  • DavidN
    • May 2021
    • 3180
    • Los Angeles, CA
    You are such a wise gentleman......Bob!
    • SoCalBobS
      • 2699
      • Southern California
      Apropos of crew poses....I've had these two guys, wasn't sure where they belonged, tried it in my KT. THAT'S where!
      • DavidN
        • May 2021
        • 3180
        • Los Angeles, CA
        Those two panzer crews look so serious. Nice paint job!
        • DavidN
          • May 2021
          • 3180
          • Los Angeles, CA
          I bought this 1/15 Bandai Hummel on Craigslist for $50. Seller only lived 10 minutes from me. I repainted it and put a 6.0S HL inside. It is now a RC Bandai Hummel.
ID:	324408Click image for larger version
ID:	324409Click image for larger version
ID:	324410Click image for larger version
ID:	324411Click image for larger version
          • Vaseline
            • 290
            Im extremely jealous haha.
            • DavidN
              • May 2021
              • 3180
              • Los Angeles, CA
              Originally posted by BcuriousR
              Yes, the whole tank is repainted. However, the base green is a very good match to the HL color: Tamiya TS28. Though if you're painting a turret, you might as well paint everything else so all the weathering, streaking, filtering, dust, etc. match.
              I still tinker with it every now and again. The original build was to see what could be done on a somewhat limited budget as well as test out the servo outputs on the HL 6.1.
              2 challenges come to mind on this build.
              1. Turret ring. I think the M36 turret from Mato is not mounted as high as the HL Sherman turret. So, mounting in the factory configuration caused the ring and turret to clamp down on the upper hull, limiting movement and dragging. You could probably just add washers to the posts, but I wanted it to be as clean as possible.... and justify my 3D printer. So I created a ring that locks inside the HL ring and creates a small spacer.
              2. Servo throw: In order for the barrel to recoil and the gun to elevate, servos must be adjusted. With more advanced radios and boards (IBU2U, Clark, etc.), adjustments can be made digitally in the board or in the radio. The HL requires adjustment in the linkage itself. It is a bit fiddly, but works with time and patience.
              I'm still working on crew placement and IR base. I hid the receiver mount with a faux radio box. It simply pops on and off. I'm moving the wiring as we speak.
              I finally made to the point that I can show you my tank and hope to join your platoon :-) I still need to order the 6.1S main board to work on the barrel elevation:
              • DavidN
                • May 2021
                • 3180
                • Los Angeles, CA
                • RichJohnson
                  • 1274
                  Nice work on the custom bash David. I see you also painted my Barbie castle, :-P
                  • DavidN
                    • May 2021
                    • 3180
                    • Los Angeles, CA
                    Thank you! It's a Mato M36 turret on the HL lower chassis that I followed Bcurious's work. And if you did not see the whole castle in the other thread, here it is:
ID:	326748Click image for larger version
                    • Hellcat 7
                      • Aug 2020
                      • 115
                      • T/S
                      Finish my Tank. I made the camouflage bag out of plastic bags along with the Trap. Had a problem with the paint staying on the plastic, so I sprayed it first with plasti-dip and then painted the main color. Click image for larger version
ID:	327123Click image for larger version
                      • DavidN
                        • May 2021
                        • 3180
                        • Los Angeles, CA
                        My second Porsche KT....sitting next to my first Porsche before. And then after the new paint job:
ID:	327415Click image for larger version
                          • 4819
                          [SIZE=16px]My second Porsche KT....sitting next to my first Porsche before. And then after the new paint job:]
                          DN, Really nice work. Best, LB
                          • DavidN
                            • May 2021
                            • 3180
                            • Los Angeles, CA
                            Got this mid version Tiger I two weeks ago from Taigen. I opened the box and this was the color on the tank:
Name:	Screenshot 2021-09-10 at 23-43-23 TAG13050-1_1024x1024 2x webp (WEBP Image, 1208 × 1208 pixels) — Scaled (75%).png
                            • DavidN
                              • May 2021
                              • 3180
                              • Los Angeles, CA
                              Two weeks later.......
                              • DavidN
                                • May 2021
                                • 3180
                                • Los Angeles, CA
                                • DavidN
                                  • May 2021
                                  • 3180
                                  • Los Angeles, CA
                                  My 1/6 RC American M5
                                  • DavidN
                                    • May 2021
                                    • 3180
                                    • Los Angeles, CA
                                    And my RC 1/6 M5 that was captured by the German in the Western Front 1944 :-)
                                    • DavidN
                                      • May 2021
                                      • 3180
                                      • Los Angeles, CA
                                      The German used the captured US tank for intimidation as they approached the American tank and demanded the American to surrender :-).
                                      • Rob1970
                                        Grumpy Old Dutchman
                                        • Jun 2021
                                        • 278
                                        My humble stable of vehicles... SWMBO goaded me into taking a group picture. I suspect for blackmailing purposes... but I fell for it anyway.
                                        ...and no, this is not all of them. Not included in this picture are the Renault FT-17, Panzer I and M3 Stuart kits (and the first of the Heng Long 1/30 Sherman donor tanks), the ongoing Sherman-to-Grant conversion and the poor Sherman that is doomed to become a BARV...
                                        ...but yes, there's two Tigers and a poor Pantiger. And the Willys (Alas not quite the right scale) a cargo truck that one day will get a 3D printed GMC cab.
                                        If the post office does their job, this ridiculous amount of armour will be joined by a Jagdpanther on Tuesday. One thing is painfully obvious tho... the Allies are pretty brutally outnumbered. High time someone started producing more (RTR) US and UK tanks.
                                        Sherman M4A3 105mm Houwitser / Sherman Firefly IC *under construction* / Panzer IV *awaiting side-grade from TK7.0S to TK6.0S* / Stug III / King Tiger / KV-1 *awaiting upgrade to TK6.0S* / Tiger I / T34-85 / Leopard 2A6 *waiting upgrade to TK7.0*... No, I do not have a problem....
                                        • Rubicon99
                                          • 3311
                                          Heng Long M4 Sherman turned into a post war Russian themed “Firefly”. Still a work in progress. This tank will be used as a “loaner” tank for IR battle days at both the LA and San Diego tank club battle days.
ID:	329536Click image for larger version
