The perfect practice model for my Top RC Model P-51!
I was hoping to see some footage of the cockpit/hatch cover. From a distance it looks as if they finally got a different pilot. How much room in the hatch for mods?
(Dangerous Dan)Team Gross!Comment
Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
There is a video of a Chinese unboxing on an RCG thread, detailed footage of the cockpit interior. I think the chap’s YT channel is called FN RC or FNRC. A comprehensive unboxing video.Tolga
Instagram: @_t01ga_
YouTube: t01gaComment
If I didn't have the FMS 1700mm P-51, I'd be on this one. I'd even consider getting rid of the FMS in favor of this one but the price is a bit steep considering it would be a second one for me.
Here ya go: (May as well turn the sound and closed caption OFF. Can't understand any of it.)
I wonder if they're the same props they used on the Freewing P 51. I was looking for parts and I see that it's gone as well as the Tigercat. I'm starting to have some rare birds.....
I'm sure if you really wanted to, you could make it work. However ............................... This P-51 uses a 16 X 12 prop, turned by a 390kv motor. The FMS 1700 uses a 17 X 9, turned by a 360kv motor. The FMS prop has much less "bite" than the FL prop. To be more equal, it needs to be 17 X 11. The FL motor is close in kv but is slightly more max speed. The FL plane is about 0.8kg lighter. Hard to say if performance would be the same. You'd have to try it and see.
In a similar line of thinking, it may be worth seeing if this motor would give the FMS 1700mm P-51 a small boost in performance. It came with an 85A ESC, so it may just be able to take it.Comment
Looks very accurate , why do they keep producing everything in Green again and not offer silver and green , what do you thing people . i get sick or repainting almost every arf now just like the B25 arg still way better than the 1500mm e-flight Fake non scale blue P51DComment
Ordered!
My thought as well. First thing to go would be the green paint. I've had three Mustangs, all silver (one Flite Metal) the 'D's weren't green for very long, the 'B's were more likely to be green.
I was leaning towards "Contrary Mary" which was WZ-I, the same as Big Beautiful Doll, but a different tail number and even more checkerboard. My theory is she was assigned the squadron number after Landers left?
FW/ FL has released planes in both green and silver before. That said I doubt they will on this one unless it really really sells well.
I historically liked the silver schemes better thou the silver shows the foam cells more.Comment
AMA#116446Comment
