Official Skynetic 1000mm Havok Racer Thread
  • mr.frankenjet
    Eat, sleep, FLY FLY FLY !
    • 448
    • Virginia, USA
    here is footage with 70% power,this was an unexpected surprise , a launch trim will fix it no worries, maybe a little less power. Maiden launch always a mystery till you get things trimmed up She is a great flyer
    rc flyin addict
    • Slammm
      Old Fart
      • Aug 2018
      • 8
      Did my maiden today and what a cool ship, smooth and beautiful in the air. On my first attempt, yesterday I did torque roll into the dirt and I was about 50% throttle, I think it was because it was out of trim and I was afraid of it. After gathering my courage I put a couple right clicks of aileron, turned the gyro on and launch was just like the videos on MRC. I have the Admiral receiver with stability plus gyro but it was turned off on the first attempt. I had the gyro on today but was only able to fly at half throttle or a little more because It has some wing bobble, I'll turn the gain on the gyro down a bit. My initial concern was the control movements,, I couldn't get the full deflection as called out in the instructions without overdriving the servos. After some adjustments and getting close to the low end movements as called out in the instructions, aileron 8mm up and down, 7mm up and down on the elevator (that's what I currently have) and that made it a tame flying ship, not nearly as fast as I expected but that was only at 50% throttle, can't wait to open her up go to high rates and see how fast she will go. Have to overdrive the servos to get to high control movements but I’m not flying with the servos pegged out all the time anyway.
      • RCGuy83
        • Jan 2019
        • 126
        It looked pretty much like my maiden hand launch of the Havok. See the 2min mark. It'll wake you up for sure! Super fun plane to fly for sure!
        • mr.frankenjet
          • 448
          • Virginia, USA
          https://www.youtube.com/watch?v=Xt51Ihcim5U&t=1s
          that looks familiar , I think the launch trim will help, hope to see on Saturday
          rc flyin addict
          • mr.frankenjet
            • 448
            • Virginia, USA
            2nd launch a lock with launch trim, happy with the setup , still room to move the cg back a little.
            Will change to 8x8e prop for the next flight, got her ready, sounds a lot better to me. Slight pitch up with the throttle, I likley will just mix it out. lets see how she goes with the new prop first
            rc flyin addict
            • Merlinfan
              • 15
              After a long delay the repaint starts. I used strapping tape to stiffen up the fuse. My favorite quick and dirty fix for sloppy foam. I have squared the fuse to the wing as best as I could. I don’t think I’m going to use the aileron linkage fairings.
              • AceMigKiller
                Insta: Check5_Av8r
                • 175
                Speaking of repaints, can't believe I haven't posted pics of my finished "Miss AmeriKa" scheme!
                Real simple to do with Rustoleum 2X paint.
                The white does tend to peel a little easier than usual so I chose to mask those areas with post-it notes where I could (instead of masking tape).
                Decals by none other than Callie Graphics!
                Cheers!
                Vic
                  • 8205
                  Great job AMK! Real eye-catcher there!
                  • AceMigKiller
                    Insta: Check5_Av8r
                    • 175
                    Has to be when it's moving that fast!
                    The Havok has quickly become one of my favorite birds. It's so locked in and pleasantly predictable, even at full blast!
                    • AceMigKiller
                      Insta: Check5_Av8r
                      • 175
                      Got some great flying in today!
                      Curious to see what others are doing to protect the belly on landing?
                      My local fields are hard surface. I know... first world problem, eh?
                      I've CA'd some thick zip-ties in strategic locations. They seem to do the trick pretty well and are what I consider "consumable". Wear one down or tear one off? No big deal, cheap and super simple to replace.
                      The *only* gripe I've got is that I seem to be chewing through props every 2-3 flights. APC's seem to hold up better than stock props, but they get munched up as well.
                      Next step will be to try and program a brake on the ESC if it has one.
                      Otherwise, friggin' great flying pocket rocket.
                      Vic
                        I like your fleet, Vic! Keep the pics coming! Your Miss America repaint transforms the Havok... I didn't even recognize it!
                        Zip ties are a good idea for belly landing anything that's foam onto paved surfaces. "Consumable", indeed. G10 works well, too.
                        • mr.frankenjet
                          • 448
                          • Virginia, USA
                          like the zip tie mod great idea for a consumable skid, your fleet looks great. The break usually left off so the prop can roll out of the way , I broke the stock prop on my 2nd flight though . Added a landing mix both ale's up a few mm's, helps keep the nose up and slows her down a little. More landing practice needed here, increased the throw on the mix for the next flight.
                          happy landings
                          rc flyin addict
                          • AceMigKiller
                            Insta: Check5_Av8r
                            • 175
                            Hmmm a reflex mix in the ailerons... why didn't I think of that?!
                            Great suggestion. I'll dial that in and report back.
                            • AceMigKiller
                              Insta: Check5_Av8r
                              • 175
                              Thanks Alpha!
                              • Merlinfan
                                • 15
                                I have waited a week for the silver to dry before putting
                                Callie’s stickers on.
                                • Merlinfan
                                  • 15
                                  I didn’t get the fuse perfectly aligned with the wing but I was able to get it to sit straighter. Here’s two pics for comparison. Should have taken off the prop for the pic. May help out with the left roll at high airspeed.
                                  • AceMigKiller
                                    Insta: Check5_Av8r
                                    • 175
                                    Very nice!
                                    I too notice an ever so slight roll at high speed, but attribute it to torque. When I back off the power the roll tendency goes away.
                                    • JamesonC
                                      MRC fanboy
                                      • 619
                                      • Laurens, SC
                                      I originally had plans for a hot 6s setup in mine. But, that left roll got pretty severe when at much higher speeds. So, mine is back on 4s.
                                      • AceMigKiller
                                        Insta: Check5_Av8r
                                        • 175
                                        Hmmm, even at full blast out of a dive I haven't experienced the roll to be anything but very mild...
                                        Not saying all airframes are the same though.
                                        Have you tried programming a roll/throttle mix?
                                        I'm guestimating mine would only need about 3% to keep it level enough.
                                        • JamesonC
                                          MRC fanboy
                                          • 619
                                          • Laurens, SC
                                          All stock on 4s, mine is not bad at all either. 6s was a different story.
