
                                        jim jets
                                        • Nov 2017
                                        • 312
                                        • EUSTIS FL.
                                        PIC O THE DAY
                                        • Ron1950
                                          Retired ATC
                                          • Oct 2015
                                          • 887
                                          • brandon ms
                                          gorilla glue will make it stronger then stock (that is if they used glue in the first place)
