Freewing A-4 Blue Angels Conversion
  • e4dragongunner
    Living the dream!
    • 876
    • Arlington Heights Il.
    1st Rate Expert work!!!! the work for the gear doors on the mains is wonderful! Totally Tempted to by a second one! But alas I need an F-14 and a A 10 and 10 more 6S Batteries
      Got the refueling probe sorted out. It looks much better. It is easy to bend with the help of a heat gun but you gotta be careful not to over heat it.
        This is just a dry run as the main wheel doors are merely taped on to get a quick visual on it. So far so good.
        Click image for larger version  Name:	20171012_232125.jpg Views:	1 Size:	106.8 KB ID:	100278
        I replaced the nose wheel with the slightly smaller one from the 90mm F-16. I wish my strobes would hurry up. They are currently on back order.
          Man, those gear doors look sweet!
          • Boots Whirlygig
            • 560
            • Granville Ohio USA
            Are those brass hinges on the nose gear door?
              Thanks Pat! Yes Boots, they are narrow brass piano hinges. Gonna give 'em a try.
                I hear ya'... I have a priority list as well and thanks! although, I wouldn't call it expert work. I am just muddling my way through it.
                  Not much to report tonight... I got one set of main doors hinged and ran out of hinges. Will get more tomorrow.
                  I also worked with Callie to make some corrections to her Blue Angels graphics, mostly sizing issues, and things like adding the McDonnell Douglas logo and changing the badge to have A-4's on it instead of F-18's.
                    YOU GO STEVO :Cool:
                      We'll get higher and higher straight up we'll climb.... we'll get....sorry. I got a little lost in thought there for a moment.
                        Got the nose gear door functioning so it is basically done. Next up will be to get the main gear doors working together which could be tricky. We shall see....
                        • bill34207
                          Jet Junkie
                          • 455
                          • Bradenton, Florida
                          That is looking really good. More detail work than I'm willing to do but I do admire what you are doing.
                            Thanks Bill. I am part crazy and part glutton for punishment LOL
                            Quite the glorious sight.
                            On a side note, I got the JHH Mk. 82 bombs today for my Green Knights. That will probably be about a week or more worth of work to put 12 of those puppies together and make the MER's. Should look awesome when done though.
                              Main gear doors closing. Now to work on the opening part...
                              I am totally winging this as I go so it has changed several times already.
                                Of course it has to have an operational arresting hook.
                                Click image for larger version  Name:	20171016_192355.jpg Views:	1 Size:	80.4 KB ID:	100692
                                Click image for larger version  Name:	20171016_192405.jpg Views:	1 Size:	113.2 KB ID:	100693
                                I will hook it up soon.
                                • Topshot19
                                  Pilot
                                  • 189
                                  • logan utah
                                  This means you have to do a string system on the runway now to stop it
                                    That would be cool but.....
                                      • 7383
                                      Looks great Steve, you're an amazing talent!!
                                        Thanks Dan. Not amazing enough to keep monkeying around with trying to get the main doors to open without servos. I am wanting to move on to finishing and painting so I am throwing in the towel, waiving the white flag and will work the mains doors with servos. I will try to make them work with just one for each set of doors to start. I ordered some 9g servos and a gear door sequencer so I will have more to post soon. Not to get side-tracked but I traded with George and got this from him.
                                        He has already installed better fans, ESC's, retracts and servos. I am going to quickly install a receiver and get it set up to hopefully fly at a Halloween Fun Fly this Saturday. Heck with the TV and the drag shute. Should be interesting.
                                        • Boots Whirlygig
                                          • 560
                                          The SU-47?!?? Just in time for Halloween! That’s one scary looking machine! Better open a new thread, we’ll all want to know more!
