Thanks for all your kind comments guys!
Hi LB
RJ53, I had the same issue with the 'waterslides' and so I tried Micro Sol and Micro Set and it did not make a difference. Fortunately, I had gotten Callie's Spitfire Nomenclature set when she made my custom stuff. I'd save back the OEM waterslides and pick up the stickys from Callie. I did use the Roundel stickys from the kit and those worked okay. Best, LB
I wanted pass along my experience. I repaired the waterslide decals with.....microscale liquid decal film(!) Also purchased all replacement nomenclature from Callie Graphics which were perfect. As you know some of the original waterslide decals needed to be used. So finally finished this scratch and dent MRC kit.. soldered on a new LED and fixed the foam on the left wing really happy with the purchase.
I took some shots in my driveway between rain and snow showers.
Rich
8 PhotosComment
Rich, You nailed it. She's a beaut. I have all of the Micro Products and I did not think to try Liquid Decal Film. Doh! Isn't that one of the most elegant designs. Gorgeous. Bravo Zulu. Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Looks great Rich, the nomenclature decals that came with the kit were a disappointment, they tend to peel off and broke easily when applying. Callie will be the way I go as well, should have thought of that when I ordered the custom decals in the first place!
Guys, if I haven't said it before, let me say it now, beware of the blue box! The cover of mine just fell off and the solder joint to the ailerons came off, causing a crash on take off, so check those wires. The good news it this is a tough bird! I ordered a new box and she's all repaired and ready for the air again.
Grossman56Team Gross!Comment
Nice job! Yes, Callie Graphics is the way to go. Most everyone knows they are fast and very nice to work with. All the decals went down perfectly. I ordered the nomenclature set for my FW Corsair F4U1A to add some additional scale appearance.Looks great Rich, the nomenclature decals that came with the kit were a disappointment, they tend to peel off and broke easily when applying. Callie will be the way I go as well, should have thought of that when I ordered the custom decals in the first place!
RichComment
I recently picked one up..out of implue. I've flown and still do fly 1.2m P-47, P-51, T-28 fine. Basic flights such as loops, inline rolls. Landing are good as well, P-51 likes to nose over if you rapidly cut off throttle and don't smoothly lower throttle at touch down.
So, question is would this be to much of a plane for me?
Going to start out in low rates all the way around minus rudder. 65-75-85 with 25expo across the board...I'm tempted to run 70-85-100 but nervous that it's to much as other have stated elevator is sensitive.
How are you guys storing this plane and your other big birds?
Sorry for all the questionsPlanes
-FMS: Bae Hawk Motion: 1.6m Corsair, 850mm Mustang, 1.6m Spitfire Freewing: 1.7m A-10, F-22,Comment
Hi Elbee and others, this reed green sticker ,tape around the tail section, and two waters labels ( reg.no.) I was disappointed and I gave up from little technical labels (also water labels) I would fly without them. To Your family and you ,I give a big greeting from Adriatic Sea with norteast gusty wind (100 Kts). In my 70 years I have not experienced a stronger wind ( fatal wind chill factor ....brrrr)
Regards
Jo1 PhotoComment
Jos, Hello, Sir. You did an excellent job with the fuselage painted band. Many of the guys here painted the "Band" around the fuselage. The water labels are difficult, I know. Not certain if you're interested, but Callie Graphics in New Mexico makes a great set of written nomenclature decals for the Flightline Spitfire. https://callie-graphics.com/ Sounds very chilly in Croatia. Send more pictures of your progress. Give our best to your family as well. Best, LB"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Dear Stephen , thank you for the compliment , but I know I'm not yet handy enough, and there is no place/time for mistake :Confused:. I know about ''Callie'',but here in my city there is a production of labels, I just need to draw what I want. I'm slow, as long as my age permits, but I hope for the maiden during the Spring.I'll send all the pictures of my Spitfire, as I'm progressing.Thanks a lot buddy.
Jos
My grandson Luca, instead of new images of Spit....:)Comment
Good looking boy. He must take after his grandpa.;)Dear Stephen , thank you for the compliment , but I know I'm not yet handy enough, and there is no place/time for mistake :Confused:. I know about ''Callie'',but here in my city there is a production of labels, I just need to draw what I want. I'm slow, as long as my age permits, but I hope for the maiden during the Spring.I'll send all the pictures of my Spitfire, as I'm progressing.Thanks a lot buddy.
Jos
HiJos, Hello, Sir. You did an excellent job with the fuselage painted band. Many of the guys here painted the "Band" around the fuselage. The water labels are difficult, I know. Not certain if you're interested, but Callie Graphics in New Mexico makes a great set of written nomenclature decals for the Flightline Spitfire. https://callie-graphics.com/ Sounds very chilly in Croatia. Send more pictures of your progress. Give our best to your family as well. Best, LB
Looking good...…. I found the same problem with my Spitfire decals.... I feel your pain. I posted some photos and the solution that worked for me (besides ordering new nomenclature decals from Callie) Just apply a couple of coats of this stuff over the top of your water slide decals and they will work much better.
Rich
Is the blue box still a concern item that could give issues in flight? Didn't know if this was a first production issue or something that has followed Flightline. Good thing is can be bypassed.
Recommend rates/throws for maiden? I picked mine up used and it's in great condition. One of my favorite planes and first 1600
Planes
Hello All , thank you very much for your kind words, and for you Rich I have a question. Do you have a web address of ''liquid decals film'' ?... I will try to get it (or something similar) here in Europe. Thanks in advance. All the best.Comment
Jos, that is not the same product, so I do not know if it would work the same. I found this. It a UK website that lists the correct product, hope this helps. Best Steve
https://www.ebay.co.uk/sch/i.html_nkw=Microscale%20Industries%20Mi12%20Micro% 20Liquid%20Decal%20Film&ssPageName=GSTL"I am having an extraordinary ordinary life."~Lucky B*st*rd~
AMA#116446Comment
Hi
I found the company website and they will ship internationally. I would think your local hobby shops that support plastic model kits would carry this product too. So Microscale liquid decal film puts a clear plastic film on the top of the water slide decal which helps hold it together. It restores the original film the decal is made from and really makes a difference. I could not get any of my decals to separate from the paper without breaking before using this stuff.
http://www.microscale.com/Merchant2/...y_Code=FINPROD
Also, the Hard Coat by Beacon is not the same type of product... I have some of this for foam repairs. I do not think this is a good substitute
Rich
You can always test your blue box prior to use, I have not had any trouble with either my L39 or Corsair boxes. You can always disconnect themIs the blue box still a concern item that could give issues in flight? Didn't know if this was a first production issue or something that has followed Flightline. Good thing is can be bypassed.
Rich
