Feeling for you Hardway and Dwl.
Getting old does suck but it's better than the alternative. Some don't get to be old.
Boy, not one comment on my cockpit.
TomComment
Sorry about the no comment Tom and thanks for the kind words. Yes we're lucky to still be on the right side of the grass. Your cockpit looks great...nice detail. I've got everything to do my cockpit but haven't had the time. On top of everything else we just got a new puppy. Cute little mini aussie but she is turning our world upside down. Busy with the invisible dog fence and so on.Comment
I got a new insulin pump...$12,500. Every 3 months 1,500 out of pocket just for the stupid plastic pits to hook my self to the pump. Doesn't count insulin (300 a vial w/o insurance), test strips, etc. I'm only 31.Planes
-FMS: Bae Hawk Motion: 1.6m Corsair, 850mm Mustang, 1.6m Spitfire Freewing: 1.7m A-10, F-22,Comment
Nice! Love the Corsair. What a great canvas for weathering! :Cool:Finally have my cockpit in the Corsair...modified the 3D Pup files (scaled them down).
Only printed the head rest from the seat back. Also scaled up the seat.
Printed an image I found online for the gauges. Cut each gauge out and glued in place behind the inst panel.
Tom
PS: next stage will be weathering.Comment
DWL: We have a new puppy also. We got her when she was just 12 wks old. She's now 16 wks.
Ok, back to the Corsair. I'm about ready to do some weathering and maybe add cowl flaps. Undecided if I should use thin balsa or thermo plastic for them. Both can be curved but balsa wouldn't take much at all to break.
Since I need to remove the wing to load the plane in my vehicle it has to go on my stand. Thinking thermo plastic would take more abuse than balsa.
TomComment
I've done this before I made them out of ~.020 steel from McMaster carr. I bent the hinged edges over by clamping it in a vice, bending it over and burnishing a sharp corner with some scrap pine. you might have to rotate the jaws in the vice to make them stand above the vice so the second ear can be bent. then got a can about the size (now it would be plastic). filled it with expanding foam then put two slots in it to clear the ears and burnished it to the curvature I wanted. drilled the hinge holes then used one peace of .032 dia music wire through the ears of the flaps. connections to the fuse where between the flaps. used a nyrod to open ad shut them placed close to the hinge and also going through the hinge edges. the nyrod would expand as the engine got hot and the flaps would react.
JoePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9Comment
Good thinking. That may work on a plane with an IC engine. I'm not thinking it would work in this case.I've done this before I made them out of ~.020 steel from McMaster carr. I bent the hinged edges over by clamping it in a vice, bending it over and burnishing a sharp corner with some scrap pine. you might have to rotate the jaws in the vice to make them stand above the vice so the second ear can be bent. then got a can about the size (now it would be plastic). filled it with expanding foam then put two slots in it to clear the ears and burnished it to the curvature I wanted. drilled the hinge holes then used one peace of .032 dia music wire through the ears of the flaps. connections to the fuse where between the flaps. used a nyrod to open ad shut them placed close to the hinge and also going through the hinge edges. the nyrod would expand as the engine got hot and the flaps would react.
Joe
Don't think I'd go with operating cowl flaps, just partially open for the effect.
Tom
Before I install thermo plastic cowl flaps I'll do some homework. Namely painting the plastic dark blue and leaving it out in the hot Georgia sun to see if it will deform.
Tom
Can any of y’all tell me if this plane will fit in a mid sized ford suv fully constructed, a Ford Edge to be Specific.Comment
I have a Ford Flex which is pretty roomy but I have to angle her in to get her past a couple elements before I can sit her straight forward and back. Not sure how much room the Edge has compared to the Flex.
Although just looking at a photo of the back of the Edge it sure looks like it would fit, especially assuming those back seats fold down flat.
You know what? That may work.
I'll see if I can find something when I go to the recycling center this week.
Thanks for the idea.
TomComment
