  • jetfool
    • Nov 2022
    • 1288
    • Crawfordsville, Indiana
    Great Job Mr. Beta Tester! You will get it figured out. Rex
    • f4u ausie
      • 1237
      • Melbourne
      The lower leg on the gear. Is a little weak ... Hollow cast... My friend has broken 2 of them.. to be fair he is new to taildrag warbirds.. but I saw one landing and was shocked that it broke
        • Nov 2013
        • 2701
        • Cody, WY
        Hi Rex: great to see you online again. Haven’t seen any of your posts for a little while. These tanks, especially the larger 110 gallon models are a process. The only problem remaining is keeping them from getting damaged or destroyed upon landing on “Mars. “ (My wife and I joke how hard and tough the ground is here, with very little moisture.) I’m thinking I might have CraftCloud make a couple from Dan’s STLs like we did for the P-47 centerline drop tank. That thing is practically indestructible! If not that method, possibly getting a foam copy fabricated somehow. We’ll see…
        cheers
        davegee
        • jetfool
          • Nov 2022
          • 1288
          Davegee,
          I've been flying a lot and little shop time. Will get back on the Phantom this fall for Toledo 27. Kinda ran out of workshop steam last March. I plan to test fly my P-47 and FL P-38 in the next few weeks. I have them set up on my new Specktrum 8+ and have been flying a E-Flite Air Tractor 1.5m to get used to the new radio. Bought the Air Tractor July 4 and have 40 flights on it. I am keeping up on your progress weekly.
          Hope FL introduces some new Warbirds 1.6m this year. Not real interested in the small one, hard to see for me.
          A friend of mine is learning to fly EDF jets and in 4 weeks totaled out 2 and just orders another one. On his 3rd one in 4 weeks. Wish I had his money(he's still working for his hobby money)
          Best Regards, Rex
            • Nov 2013
            • 2701
            • Cody, WY
            Davegee,
            Best Regards, Rex
            Good deal. For your Phantom, would you be interested in printed missiles for the bottom of the fuselage? I had these on my F-4 for many years until it crashed years ago. I can send you a pic PM if you are interested. They fit into the grooves on the bottom of the fuse with magnets. If you don't want them that's fine. But I can send them to you for free if you do. Otherwise, I'll probably just throw them out. They look good, I think. I think one is missing a small fin but that would be easy to replace with styrene plastic cut to fit.
            Cheers
            Davegee
            • nuts-n-volts
              Duke City Electric Flyers
              • 260
              • Albuquerque, New Mexico
ID:	452214 Click image for larger version
              Dave, I was just wondering from your latest photo if your tanks aren't a tad too big in diameter?
              Fly low, fly fast, turn left
                • Nov 2013
                • 2701
                • Cody, WY
                Good question. We took measurements from a accurate model that had these tanks, and that's what they were when scaled up. But that will be one of the things we'll revisit to be sure they are the correct size before we proceed further. They do look a bit oversized when compared to your pic.
                Thanks for the input, we'll examine this to see how to proceed on with this project. A bit smaller would be good as less drag and less weight.
                Cheers
                Davegee
                  • Nov 2013
                  • 2701
                  • Cody, WY
                  Hi Nuts-n- Volts: I did check the size of those 110 gallon tanks that we fabricated. The Flightline P-51D 1.6M airplane is 1/7 scale. The real 110 gallon drop tanks were about 100 inches long and 21 inches in diameter. My model tank is 14.4 inches long (versus real scale 14.28 inches long) and mine is 3.3 inches in diameter at the widest part (versus 3 inches for the real thing in 1/7 scale.) So it is slightly larger than scale. I think it might have "grown" a bit during our planning but it's not terribly far off. If we get some printed, we'll make sure they are 3 inches in diameter and about 14.3 inches long, per scale.
                  Cheers
                  Davegee
                  • nuts-n-volts
                    • 260
                    I wanted to add that your HHH looks magnificent!
                      • Nov 2013
                      • 2701
                      • Cody, WY
                      Thanks so much, Nuts-n-Volts! The current setup printing I have done works out fine, but the drop tanks just can't take the brunt of hitting the hard desert ground. However, the earlier rectangular drop tank designed by Dan Gross and then fabricated by Craft Cloud was more than up to the task of surviving the drop to the ground to reuse the tank again and again. It was tested again yesterday on my FMS P-47D Hairless Joe and it worked great.
                      So, I hope to work with Dan to make the corrections to the STL that you brought up about the diameter of the tank and a couple of other minor tweaks, Craft Cloud can print up a few of them and we can be assured they will survive the demonstration drop.
                      I appreciate your observations on the too-large diameter of the tank we came up with, and that was very helpful to changing this to look exactly the way we want it to, and properly in scale as well. When you pointed that out, I had to agree with you that it needs a little adjustment.
                      Take care,
                      Davegee
                        • Nov 2013
                        • 2701
                        • Cody, WY
                        Nuts-n-Volts made an astute observation when Danger Dan and I put some of the 110 gallon drop tanks together in a 3D printed form. They flew fine three times, but were weak when landing on the ground and usually fractured. Nuts-n-Volts observed that the diameter, not the length, looked a bit too big. I hadn't even considered that, but when he mentioned it, I looked at it more closely and then measured the tanks. Mine were too large by 1/2 inch in diameter at the "fattest" part. They should have been 3 inches in diameter and 14.28 inches long, for 1/7 scale that the Flightline 1.6M P-51D is. They were actually 3 1/2 inches in diameter, and that makes a Big difference!
                        So, Dan made me some adjusted tanks that are now spot on, dimensionswise. I did some testing in my shop just now and have the tanks loosely put together with tape, and tested CG with the tanks on and off, and seeing how well they drop away from the airplane onto foam cushions on my work table. Everything worked out great. So, I will run a few more tests and weather permitting, I'll do a drop test with these tanks. I won't bother to paint them or put the final details on them until I know that they will survive the drop to the ground, but I am encouraged that their thicker shells will keep them from breaking. We'll see.
                        I'll attach some pics. On the CG tests, I decided to move the battery forward on its tray about 1/2 inch when the tanks are on. This is because the CG of the tanks when attached to the airplane is about 1 inch behind the markings on the wing by the manufacturer. They balance great there. And when I tested the CG with the tanks off, the slightly forward CG is not a problem in the balancing of the airplane after the tanks are released and the plane brought back in for a landing.
                        Kudos to Nuts-n-Volts for pointing out my error on the original tanks, and I think these will look better and more scale. Besides, it was a fun exericse in modeling!
                        Cheers
                        Davegee
ID:	452436 Click image for larger version
ID:	452437 Click image for larger version
                        • nuts-n-volts
                          • 260
                          Dave, 1st, those new tanks are looking spot on! Great work and I hope, think they will survive the ultimate drop test.
                          2nd Thank-you for the kind words. But even without those, I am always glad to help... anyone. ...I love the Mustang.
                            • Nov 2013
                            • 2701
                            • Cody, WY
                            Thanks, Nuts-n-Volts. You have helped me with suggestions in the past that worked out well. I appreciate your knowledge base and take heed when you make a suggestion! I'm not sure where we got the 3 1/2" diameter for the 110 gallon tank in 1/7 scale, possibly it came from a diecast or plastic model kit and something got lost in translation. At any rate, they are the correct size now, thanks to you, and even if they break up on ground impact, I can easily print up new ones, or at least know I got this one right.
                            The 357th FG did a lot of bomber escort missions deep into Germany, and these tanks were key to allowing the P-51s to stay with their bombers all the way to target and back. I'm glad I made these up, not only for the fun and challenge of modeling, but to also show others that these were an integral part of the missions that they and other fighter units flew in WWII.
                            I"ll report back no matter what happens when I do the drop test of these tanks probably later this week.
                            Cheers
                            Davegee
                              • Nov 2013
                              • 2701
                              • Cody, WY
                              I thought you and maybe others might enjoy a link I found to Major Richard "Pete" Peterson and the 357th FG in WWII. Some good photos in there. Here is the link for those interested: https://toflyandfight.com/tribute-to...rd-a-peterson/
                              Cheers
                              Davegee
                                • 7347
                                looking at our new iteration versus the pic of the real deal, it looks pretty darned good!
ID:	452450 Click image for larger version
                                I'm liking it!
                                Grossman5
                                (Dangerous Dan)
                                • jetfool
                                  • Nov 2022
                                  • 1288
                                  Davegee and Dan,
                                  Believe you guys hit the nail on the head. Fantastic realism.
                                  Rex
