Official Black Horse 2350mm Gilmore Red Lion
    • 4819
    Originally posted by RCBobP
    This is one where you'll get all kinds of opinions. Here are pictures of my engine in the cowl,
    RB, Whatever you decide to do, I just want to congratulate you on a job well done. Great install work, she looks to be a beauty. Best, LB
    • 406PIlot
      • Nov 2020
      • 381
      • Billings, MT
      DaleD I am not running any baffles in my cowl. It's is wide open with the Saito FG-90 sitting there. I've checked temps repeatedly on multiple flights immediately after landing and head temps are anywhere between 165-185 at peak. I have had no issues with temps or anything just running the cowl and no baffles.
      • DaleD
        • 57
        RCBobP and 406PIlot, based on both your responses, I believe I will be about ready to maiden VERY soon.
        Today I finished installing the blisters on the cowl and finalised battery placement for an ever so slight nose heavy attitude.
        The addition of the blisters gives the Gilmore a more aggressive look. I am very happy I took time to trim, sand and install them. I can clearly see why this model attracts so much attention.
        More updates to come.
        DaleD
        • 406PIlot
          • Nov 2020
          • 381
          • Billings, MT
          DaleD That 5 cylinder looks so good in there!!! Nice clean install of batteries etc. Good work. Can't wait to hear your report on the maiden. We are all rooting for a successful flight!!
          • RCBobP
            • 89
            That 5-cylinder engine looks bad arse! If I had known about it, I probably would have used that one, not that there's anything wrong with the Saito!
            Looking forward to your flight report, and take some video so we can hear that engine purr!
              It's great to see all of these Red Lions coming together and taking to the air! Congrats guys!
              • Karolh
                • Oct 2021
                • 3
                Hi Dale, your model will certainly take center stage at the field whenever you maiden her as she is a very commanding model to
                look at. I like your very neat installs and attention to detail. Can't wait to see her fly and hear the awesome sound of that 5 cylinder doing it's thing pardie.
                • RCBobP
                  • 89
                  Seems like we always have to be thinking about the next improvement to our setup. Can't leave well enough alone.
                  I don't trust the EZ Connector on the throttle servo arm. I tightened the set screw, but my paranoia makes me think that one day it will loosen and I won't be able to move the throttle while she's in the air. Now that I have the throws and trims where I want it, how big of a sin would it be to place a drop of medium CA on the push rod on either side of the connector? Or does anyone have a better idea? Or is my paranoia unfounded? (As the saying goes, just because you're paranoid doesn't mean they're not really out to get you.)
                  • Karolh
                    • Oct 2021
                    • 3
                    You have company in that department as any connection that I have the slightest doubt of it coming loose gets a dab of loctite or CA just for my peace of mind and also safety's sake.
                    • DaleD
                      • 57
                      Very nice of you to drop in Karol. Thanks for the kind words and encouragement.
                      DaleD
                      • RCBobP
                        • 89
                        Someone took this picture of my Gilmore in the air, so I thought I'd pass it along.
                        • DaleD
                          • 57
                          DropDeadGorgeous
                          DaleD
                          • 406PIlot
                            • Nov 2020
                            • 381
                            • Billings, MT
                            Put a 90bend in the wire just behind the connector. This should keep it from coming completely out should the screw get loose. Also no harm in a little ca or some blue loctite
                            here is a picture of mine doing exactly as I mentioned. The picture is bad but you get the idea (I hope).
                            Just make sure you don't need to adjust the rod before you trim and bend.
                            • Karolh
                              • Oct 2021
                              • 3
                              In one word .... sweeeet !!
                              • RCBobP
                                • 89
                                Thanks, 406PIlot . I worry that with my luck, I'll try to bend it, but it will break!
                                • RCBobP
                                  • 89
                                  Another awesome photo.
                                  • 406PIlot
                                    • Nov 2020
                                    • 381
                                    • Billings, MT
                                    Is that a super aggressive take off or a fancy tail first landing.
                                    Great photo either way!!
                                      RCBobP Nice shot. Still, the coolest Gilmore pilot in the cockpit.
                                      • DaleD
                                        • 57
                                        VERY nice shot indeed. I would have loved to see the full aircraft. Cant help but wonder what is going on with the tail section.
                                        DaleD
                                        • RCBobP
                                          • 89
                                          Photo taken by a photography hobbyist who came to our club's annual community fly-in. Great detail on the zoom but you're right....would have loved to seen the whole plane.
