  • Bubble conversion in progress, removal of the turtle deck 1st , then sanding it to 95 percent profile then cutting the canopy hatch and slow block sanding to match both parts to avoid over use of filler prior to the primer coat..
    • Excellent! Looks better already!
      davegee
      • Originally posted by davegee View Post
        davegee
        the foam is the delicate part, on to print some test sizing shells prior to the real plug 10 hour print . i removed the cockpit panels to avoid over spray
        • vrosi1963,
          Lookin' really good, Sir.
          Best, LB
          • vrosi1963,
            That looks amazing.
            • Davegee,
              Looks like you are going to get an FMS 1500 bubble top P-47D after all. They do fly nice. If I do a P-47m I might have to upgrade the motor to the most powerful motor that would fit (doesn't really need a bigger one) Just because the P-47m was the most powerful one in Europe. LOL
              Best Regards, Rex
              • I’ve been flying the FMS 1.5m P-47D razorback since they came out with them in 2016. Was always hoping for a bubble top, but looks like this is the only way to get one, right now. I’m really looking forward to it. Will probably my final P-47, but a good one to end on.
                Yeah, as you might know, the M model used an uprated R2800 C series engine originally designed for the larger P-47N. In the smaller M model, it was hell on wheels. My late friend Russ Kyler who flew one in the last months of the war declared that “Any German that took them on above 25,000 feet was Dead Meat!”
                I can help you with any specific detail questions you might have if you go ahead and make one.
                Your package has been sitting not far from you in Indiana for a couple of days now, but thanks to the weekend and federal holiday tomorrow, it will arrive at your house on Tuesday. Hopefully everything arrives intact.
                cheers
                Davegee
                • Davegee,
                  Hope you add all the details you can think of and the more I think of the sharper trailing edges I think they would withstand any flying conditions if adding the g10 and poly acrylic/fiberglass.
                  Thanks for the update
                  Best Regards, Rex
                  • Originally posted by jetfool View Post
                    Davegee,
                    Best Regards, Rex
                    Yes, I think I would like to do that. I have some extra parts that I can practice on. Can you tell me where to get that device to mark the centlerline of the trailing edges and also where to get the g10 poly acrylic fiberglass? I might as well stock up with tools and parts I would like to add to this model. I think the P-47 redo of the fuselage finishing and shipping back to me is at least a month away so this would be a good time to get familiar wtih doing the trailing edge mods on some sample surfaces.
                    Thanks,
                    davegee
                    • first shell test print , the cross section looks correct but will go up in scale , the fuse looks slightly lengthened to me per the real plane profile
                      • That's absolutely incredible.. . between the 4 of yas. ( I'm sure the other 3 no who U r),,, a full size 3 d printed p47 is on the horizon!! Oh ok maybe half scale awesome 👍
                        • vrosi1963,
                          It is looking fantastic. Nice craftsmanship.
                          Best Regards, Rex
                          • Originally posted by vrosi1963 View Post
                            first shell test print..........
                            VR,
                            That will do, SIr.
                            Best, LB
                            • Davegee,
                              This is the DU-BRO slotter I use. Amazon sells it.
                              MSC Industrial is one place for Garolite/ G-10, 1/32" by 12" should give enough material to cut strips from.
                              McMaster-Carr is another and where I usually order from. They offer thinner sheets .015", .020", 1/32". I have sheets of all three 12X12". gives a choice to choose from.
                              Don't cut on your bandsaw, it will dull the blade immediately. I use a tile cutter table saw from Harber Freight (30-40$) mine came w/5" diamond blade. It is a thin blade, so I don't waste much material. Any questions. Ask.
                              Best Regards, Rex
                                That could be. They may have found to make it a better rc flying airplane, they had to stretch it out a little here and there.
                                Regarding the clear canopy, can I get at least a couple of those when you make them? I'm thinking just in case I scratch or damage one while flying, that kind of thing. I'd like to have some backups. I also plan to make the canopy retractable, if I can do that. Any extra $$ for extra clear canopies just let me know.
                                Your mods are looking great so far.
                                Thanks,
                                davegee
                                  Davegee,
                                  Best Regards, Rex
                                  That's good info, Rex. So, you cut the slot into the trailing edge of the control surface. How far does it stick out, and how do you make a smooth taper from the control surface to the end of the G-10 that you glued in place? I wish I had known about this technique years ago when I was flying the Aerotech and Yellow airplanes. It was fairly tapered but not quite to what I wanted it. At least it was Way better than foam airplanes!
                                  Cheers
                                  davegee
                                  • Davegee,
                                    Once you have the centerline marked use a sharp x-acto blade #11 and cut a slit 1/2"-3/4" deep. Take your g-10 and slide it in the slit, it should be flush with the existing foam trailing edge. glue with thin ca. you will feel the difference of the trailing edge when the ca sets up. Sand the foam down to the g-10 at the correct angle till it all looks right. I clamp a flat strip of scrap pine board, usually a 3/4'X 2" X 12" under the ail/elev/rud to give a hard flat surface as I sand the topside, reverse for the bottom. When done you should have a nice straight line that looks like the real one. Follow up with the poly/fiberglass strip and finish it out. I usually start with 80 grit sandpaper to get the first thick edge sand toward the leading edge then using 120 to 320 for final sanding. hope this helps.
                                    Best Regards, Rex
                                    • V2 scaling i think this is way better , will print a pilot with head rest armor plate to see if the height is looking correct .
                                        Davegee,
                                        Best Regards, Rex
                                        Thanks, Rex. How about for complicated curves, like the rounded edges of the horizontal stab, elevators, ailerons, etc. Do you just cut the curve into the g-10 so that it fits? Is there any way to use a exacto blade and cut them by hand without buying a motorized cutter from the store as you described?
                                        Thanks,
                                        Dave
                                          That looks good, Jim. It would be good to see how the armor plate backing for the cockpit fits with the clearance for canopy. Nice job!
                                          davegee
