I had a similar shipping issue with my sons cello when he left for university. It was cheapest to buy the seat next to me. The airline offered a discount since it wasn't a person. Ended up being way cheaper then the usual shipping methods for something that large.
Thanks Beeg.Originally posted by Beeg View PostI had a similar shipping issue with my sons cello when he left for university. It was cheapest to buy the seat next to me. The airline offered a discount since it wasn't a person. Ended up being way cheaper then the usual shipping methods for something that large.
It’s more than a little crazy. Thanks for sharing your thoughts.
Thanks F4u Aussie.Originally posted by f4u ausie View PostShipping 4 me from motion to Melbourne is normally $230 USD. ...may b cheaper to send it back and order from motion direct!! And that's fedex
I thought I was being clever making the most of my mates’ travel back to Oz,
You are right, the return to Motion, then repurchase seems like the best option.
Thanks again.
Hello Paul...……..You couldn't find a answer to your question in a search most likely cause it has never been asked in all the readings I've done.Originally posted by paulsnapp View PostI know this question has been asked before but I was not able to find it in a search. How much torque do you use to install the stock prop nut and how do you get it since there is not a "nut" to attach a torque wrench to??
I've also never seen a prop nut torque specified by ANY manufacturer of ARF's. A good firm hand tightening has done well for me and many others over the years.
The round cylinder shaped prop nut on the corsair is not a uncommon method of securing the prop and is hand tightened.
Most of us have calibrated elbows and wrists.Originally posted by paulsnapp View PostI know this question has been asked before but I was not able to find it in a search. How much torque do you use to install the stock prop nut and how do you get it since there is not a "nut" to attach a torque wrench to??
On a serious note, just make it fairly snug but you don't have to really crank down on it. Aluminum threads have pretty good surface friction I know we all have different levels of strength and experience of tightening different fasteners but if you bend your screw driver inserted through the prop nut or deform the edges of the holes it's way too tight.
Try tightening the nut then see how much force it takes to remove it. Unless you get a bad prop strike the nut shouldn't loosen from normal use.
I don't know if this helps. I could go do a test on a different fastener with a torque wrench to give you a better idea of what I use but I'm sure most of use a pretty wide range of what we think is sufficient for a prop nut.
Paul, the longer the moment arm the higher torque you can achieve. I find the biggest Allan wrench that fits through the hole, put it through a little more than half way and tighten with that lever arm. you can use any other wrench/screw driver you want but the point you apply the force needs to be the same distance away. hope this helpsOriginally posted by paulsnapp View PostI know this question has been asked before but I was not able to find it in a search. How much torque do you use to install the stock prop nut and how do you get it since there is not a "nut" to attach a torque wrench to??
JoePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
Well today was my F4U’s expiration date. I took off and it climbed out great. Went to bank left and nothing. Post crash revealed ailerons were unplugged from the blue box. I remember having to pull my battery lead from that area as I went to plug in the battery. Simple preflight could have saved it. Don’t get lazy, or comfortable guys! Now I think I will just order a new one and move the guts over to an old airframe I want to fly again. I had to brush up on my tree climbing skills as well as my hiking skills. Whoa I’m outta shape.
Md_cobra , That is just sad, my friend. Preflight, preflight, preflight. We all can get complacent. I hope you can do a rebuild.
Tough deal, Brother. Best, LB
Md_cobra So sorry to hear (and see) that. Yes, we are all guilty of getting a bit complacent at times. I hate to admit I am as guilty as anyone not always thoroughly performing a pre-flight check before takeoffs. It's Russian Roulette. A good reminder for us all.My YouTube RC videos:
- Likes 2
Welcome to the Squawk Reddogpt ! Wow, what a beaut!
Hi I have the Flightline Corsair ,what a lovely airplane but I have one major problem with it that has stop me flying the Corsair .I have had only 10 flight with the Corsair and gone through 4 retracts .The landing honestly have not been heavy .What happens is it gets into a slight bouncing and then one of the retract gives way so .The actually retract is fine no problems it is the retract servo that is the problem .IT seems to get pushed passed the worm drive piece ,So I take the servo apart to put the retract leg back inline with the worm drive and the little leads come off the circuit board and there is no way my soldering will cope with re soldering the tiny little leads back on to the circuit board so I have to buy and new retract servo .I have just brought 2 retract servos a week ago and it two flight they have both failed again .I just can not afford to keep buying new retract servos every couple of flight so I have grounded the Corsair. I also have the 1600 Spitfire but have no issue what so ever with that I know everyone is going to say I am landing it to heavy but honestly even people at our flying field have commented that the landing was OK and could not believe the retract gave way .Has anyone else experience this is is it just me .Sad not to fly such a lovely aircraft
Two things cause bouncing
landing to close to stall speed, or at to high an AoA (+ or-). The wing has to be flying enough to dampen the springs in the Oreos.
hope this helps
joePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
