  • iampilot2
    Pilot
    • Sep 2018
    • 25
    • Ohio, USA
    Kelly Johnson, man at the right time in history.
    Credited for numerous pivotal designs.
    Painting invasion stripes on mine, big job.
    -Brad
    • iampilot2
      Pilot
      • Sep 2018
      • 25
      • Ohio, USA
      Laid the white base paint, flat Krylon and blue painters tape -no problem. Pucker factor off the scale as I was removing the tape. The factory olive paint is very durable.
      • iampilot2
        Pilot
        • Sep 2018
        • 25
        • Ohio, USA
        Strips finished
          Looks nice!
          • iampilot2
            Pilot
            • Sep 2018
            • 25
            • Ohio, USA
            Thanks, my Top Flite P47 is olive with invasion strips, really helps visually when flying. Beside those stripes signify victory.
              Yes indeed! On both counts!
              • iampilot2
                Pilot
                • Sep 2018
                • 25
                • Ohio, USA
                All push rods installed and initial adjustments made, servos cycled for six minutes all good so far. Lights identified and proper location in circuit module noted.
                connecting outboard flaps per manual causes them to travel more than inboard flaps. Anyone have this issue?
                Tomorow I will address this and remedy.
                going to maiden this Saturday. Click image for larger version
                  Hi iampilot2,
                  The flaps on my P-38 (and my F7F for that matter) vary between 1-4mm across the span and I haven't noticed anything detrimental over the past ~3 years. Personally I'm comfortable if the inboard flaps are mirrored close enough to each other and the outboard flaps are mirrored close enough to each other. Only if both flaps on the same wing were noticeably different deflections that the two flaps on the other wing would I be wary. In that case I'd make adjustments to the servo linkages mechanically to get them back to flight-safe.
                  • iampilot2
                    Pilot
                    • Sep 2018
                    • 25
                    • Ohio, USA
                    Thanks Alpha
                    • Dual Prop Dave
                      Just another Prop Nut!
                      • 144
                      • Sunbury,Pa
                      Originally posted by iampilot2
                      Strips finished
                      Looks awesome! You do very nice work! Can't wait to see the finished product!:p38
                      • iampilot2
                        Pilot
                        • Sep 2018
                        • 25
                        • Ohio, USA
                        Well weather in Ohio was not right for maiden. So today I took my time programming radio and cycling motor batteries. Thrust is impressive. Balancing three blade props can make one nutty but got them very close.
                        Yet to place all the decals. Haven’t really looked very close at the quality on ones supplied with kit.
                        I used Cali decals (Snafu) on my 1/8 scale gasser P47 and were very pleased with quality. Click image for larger version
                          Yeah, don't bother with those more of a pain than they are worth she looks great as well
                          • iampilot2
                            Pilot
                            • Sep 2018
                            • 25
                            • Ohio, USA
                            Thanks All
                            • FLTpilot
                              • Aug 2018
                              • 25
                              Wasn't feeling too well today so I decided to play.....! Original photo was Ryan@Motion from Pg 78. Hope you don't mind..... Click image for larger version
ID:	153676Click image for larger version
ID:	153677Click image for larger version
ID:	153678Click image for larger version
ID:	153679Click image for larger version
ID:	153680Click image for larger version
                              • iampilot2
                                Pilot
                                • Sep 2018
                                • 25
                                • Ohio, USA
                                Nice, thanks for pics
                                • Para1911A1
                                  • Nov 2015
                                  • 19
                                  • Paso Robles, CA
                                  Hey Guys,
                                  I'm looking at adding a muli engine to my fleet. What are everyone's views on selection between F7F or P38??
                                  Gary
                                    They both fly great, but the F7F flies easier, is lighter on the wing, and seems to get better flight time.
                                      +1 on the F7F, it is a nicer plane.
                                      • Dual Prop Dave
                                        • 144
                                        • Sunbury,Pa
                                        I love my F7F, but really enjoy the P-38. I must admit I find myself flying the F7F more than the 38. In my opinion, you can't go wrong with either one!
                                          +1 Totally concur with Pat
