The dang thing gets brighter when you polish it! Just had to try and yep, like a mirror!
Did a couple of panels yesterday and called it quits.
Tips on Flite metal:
Run tape around the perimeter of the area you plan to cover, one or two panels, depending on the size and lay the Flite metal down overlapping the tape and work it down from one side to the other, I just use my finger initially. Once down, I'll use the paper stump on its side to work the Flite Metal right down. Then, starting with the top most piece of tape, I'll hold the Exacto knife at the intersection of the overlap and the tape, then pull the tape back over itself. Once the knife starts the cut in the Flite Metal, the tape will pull a straight line, so you don't have to cut the whole length of the flite metal. Works great, you get better at it as you go along.
