    Damn... :(
      Originally posted by Mad Baron
      I am really starting to hate this plane. the tail is separating from the fuse even though I used a generous amount of foam tac. I wish I sent it back when I got it.
      What most folks don't realize about Foam-Tac(or any other foam adhesive) is that using copious amounts is actually not a good thing.
      More goop does not make for a stronger joint and all that extra actually can start to melt pockets/holes in the foam seam.
      Best practices for application:
      Apply in thin smooth continuous bead on one surface.
      Put both mating surfaces together to apply the adhesive bead to other surface which creates like an adhesive gasket.
      Pull the mated surfaces apart about 1/2 inch to allow air to start to firm/set glue for a couple minutes.
      Re-mate the surfaces and hold or tape together for a minute or two.
      If you don't want an elastic joint, white Gorilla is your next best foam modeling friend.;)
        :(:(:Straight-Face: Sorry
        • Mad Baron
          132 Aviation
          • 547
          • McMinnville Tn.
          I did use a thin bead on the tail part I put it together and pulled it apart and reassembled it but it separated at the top.
            You originally commented on using a "generous amount" thus the reason for my suggestion.
            I personally don't use Foam-Tac on structures that are under load like airfoils and firewalls.:Scared:
            Want that Gorilla seeping into those foam nooks-n-crannies and forming a solid foam weld.:Cool:
            • Mad Baron
              132 Aviation
              • 547
              • McMinnville Tn.
              Never thought of using gorilla glue on MRC building video they used foam tac. I am going have to fill the gap because I can't afford another $100 for a replacement fuse and tail section hopefully it will hold together.
                Worst case if you can take a hobby knife and get the tail pulled off then redo the whole process with the gorilla glue. :Confused:
                • Mad Baron
                  132 Aviation
                  • 547
                  • McMinnville Tn.
                  I think that would be impossible because I put some foam tac on the square plug that keys into the fuse
                    • 7387
                    Hi Mad Baron, I had the same trouble with the 1600 mm Spitfire, the tail came loose twice! Finally went 5 minute epoxy. I did use Foam-Tac on the Tigercat, just lucked out I guess.
                      Awe damnit... :(
                      • Mad Baron
                        132 Aviation
                        • 547
                        • McMinnville Tn.
                        I was able to open up the gap and flow some foam tac into the gap last night. Checked on it after work today and the glue held strong so I think it will hold up well.
                        • Mad Baron
                          132 Aviation
                          • 547
                          • McMinnville Tn.
                          I was reading thru the manual on hooking up the pushrods and trying to figure which hole on the servo & control horn they should go to. Any help is appreciated. Thanks!
                            I finally got a round to putting the FMS motors, props, front strut and wheels on the Flightline Tigercat and converting it to 6S...I’m betting this girl will be fast.
                            You know I'm flying vicariously through your flying antics/postings..........now show me a vid of that upgraded beast doing the Power Line Limbo LOL
                            • jwdawson5
                              Member "Oldtimer's" Flying Association
                              • Oct 2016
                              • 7
                              Hafta agree with Gilatrout and Grossman56 on the prop hub issue. I was aware of the issue but failed to do a good pre flight check and here is the unfortunate result!
                              • Mad Baron
                                132 Aviation
                                • 547
                                • McMinnville Tn.
                                Wow! That was terrible. Seems like the prop hubs should be made from a more durable material to stand up to the pressures that they go though. Is it repairible?
                                  https://www.youtube.com/watch?v=mULa...a6CHOpK34C-YhA
                                  Sorry that happened!!! Welcome to Hobby Squawk.... Design change due for sure. I have to go check mine now too.... Anyway, glad you are here!!
                                    • 7387
                                    Hey MB, I have outside to outside on all controls, seems to work well.
                                    • Mad Baron
                                      132 Aviation
                                      • 547
                                      • McMinnville Tn.
                                      Thanks Grossman I have finally got the control rods installed. All that needs doing is to balance for the CG and flying it.:)
                                      • farmflyer
                                        • Mar 2015
                                        • 1164
                                        • Quitaque Texas
                                        I guess there is a good reason they don’t just make them all 1 piece props and cover them with a (scale) looking hub.
                                          I heard the sarcasm FF ;)LOL
