Today was (winter)camoflage testing day on the VietRCC Battlegrounds in Ontario Canada.
Ambusher1 in position.
Ambusher2 ambushes Ambusher1 :)
Only to be ambushed by Ambusher3 :))))))))))
CCC
More from the T34's wintercamo maiden 'n mud drive.
Natural weathering procedure / Icebreaker / and return to base
I had fun with a hint of sun.
CCCComment
The barrel is a custom 3D printed resin barrel with metal sleeve inner bore liner. The bore is slightly smaller then the stock HL “bb’ bore, but large enough to fit an IR (or flash) bulb snuggly. It is the same bore size I fit to most of my tanks ( I remove the forward section of HL inner barrel or I add tubing inside to reduce the inner diameter) it tighten the beam slightly but not some much that I handicap myself with a much slower aiming speed. The bulb set back is slightly further back in the barrel at 10mm on this tank. Overall this tank was built with a much larger and different playing field in mind that see engagements at 50 -100+ ft routinely and high speed maneuvering (modern theme A.I.M. battles) like that of the San Diego club or lessor degree PHX club. The LA field is just to small but made for a good “live fire” trials day for it.Comment
The ERA / EMA, barrel and up armored turret hatches are 3D printed. They were designed by JVM3Dconcepts to my specifications. The turret off as a stripped down Henglong ZTZ 99A turret and modified to fit onto the T72 hull. Other small parts are kit bashed (taken) from a Leopard 2, Bradley, T90, Leopard 1 and Abrams.Comment
Here’s a couple of my kit bashed vehicles. Not to scale or much detail but fun to make work.
2 PhotosComment
2 PhotosComment
Gathering 1-2x monthly/All Ages & Experience levels welcomeComment
