Official Black Horse 2350mm Gilmore Red Lion
  • DaleD
    Originally posted by djmoose
    Thank you! The thing about those wheels is that they're pretty gawky...however with most of them inside the pants...it's not that big of an issue. I went with black so they would be less noticeable.
    About the collars...I had some 1/4 inch ID on hand...which is slightly larger than 6mm but they still clamp on real tight. (tight enough for me to be comfortable) If for some reason they slip, they have metric ones as well.
    I get these from McMaster-Carr: https://www.mcmaster.com/catalog/6436K12
    Looks like collars like these are available other places as well. (Home Depot, Amazon, etc etc)
    Thanks for the link.
    I’ve placed an order for 2 each in 1/4” and 3/16”.
    DaleD
    Interesting clamp collar. Thanks for the link.
  • djmoose
    Originally posted by DaleD
    Those wheels look REAL nice. Hope they perform as well as they look, please keep us posted.
    I’d like to get a couple of those split collars. Would you kindly share a link to your source and any additional details? The supplied screw used as the wheel axel is 6mm if memory serves correct. What size collar did you select?
    Thanks
    DaleD
  • DaleD
    Just a little teaser:
    A real teaser indeed. Beautiful model being handled well.
    DaleD
  • DaleD
    I found these Fly Wheelz that I think will work perfect for the 44. Thinner, slightly more bounce (not much) and comes with a spare set of rubber.
    I've also switched to some clamp-on collars for in-between the LG and the wheel. (instead of a nut or locknut)
    Thanks
    DaleD
  • djmoose
  • djmoose
    Duplicate post
    djmoose Congrats on the maiden!
    When tuning the Gilmore in, it wound up being a warbird/pattern plane approach. The ailerons are scale and fairly small. similar to those on warbirds, so 20deg and 25deg worked.
    It has a long tail moment, similar to a pattern plane, so 12deg and 15deg worked well.
    Replacing the glitchy elevator servos made the biggest difference on mine. With the long tail moment, just a little off center on the return had a big effect on how it felt.
  • djmoose
    Thank you 406! We all know that the true test for CG in flight is the inverted flight test...I just did not have enough aileron to feel ok to roll her yesterday. I don't push things until I'm comfortable. Baby steps! More to come!
    Originally posted by 406PIlot
    djmoose great job!!!!!! Really glad your maiden went well!! Your write up was excellent.
    I will say I am in complete agreement about the ailerons!!
    Cheers on the maiden!
  • 406PIlot
  • djmoose
    She has flown! One maiden flight, I was the only one at the field, so no video.
    AUW: 23.45 lbs (no lion, closed cockpit, 12S 5200mah)
    CG: 114.6 mm from LE
    Batteries:
    2 6S 5200 Zee packs - https://smile.amazon.com/gp/product/B08GLMY3BT
    1 2S 2200 pack for Rx
    Taxi and takeoff were no problem...needed right ridder to keep her straight, but that's par for the course.
    I personally need more aileron. My high rates were per the manual and I'll be adjusting.
    This plane loves rudder...if you don't fly rudder, you might not enjoy flying this plane and it's probably not going to look great in turns. The good thing is that this plane responds well with rudder input. Not only in coordinating turns, but for aligning your lines, not to mention corrections for your landing approach.
    Rudder rate as stated in the manual is perfect.
    I need more time on the elevator...I stayed on high rates the entire flight...as I didn't want to loose any aileron. Yes, as she flew yesterday, some would say pitch is twitchy....but I didn't notice any other tail heavy tendencies...so as of right now, it's just nicely sensitive on pitch. (this has been stated before in the thread...I'm just confirming with my experience)
    In fact...at 114.6 CG, everything pointed to it still being nose heavy. I wont know for sure until after a few more flights. I'll keep in mind that even if it's nose heavy...moving the CG back will give the elevator more authority. It truly is a balancing act to get everything the way you like it.
    Landing in just mowed grass on a rolled field was butter. Not even a bounce. (another reason I don't think it's tail-heavy) I stayed with the stock wheels and had no problems. However I BET landing on pavement wouldn't be as smooth.
    More to come!
    Click image for larger version  Name:	image_74303.jpg Views:	3 Size:	155.0 KB ID:	322695
    P:S: I don't ever mention expo in a thread like this as I feel it's completely pilot preference. Just saying that because I want to head off any expo suggestions on the elevator or ailerons. Trust me, I don't need any more or less. :-)
    P:P:S: I do have a Jeti Rex10 Assist Rx, but the gyro stayed turned off the entire flight. IT won't get turned on until I get the plane trimmed and flying they way I like.
  • 406PIlot
    Ok here is a picture i snapped when i got home from work.
  • RCBobP
    No problems at all with balancing the plane. The heavy motor helped quite a bit. I didn't have to add any additional ballast or weight. I am using the 112mm CG and it's perfect. I included a picture from when i was laying things out during assembly. I'll get an updated picture and post later. However things didn't change. Fuel tank / batteries / switches etc all stayed in the same location shown.
    Awesome, thanks!
    406PIlot Nice clean install. Pretty easy to do when there's an area the size of most garages to work with lol.
  • 406PIlot
    Originally posted by RCBobP
    Yes, that sound. Purrs like a kitten! Did you have any issues balancing the plane? That engine adds some weight to the front, so I'd like to see how you set up "under the hood". Battery placement, etc. Did you have to add any aft weight? Did you balance at the 112 mm mark?
  • RCBobP
    Looking good RCBobP.... That saito FG-90 pulls the gilmore fantastically with a 24x12. OHHH THE SOUND!!!!!!!!!!
    406PIlot Sounds great!
  • 406PIlot
  • RCBobP
    By the way, I ran three tanks through the engine on a test stand. Hot diggety that baby hums!
