  • Originally posted by Quoll View Post
    Hey everyone,
    Just doing a makeover on my recently arrived OV10. An impressive model but I found the screws into the wing centre section into the booms appear too short. As a result the centre section raises up. Before I remove those screws and attempt to use longer screws, has anyone had a similar issue. If so can you please advise your experience and how the fix went.
    I also had minor trouble with the rudder not working correctly and traced that to a defective lead.
    I don't think it's that the screws are too short. I think you're missing the hole. IE, the alignment is off. However, I could be wrong. Next time you push the wing section into the boom section, have the plane upside down so you can see the slot of the wing section as it slides onto the peg of the boom. Does it go in far enough to align the path the screw must go to get threaded and seated? If the alignment is off just a little, the screw will be pushing up against the peg, thereby shoving the boom section up as the wing section is forced down.
    PS. If you don't have ALL the wires shoved into the space in the boom section, a single wire hanging in the space between the wing section and boom section will prevent the wing section from mating flush with the boom. That gap is enough to misalign the hole.
    • Has anyone had any problems with the blue box? I had my OV10 go out of control for no reason at all I was able to get control of the plane but it landed pretty hard and broke the nose gear. When I replaced the gear the connector in the blue box was loose.
      • Originally posted by Mad Baron View Post
        I have never trusted these "blue boxes" since the early days of them coming into service. I've had a couple of crashes due to them. My OV10, along with almost all of my planes that have these boxes, have had the critical control surfaces by-passing the box - AIL, ELE. I don't bother with the other servos. If any of them fail, I can still "bank and yank" the thing back.
        • I think I will bypass the blue box Aileron and Elevator as well. I don't want a repeat of what happened last time I flew it.
          • I agree, while I don’t not trust them I either remove them or just leave retracts and lights through them… I do it more to get more programming with higher channel count receivers.
              Another thing to consider is momentary loss of signal. Do you have a RX with telemetry? It will tell you the number of frame losses and holds during the flight.
              • I do have a telemetry ready RX but l don't know how to set it up. I have a Spektrum NX8.
                • There's nothing to set up on the RX. It's already sending stuff to the TX. You have to tell the TX to show it. You need to see what's in the "flight log".
                  • Got it. Thanks for the info now I can see the telemetry!
                      Have a question Sir. Can you bypass the blu-box for AIL, ELE and still benefit from the multi connector in the outer wing (taking the wing off for easy transport/storage) ?
                      I have not bought the OV-10 Bronco yet, but am seriously considering it.
                      Thanks in advance
                      • The aileron goes through the multiconnector so that would defeat the purpose. Along with the ailerons the outer flaps and lights go through it. You can bypass everything else, rudders, retracts, motors, etc.
                          ^ This. If you are real good with hunting down the correct wires from that multiconnector for the AIL, you can remove them and solder your own 3-pin connectors and "Y" them directly to the RX. It's risky business as these multiconnectors use common grounds for multiple servos. A lot of really bad things can happen if you make a slight "boo-boo".
                          • Thanks a lot, all clear :-)
                            • Has anyone converted this to run off one 6s lipo like the fms Tigercat yet? Thanks.
