I don't think it's that the screws are too short. I think you're missing the hole. IE, the alignment is off. However, I could be wrong. Next time you push the wing section into the boom section, have the plane upside down so you can see the slot of the wing section as it slides onto the peg of the boom. Does it go in far enough to align the path the screw must go to get threaded and seated? If the alignment is off just a little, the screw will be pushing up against the peg, thereby shoving the boom section up as the wing section is forced down.
PS. If you don't have ALL the wires shoved into the space in the boom section, a single wire hanging in the space between the wing section and boom section will prevent the wing section from mating flush with the boom. That gap is enough to misalign the hole.
