  • paulrkytek
    Gone for the full desert rat https://www.youtube.com/watch?v=-EDAfE7dQVI
    I also had a screech coming from the prop/motor whenever I made a power off dive, then coming back into the throttle. Un-nerving it was. I re-programmed the ESC and the now it has not only gone away, but the power is much smoother and quieter. I believe it was either the brake not being set to off or the Freewheeling feature not set to on.
    The aircraft is very well made and flys wonderfully.
    I have been experiencing that same screech. Very unnerving! What entailed re-programming the ESC exactly?
  • GliderGuy
    When I had a main not deploy until I recycled, someone commented about a possible frame loss issue on the P-51.
    I immediately ordered some capacitors off Amazon and ended up adding 6600 uF (2 of the 3300 uF in parallel) because I could! In the past, gyros I have purchased came with 3,300 uF.
    Since adding these caps to an open port on the RX, no more issues. I was surprised to find the bird’s gyro didn’t have a capacitor in the system. Checking my other MRC birds…some do and some don’t have external caps at the gyro. I’ve added caps to all the birds that didn’t have them. Couldn’t hurt!
    And…because I could…I also added RF chokes to the non-motor side of the ESC. Generally, chokes are reserved for use on my high-current EDF jets.
    I’ve made a lot of flights since the addition of the add-ons. Rock solid, now. I have equipment that doesn’t monitor frame losses or drops.
  • nuts-n-volts
    I think I'm quoting Evan here... I bought the plane without a gyro and firmly believe it doesn't need one at all. And, like GG said, go easy on the rudder when taking off/landing. It's very effective.
    Just a FWIW. I would check your Frame Losses after flying. I was getting over a 100 or so each time flying stock. Bought a 10A ZTW BEC from Motion. Had a feeling the load was high especially near the end of the flight with gear, flaps, etc all working. After installing, the FLs went down to below 20/flight. Just maybe something to keep an eye on.
  • GliderGuy
    Hi Brian…
    The default gyro settings are mostly fine. The Zig Zag on takeoff is pilot induced. Once you get the hang of it…the Zig Zag goes away. I’m on high rates and no Zig Zag.
    The secret is don’t touch the rudder and smoothly but smartly go to full throttle. Don’t ease in the power…get after it. She’ll jump into the air very straight with a touch of up elevator at the start.
    Ease up the throttle to full power…and you’ll Zig Zag a lot.
    Others have posted this trick in prior posts.
    I agree with Evan…I like it!
  • BL_41
    "Question on setup of Freewing Gyro for 1600mm P-51".
    Sounds like the gyro that came with my Flightline P-51. I also bought the Freewing bluetooth device to communicate with the gyro. I found their Freewing Flight Assistant for Android, but not for iOS devices. I have fifteen flights using the gyro Basic Gain mode. The pitch and roll settings seem good. I had a couple of landings the other day in light gusty winds. The plane was rock solid all the through the landing. I think the yaw may be set a little high. On takeoff the plane has a tendency to zig-zag, regardless of the wind direction. I have reduced the gain on the yaw, but have not had a chance to test it.
    Brian
  • Davegeee
    I like it. Looks and flies very well. That said I fly my jets more and actually like the Spitfire more.
    I'm looking forward to flying my P-51 when I get it all done in a few weeks, hopefully.
    The upcoming F-35C should really be a cool airplane, and I have confidence that it will be, with the RC Geek Chris Wolf a driving force behind it. I may get one myself if it turns out in reality as good as it looks on paper!
    Cheers
    Davegee
  • jetfool
    Davegee,
    While working away trying to learn my new NX8+ Spektrum from my old Futaba 7c a deceased's friends son gave me his dads like new Spectrum 8, Taranis 9d assist + and a Turnigy 16 with 3-4 rec for each. Not sure if my old mind can figure out this new technology. Felt Humbled to receive these.
    Rex
    Me, too, on the Cougar. I do like the other mode and will probably do the same with the P-51.
    How do you like your P-51 so far, Evan?
    cheers
    dave
    Sounds like mine. I disabled the self leveling
  • Davegeee
    Hi Guys: I am putting my new 1.6m Flightline P-51D together. I opted for the version with the gyro installed on the airplane. I just put the power to it this morning. I have some experience with these gyros from my Freewing F9F-8 Cougar airplane which works great.
    The reading material that came with the P-51 talks a little bit about the gyro, but it is different in some ways to the one in my Cougar. For instance, the colored lights on the gyro are different. On the Cougar, the off mode is a white light on the gyro box. The Auto Level gain mode is a blue light on the control box. And when you used the Basic Gain mode, the colored light is green.
    Now, on my P-51 with the gyro, with the unit turned off, there is no light, it is dark. In the auto leveling mode it is a flashing green light, and when in the Basic Gain mode, it is a solid green light.
    I have it figured out I think that it essentially operates the same as the earlier unit on my Cougar, just different colored lights . I've tested them in my shop by moving the airplane around, and it seems to me that it works ok.
    Has anyone else bought the gyro option for the P-51? I just wanted to be sure I'm not missing something as I didn't see any other documentation with the P-51 kit, but it seems to be operating ok, as I am thinking I have the lights correct for the differences with the Cougar servo. They both look identical.
    Cheers
    Davegee
    As a knife, it's much too sharp to carry. There is no sheath. I have cut large pieces of foam with it, like when I made a stand from the shipping box for my AL-37.
  • Davegeee
    Originally posted by Elbee
    https://www.amazon.com/MIERE-Surgica...s%2C203&sr=8-6
    davegee
    Make sure you pick up a blade removal tool.
    Removing a used blade without one is an accident waiting to happen.
    I sound like my Mom, but I have sliced a layer or two off trying to remove the blades with it.
    Best, LB
    Good point! I can see that easily happening!
    Davegee
    commented on 's reply
    Are you a former special forces member? Just kiddin'...now that's a knife!
  • jetfool
    Xviper,
    YIKES!
    That looks like a sharp weapon, don't think I'd need anything like that. Make a great craving knife though for balsa.
    Best Regards, Rex
    For serious work, we used to use “autopsy” knives. When the lab closed, I was allowed to take a few home. They come in 3”, 6” and 12”. Just as sharp as a scalpel but used for cutting brain slices. They were strong enough to slice through fish spines.
    Here is the 6” I used to use for many years. Now it’s only used for cutting veggies and meat in the kitchen. Wife uses it to cut rhubarb - the acids in that dulls it very quickly.
    Click image for larger version  Name:	IMG_5831.jpg Views:	0 Size:	80.2 KB ID:	449496
  • jetfool
    Elbee,
    My Dad bought me a large set in a wooden box in 1970. He dated it and I still use the handles w/ new blades (of course) to this day. Really brings back memories every time I use them. Those scalpel blades do last a long time. I use a good pair of needle-nose pliers to remove the blade.
    Rainy and windy again, hope you all are having good flying weather
    Best Regards, Rex
    xviper
    Good tip.
    The removal tool came with the handle and blades from Swann-Morton.
    I cut myself twice before figuring out I should try the removal tool.
    I am not always the sharpest pencil in the box.
    The removal tool works and is a faster way to change out blades for me.
    New blade install is a deliberate process, but simple, as you wrote.
    I do like how sharp these are and how long the blades stay sharp.
    Different stainless alloy, I suppose, versus carbon steel.
    I do miss my tried and true X-acto #11 blades and still use the handles with #4 blades and one or two of the other general purpose blades.
    I have 2-3 NIB complete X-acto box sets from 80's and early 90's I received as gifts.
    For me that's instant nostalgia in a box just looking at 'em. Good times.
    Best, LB
    Worked in a medical research lab for 21 years. Used all kinds of disposable scalpel blades the whole time. The key is having the correct handle for the blade being used. If the handle is incorrect, yes, the blade can go zinging across the bench. Also, a medical grade handle is the only way to go. Once you see how the blade goes on, it's not difficult to figure out the best way to safely remove it, even without a removal tool. We never heard of a removal tool back then. Hint: for installation, fit the blade in the correct position and push it (pointy end up against something rigid like a hard piece of wood) until it clicks into place. You can see that the blunt end bends as it slides over the raised ridge and straightens when it clicks into place. To remove, lift the blunt end on the blunt side and place the now slightly curled blunt end on the edge of the same wood block with pointy end up. Pull the handle down and the blade disengages. It helps to have finger nails that aren't clipped. (Or use small fine needle nose pliars.)
    If you can find them, get handles that are big, thick and roundish. These are the more "industrial" strength type of handles. They can be held more securely and less likely to slip.
