    Yikes
    • NoDirt!
      • 183
      Been fiddling with the Norden bombsight. I changed the finish and added a couple details. Now I just have to figure out how to mount it.
      Haven't messed with the plane much but hopefully soon.
      • CFIT rob
        • Jul 2016
        • 220
        • Indy
        Well damn....I didnt want to believe that the dynam retracts have a low temp issue but..i finished replacing my failed port main with another new dynam retract(stbd failed on second flight,motion sent replacement,love you motion!) Flew two flights yesterday temp 47F. 1st flight (from car to tarmac) no problem. 8min flight. Second flight new port main failed to drop. Cycled again and waited,gear dropped after 5-8 second delay. On the ground..same thing stbd main,nose gear working fine,port gear only after delay. At home at room temp...no issue. (My ex wife didnt work when she was cold so i replaced her. )Anyone know of a drop in replacement?
          Have you tried loosening the screws a little, sounds like it's binding.
            • 8814
            Having replaced all my retracts on the B-26 with non-Dynam ones, I have not yet had any issues with them and I fly at or below freezing most days now.
              Yes! Me too freewing for the win!
              • CFIT rob
                • Jul 2016
                • 220
                • Indy
                Got word from MRC customer service...cold weather is an issue dynam is working on. They gave me a possible eflite drop in. The EFLg1590m from their 1225mm birds. A reviewer on mrc site for those retracts said they dropped in his tempest. The B26 mains are same part as the tempest. No idea for nose gear yet. Will try loosening the screws first. Thanks for the suggestion.
                • Gerry N
                  • 3
                  I just read the little known story about the B-26 in the battle of Midway - almost landing on the Jap flagship carrier. You gotta love the B-26.
                  U S ARMY at Midway.html
                    Heck yeah, scared as hell but go in anyway. It's something that can't be taught, it's something within that tells you victory is worth the risk. For our brothers, our country, our family.
                      • 7383
                      One of my all time favorite books is 'The Ragged Rugged Warriors" By Martin Caiden.(Still have my original 1963 copy!)
                      In the last chapter he describes the B-26's going in at Midway with a torpedo slung from the belly. These guys were shot to Hell and still kept fighting. Tyr to read it without getting a lump in your throat from the bravery and courage displayed by these men. Unbelievable!
                        Indeed
                        • NoDirt!
                          • 183
                          I've been fiddling with the plane a little here and there and this may have been metioned but another thing you may want to check- motor mount screws.
                          Mine were not loose but not all that snug either. They're machine screws into blind nuts, which I like, so I pulled them out and added just a touch of blue Loctite.
                          There was no slack on the wires so I was afraid to pull on the motors to get to the screws on the back. I'll hope for the best regarding them.
                          Just another little thing to check.
                          • NoDirt!
                            • 183
                            And another thing, tail weights, I didn't think mine had them but of it does.
                            I'm going to leave them in because I did a preliminary CG check and it's balancing nose heavy at about 60 mm (upright & wheels up by the precision fingers) with a 3850 & 4100.
                            • themudduck
                              -TMD- Foaming at the Mouth!
                              • 1041
                              • Burton OH (near Cleveland)
                              Here's the thing, lighter planes just generally fly better. About the only thing a heavy model is good for is flying in wind (and fast). The lighter the plane is, the easier the load is on the motors, hence longer flight times are achieved. Lighter wing loading is easier on the plane as well.
                              I use the 3600 battery (without the tail weights) and can fly for ten minutes. So anyway that's just my point of view.
                              • CFIT rob
                                • Jul 2016
                                • 220
                                • Indy
                                Lighter is better ( the ex-wife didnt get the concept...) but i had to leave one weight in to allow a cg range 60-65mm with my (heavy?) Chinahobbyline 4000 40c. The battery is about 3/4in from the back of the compartment. With two weights in my Roaring top 3700s were so far fwd the cockpit wouldnt fit. My timer at 9 min with plenty of reserve. Still alittle bummed about the retracts acting up in the cold.
                                • NoDirt!
                                  • 183
                                  Yea, I understand lighter, but these are the batteries I have in stock at the moment. My next size down are too small at 2200
                                  • fhhuber
                                    • Aug 2015
                                    • 1476
                                    Most aircraft will carry a LOT more battery weight than the recommended size pack.
                                    Aerobatic performance can suffer rapidly with added weight, especially since you are reducing your power:weight ratio and increasing your minimum airspeed to maintain level flight and thus minimum speed needed for any maneuver.. (its not really "stall speed" because you can cause a stall at any speed) Turn/loop radius need to be larger to prevent stalling.
                                    I commonly stick in 3S 3000 - 4000 mah and 4S 3000-3300 mah packs in planes that call for 3S 2000 mah. While average flight time is greater than the recommended pack size its not proportional to the mah.
                                    They carry the weight fine. It greatly improves ability to handle the prevailing gusty wind conditions around here. When the wind calms down, I put in the 3S 2000 packs.
                                      All good points for each application
                                      • Mad Baron
                                        132 Aviation
                                        • 547
                                        • McMinnville Tn.
                                        I am looking at replacing the red and green led with white for landing lights. It is difficult to remove the panel on the wing to access the wiring?
                                          Probably not too bad unless you had to reglue yours, mine fell out on takeoff one time causing a crash. They seem to come loose easy anyway..
