  • Thanks OV10 and Hardway for your great advise, I always know I can count on you guys for the straight "dope" on these issues. Contacted Andrew at Motion, who is always very helpful, and he confirmed the same issues with the Gecko. Lesson learned, before trying out any new/differrent equipment, do your ressearch first. Andrew also said programming this ESC can be combersome, and since I'm not the brain surgeon most of you are, I'm not even going to mess with it. Ordered a Castle ESC and I'm done with ever trying a Gecko. Even Andrew said if it was him, just put the Castle in and don't mess with the reprogramming, sound advice. I have 6 Castles in other planes and love that ESC, don't know why I didn't just go with it to begin with, guess I just had a timing issue with my brain-anyone know how I can reprogram my brain or is it a lost cause.
    • Comment
      • I almost put a Castle Cremation in my Ryan, and this is why I did not - but I had several less than desirable concerns expressed from other club users prior to this event. This was the last straw. It went back in the box - never powered it up and went with a Hobbywing 100 instead of the Talon 90. Sold it and broke even. The first thing I saw at this crash was the CC unit. I watched the owner prepare the airplane on its 3rd flight, after all the normal checks and double checks, a fresh charged battery and range check. On the downwind leg of the second circuit from 300’ the airplane stopped responding, nosed down to about 60* and went straight into the desert floor. I was his spotter, maybe we got a bad batch - dunno, but none of our club members will use them and some units have even burned up on the ground.
        Just my $.02
        Click image for larger version  Name:	8E734483-3B23-48E8-A1C0-2D7A6E7AE006.jpeg Views:	0 Size:	420.3 KB ID:	213088
        • It used to be that Castle was THE go to ESC. Some people would revere them like bowing to a god. So I got one that was on sale. It was a 200A for less than 1/2 the retail price through a well known shop in one of the southern US states. That thing crapped out on the first test run and never worked again. When I now hear the word "Castle", it does nothing for me. I guess I can add "Gecko" to that short list.
          • I like the bubble top version but am concerned that the darker blue paint would gator in the New Zealand summer heat. Would be interested in comments from bubble top (and birdcage) owners about their experience over the summer regards gatoring?
            Cheers
            Mike
            • My bubble top has held up well over the Summer. Not that I have her out in direct sun and heat for long but in the times I have, it's been fine. The cockpit will be the first to bake and gator as is always the deal with all these foam cockpits.
                Sorry to hear that about Castle, I've had nothing but good luck with them (so far, oops, probably jinxed that). I have 5 of them in my Extreme Flight planes and one in by Beast 60 Bi-Plane and all have performed perfectly. Now putting one in the new F-16, so we'll see how that goes, but will never, ever, buy another Gecko because of the timing issues (maybe just my bad luck as others seem to have no problems-could be just with that EDF inrunner).
                • Originally posted by Monty500 View Post
                  Cheers
                  Mike
                  Keep it out of the direct sun Mike, I put a towel over mine and keep it in the shade as much as possible.
                  I store my foamies in a trailer which gets hot... the heat won't harm it, but leaving it out sitting in direct sun is no good. In addition to the direct sunlight "gatoring" the dark-painted foam when it heats it up, the UltraViolent rays (UV) will degrade and weaken the foam over time. A lot of us here have had success using a clear-coat (like a foam-safe polyurethane) to help protect the foam from the nasty sun.
                  • Originally posted by RCAV8R View Post
                    Hey Guys...I only had 16 flights on my Corsair from when I first bought it back in May and was out with it today, enjoying some new batteries and getting to know the plane again. I had five great flights in and was just finishing up the sixth and final flight after a couple of touch and go's. I turned on final with gear and full flaps deployed, and sensed things were feeling mushy. I added throttle, but felt like there wasn't anything happening. As it slowed and the wings began to wobble I was still adding more power and trying to correct with ailerons, but felt nothing. It went into a spin that I couldn't recover from. As much as I would love to blame it on something, I couldn't find anything mechanical to suspect. The receiver light was solid, the battery had 30+% left, all the control surfaces were working (except the elevator, which was unplugged and I'll never know if that happened before or after), and my transmitter had plenty of charge. It is a total loss, and to add insult to injury, the brand new battery is toast as well.
                    So, my personal lessons learned are: 1) do not deploy full flaps until on final, 2) add more power while turning to final as a rule (especially on the Corsair), 3) read a reminder in my pre-flight book on every trip to the airfield, reminding myself when in an emergency to always drop the throttle completely and bring it back up (just in case there is a brown-out). That wasn't the case here, but I kicked myself for not doing that procedure instinctively! So this was my first crash in 3 years and 3 months...it still hurts, but I guess nobody gets away completely unscathed. It's an awesome bird and no doubt she will be replaced in the hanger! Rob
                    first let me say I have gotten behind the power curve on this plane several times. I add throttle, again and again and it slows the decent but not as fast as I would expect and in each case it lands on the wheels and roles out fine. but I know I was behind the power curve.
                    my son and I carry a 4.8-5.2v back up battery on all our planes 5# and up. he had an engine out last month, brought the plane in and we found the problem and fixed it. but in down loading the motor/esc flight data it had 18 separate flight entry's for that 2.5minute flight. had he not had the back up battery the first of those 18 restarts would have ended the plane.
                    Joe
                      Cheers
                      Mike
                      Aros and Mudduck thanks for your comments. I have a beach style sunshade that I use on sunny days as the UV levels here in NZ are very high. As you say Aros its the cockpits that seem to suffer the most. Several of mine with black cockpits like the Stinger 90, A4 and Rebel gatored from being in the air, not from being left in the sun.
                      Cheers
                      Mike
                      • Not sure this is the right place for this, but since we were talking earlier about "brown" outs on this thread and I mentioned the problem I was having with a gecko 155 amp ESC on my new F-16, I thought I'd pose my question here as well as on the F-16 thread since it seems that the F-16 thread is kind of dead and all the "heavy hitters' with the knowledge I need are on this thread. Here's my question:
                        As stated before, the Motion recommended Gecko 155amp ESC had major timing issues with the upgraded 4068-1835kV inrunner, causing the throttle to occasionally go dead when the throttle was reduced to 0 and then throttled up (is that a recipe for disaster or what). The only fix is a firmware download or reprogramming the timing, both of which are difficult and 1 guy at Motion told me not to mess with the timing as it may cause the EDF to burn out. Still waiting for Motion to decide what, if anything they are going to do for me, but in the meantime, I ordered from them the Castle 130Amp ESC with 5amp internal BEC that they said would be a good alternative. 1 of them also said the 5amp internal BEC was enough for the 5-17gram servos, 1-9 gram nose steering servo, the nose & main retracts and the lights. My question is, do you guys think the 5 amp peak internal BEC is enough, or should I install a separate 10amp BEC and cut out the internal BEC. I'm just not knowledgeable on how much these servos and retracts actually draw. I have 6 other Castle ESC's with 5 amp BECs running in other planes perfectly, but none of those planes have retracts or lights. Those planes all have 4-6 of the Hitect 7245 servos and never had an issue, so I'm kind of lost here trying to figure out if 5amps is enough for the F-16.
                          Looking for the same answer....different application. I’ll be watching this.
                          • Got two flights in as the sun set. Thankfully after a headache eased up.
ID:	214671Click image for larger version
ID:	214672Click image for larger version
ID:	214673Click image for larger version
ID:	214674Click image for larger version
ID:	214675Click image for larger version
ID:	214676 Couldn’t help myself taking more photos.
                              Tolga
                              Instagram: @_t01ga_
                              YouTube: t01ga
                              • One day I'll have to get a Corsair of my own.
                                • Originally posted by t01ga View Post
                                  T1G, And who could blame you. Bravo Zulu. Best, LB
                                  • Beautiful!
                                    • Thanks guys!
                                      Tolga
                                      Instagram: @_t01ga_
                                      YouTube: t01ga
                                      • Aros,
                                        I have just been checking your youtube channel. You got some nice planes buddy.
                                        Tolga
                                        Instagram: @_t01ga_
                                        YouTube: t01ga
                                        • Thanks man...I've had some goodies through the years. Just wish I had the funds and space to have kept them all.
