Dan,
Looks like it has seen many Indian fights and dropped on many Bordello floors. Wonder what the Pony Express rider looks like, and his horse?
Glad it finally made it, gives me hope in our federal gov't using our money wisely. LOL!
RexLeave a comment:
Thanks, I have done a TON of these R2800 wiring harnesses! Any questions, let me know.
You can see what the Corsair V3 prop looks like on this airplane. The differences are distinct and impressive when compared to the OEM prop from FMS. Still, I think doing your initial maiden and testing with the plane is good to do with the OEM prop, which I think you said you were going to do. Then you'll be ready for the bigger prop, which is not a big deal.
Best,
DavegeeLeave a comment:
Davegee,
That is what I will try to do when I get to detailing the engine. Yours look real.
Best Regards, RexLeave a comment:
I have been using the technique of photo copying the OEM cylinders for many years and then cut to fit paper copies in the gaps to give the impression of cylinders behind and in between the front row of 9 cylinders. Regarding the wiring harness for this engine, there were several different types and colors of them around the crankcase, but in all instances, at each point where a sparkplug wire comes out of the harness, it is paired with another wire that goes over the top of the cylinder and attaches to the other sparkplug (made to look like that for these models) on the back of each cylinder head. Ends up being a lot of wires but it looks pretty cool, even for a foamie. That's just my take on how I do them. Ignition wires varied from black to silver to gold, and probably others, too. Here is what I did with my FMS P-47D Penrod and Sam. The Corsair, Hellcat, and P-47 all used the same R2800 P&W engine, so they are all pretty similar.Grossman56
photocopying the back row is a stoke of genius, but no, I printed 3 separate parts: a thin back section, center section and front section.
Glued those together with thin CA.
I painted parts as needed for assembly and then added the plug wire detail.
The tricky part was cutting back the foam to accommodate the depth of the P&W Model.
I had to cut back the motor mount and design a stiffener to reinforce the mount to the foam.
This had to stay square to the world while not change the thrust angles built into the OEM design.
This might have been over-kill as they say, but for me, I was in uncharted lands and wanted all to be solid.
In the end, it all worked out and was worth the effort, I think.
Best, LB
I recall, the work you put in is almost as difficult as restoring the real thing!
Dave came up with the idea of taking a picture adjusting it to size (which was very simple in Adobe Elements) and cocking the picture one cylinder over and gluing it in. Once in position, a bit of carving on the paper, which ends up looking like an inner tube, and there's your back row of cylinders.
Reassembled the old girl to see how 'salty' she looked. A couple of palm trees in the back and she's good.
My salty marine!
(Dangerous Dan)Leave a comment:
Best, LB
6 PhotosLeave a comment:
Looks Great!
Did you photo copy the back cylinders or was that a 3D print as well?
At any rate, the result is very realistic.
Grossman56 (Dangerous Dan)Leave a comment:
Good work on that prop! It looks like something that was exposed to the elements in the Pacific Theater for a while!Picked up some paint and materials today and got at it again. Did the aging on the prop, it looks wicked!
Started in on the motor upgrading (painting) as well.
Have to dig up some wire and start on a harness as well. I'll use this pic to try and photo copy a rear set of cylinders.
BTW, I watched some vids on resin printers. HOLY CR*P!! it looks like something out of Star Trek where they create the Borg!
Just too bazaar!!
(Dangerous Dan)
Resin printing is a definite consideration for 3D printing. Elbee has one, and I have several friends who have them, too. I think I'll get one in time. You can get some extremely smooth prints for certain work. As Elbee said above, it has some drawbacks for modelers like brittleness and weight.
Cheers
Davegee
Thanks Elbee, just took your advice and downloaded the Prussa slicing program. Give me something to learn, keep the old geriatric brain functioning. As for the slicer, I was quite surprised at how reasonable the price was. Now to convince 'She who exceeds my rank' to think in the same vein
Meanwhile, I'm feeding Dave all the STL's. Just purchased to pilot bust for us and sent the file you forwarded to me for the Spitty cockpit. This sure has put new joy in modeling for me.
This might sound crazy, but is it possible to create an STL file for the wiring harness for the Corsair? Seems to my that would be on everyone's list.
Danger,Picked up some paint and materials today and got at it again. Did the aging on the prop, it looks wicked!
Just too bazaar!!
(Dangerous Dan)
Your detail work is simply great and quite realistic.
As for resin printers, don't over look the versatility of FDM Additive Manufacturing aka filament printers
Yes, Resin Prints are outstanding and the parts look top notch, but the material is inherently brittle, read, non-structural.
I could not have done the all of the mods to my Corsair with resin printed parts.
Detail parts, yes, such as the pilot's head and side panel skins, IP, but not the cowl flaps or sliding canopy parts, strut covers, etc.
Additionally, resin parts can be heavier if the parts have mass, like a pilot body.
There is realistic limit to thickness of the outer shell, typically 2mm, so depending the size, the weight penalties can be prohibitive.
There is place for both in this hobby, IMHO, and filament printing is cleaner and more cost-effective.
I did just receive a resin printer from Santa on Christmas morning and I am looking forward to printing some detail parts for my Desert Warrior B-25C.
I will post pictures when I get there, currently waiting on Amazon to deliver a new surge protector power strip (tomorrow).
Reviews will be welcome.
Best, LBLeave a comment:
Just too bazaar!!
(Dangerous Dan)
Sounds great, Rex! Can you PM me your mailing address? I'll send a complete hub, inner and outer parts, a Robart tire and instructions as to what the problem is. Should be an interesting project for the kids. If possible, once we have a solution, I'd like to have or buy the STL as I will probably have to print out several of these in the future, assuming we are able to address the problem with these wheels/tires combination. I'll report back to the kids the success or failure of this new design this spring, or whenever weather is good enough in these parts to do some testing of the hypothesis.Davegee,
I spoke with the industrial arts teacher Sunday at our indoor fly. You need to send me a hub with inst. on what you need modified and the class will be happy to design a new hub. He said they would measure everything and add modifications. We would have the STL for future needs.
Best Regards, Rex
Thanks so much!
