  • cmdrcody
    "Grumpy"
    • Dec 2022
    • 228
    • Largo, FL USA
    Finished the paint scheme on my Tiger 1.
ID:	369923Click image for larger version
ID:	369924Click image for larger version
ID:	369925Click image for larger version
ID:	369926Click image for larger version
ID:	369927Click image for larger version
ID:	369928Click image for larger version
ID:	369929Click image for larger version
    • cpt.chaos canada
      • May 2022
      • 105
      • Aulds cove, Nova Scotia, Canada
      Today was (winter)camoflage testing day on the VietRCC Battlegrounds in Ontario Canada.
ID:	369985​Click image for larger version
      ​Ambusher1 in position.
ID:	369987​Click image for larger version
      Ambusher2 ambushes Ambusher1 :)
      Only to be ambushed by Ambusher3 :))))))))))
      • cpt.chaos canada
        • May 2022
        • 105
        More from the T34's wintercamo maiden 'n mud drive.
ID:	369994​Click image for larger version
ID:	369995​Click image for larger version
        Natural weathering procedure / Icebreaker / and return to base
ID:	369997​Click image for larger version
ID:	369998​Click image for larger version
ID:	369999​Click image for larger version
        ​I had fun with a hint of sun.
        CCC
        • Panzermechaniker
          • Feb 2023
          • 144
          • Rubicon99
            • 3318
            T72 GX-2 at its first battle day with the LA tank club 02/11/23
ID:	370144Click image for larger version
ID:	370143Click image for larger version
ID:	370142Click image for larger version
            • oldwolf
              • Dec 2020
              • 266
              Rubicon99, your T72 GX-2 looks great! The main gun bore looks smaller than on most model tanks. Are you using a smaller diameter main gun bore to narrow the ir beam and force yourself to take more precise shots?
              • Rubicon99
                • 3318
                The barrel is a custom 3D printed resin barrel with metal sleeve inner bore liner. The bore is slightly smaller then the stock HL “bb’ bore, but large enough to fit an IR (or flash) bulb snuggly. It is the same bore size I fit to most of my tanks ( I remove the forward section of HL inner barrel or I add tubing inside to reduce the inner diameter) it tighten the beam slightly but not some much that I handicap myself with a much slower aiming speed. The bulb set back is slightly further back in the barrel at 10mm on this tank. Overall this tank was built with a much larger and different playing field in mind that see engagements at 50 -100+ ft routinely and high speed maneuvering (modern theme A.I.M. battles) like that of the San Diego club or lessor degree PHX club. The LA field is just to small but made for a good “live fire” trials day for it.
                • Vaseline
                  • 290
                  Rubicon that is an amazing tank I'm assuming you printed all the ERA and turret but a great piece of work always fun to see
                  Nice work
                  • Rubicon99
                    • 3318
                    Nice work
                    The ERA / EMA, barrel and up armored turret hatches are 3D printed. They were designed by JVM3Dconcepts to my specifications. The turret off as a stripped down Henglong ZTZ 99A turret and modified to fit onto the T72 hull. Other small parts are kit bashed (taken) from a Leopard 2, Bradley, T90, Leopard 1 and Abrams.
                    • Vaseline
                      • 290
                      Man it all went together fantastic
                      Again nice work
                      • DavidN
                        • May 2021
                        • 3204
                        • Los Angeles, CA
                        My collections of Panzer IIIs.....
ID:	371068Click image for larger version
                        • DavidN
                          • May 2021
                          • 3204
                          • Los Angeles, CA
                          • DavidN
                            • May 2021
                            • 3204
                            • Los Angeles, CA
ID:	371074Click image for larger version
                            • DavidN
                              • May 2021
                              • 3204
                              • Los Angeles, CA
ID:	371077Click image for larger version
                              • CountChocula
                                • Feb 2023
                                • 4
                                Here’s a couple of my kit bashed vehicles. Not to scale or much detail but fun to make work.
                                • CountChocula
                                  • Feb 2023
                                  • 4
                                  • w68colley
                                    • Feb 2023
                                    My 1st tank, can't wait to get outside.
                                    • 761st
                                      • May 2022
                                      • 392
                                      Welcome to it!
                                      • DavidN
                                        • May 2021
                                        • 3204
                                        • Los Angeles, CA
                                        It is best for the tank in running it outside if you can reverse the tracks the other way
                                        • cpt.chaos canada
                                          • May 2022
                                          • 105
                                          Looks good to me.
                                          What scale are they?
                                          I guess 1/35?
                                          CCC
