Official RotorScale UH-1A Medic Green 450 Size Helicopter Discussion Thread
  • Gravythe clown
    • Mar 2019
    • 711
    • Clovis, California
    Thanks
    Gravy
    • Gravythe clown
      • Mar 2019
      • 711
      Originally posted by CM_Aero
      Here’s a pic of the ESC that came with my Huey. It says 4S. Also, the website said The microbeast was preinstalled and when it arrived, it wasn’t there. I also saw the price on the website decrease and the description change which made me annoyed. Then I got another email saying the microbeast had shipped with a credit on my account. So there are issues going on. Not even sure if I have the updated components inside per the item description. Got the email regarding the battery and created a ticket. Haven’t heard back.
      That's not what I got on my UH-1 i got the older Blue 6s one. What KV is your Motor? I sure hope it's more than 1800. I had to remove my motor bolts and the four screws holding the motor mount in place as-well the four screws holding the frame to the fuselage just to get the motor so I could see the KV.
      Gravy
      • CM_Aero
        • Nov 2018
        • 183
        • Central Texas
        Gravy
        Its the motor listed in the specs. 450L-1800kV Brushless Motor. I removed the 4 bolts from the bottom and slid a thin mirror under the frame to look.
        • Gravythe clown
          • Mar 2019
          • 711
          IMO You might want to contact motion about that. Not sure if that is going to work. That put the head speed at 2400rpms with only 10% headroom. When I flew mine at almost the same rpms 60% throttle in 6s I had LTE really bad.
          To go 4s it should have a much higher KV. I’ll be curious to hear your flight results.
          gravy
          • CM_Aero
            • Nov 2018
            • 183
            • Central Texas
            gravy
            I'll let you know. FBL unit just came in today. Need to take the fuselage off to go over things b/c like others have mentioned, rotation is tight.
              • 2818
              • Arlington, TX
              That’s the stuff I used for the mod. For 4S, you might at least be able to go to a higher tooth count pinion. That would buy a bit more headspeed. Haven’t had the chance to try mine on 4S yet, but it’s on the list at some point.
              • CM_Aero
                • Nov 2018
                • 183
                • Central Texas
                The manual for these helicopters said they were test flown at the factory. Is that true?
                  • 2818
                  • Arlington, TX
                  The first batches were, but I don't believe that is true for the latest version. They were originally supposed to include an open source quad control board, but that plan ended up being cancelled due to issues with said controller. The factory still does the basic setup (centering servos, adjust linkages, balancing blades, ect) but I don't believe they are test flown any more.
                  • Gravythe clown
                    • Mar 2019
                    • 711
                    got the 504 pack today. Looks like the only difference is it 48” instead of 30”. So I’ll start on that if all goes good this weekend.
                    thanks again for the heads up.
                    gravy
                    • Gravythe clown
                      • Mar 2019
                      • 711
                      God luck on your UH-1 guys.
                      Gravy out.
                        • 2818
                        • Arlington, TX
                        Had the chance to take up the Huey on a 4S 2200 this afternoon and it flew great! Bumped up my throttle curve a bit and had no LTE issues. Even tried down some pretty fast sideward flight in both directions without any blow outs. I think most of the LTE issues came from the high pushrod friction.
                        • RCFlyer51
                          • 41
                          • Lacey, WA
                          That is great to hear. Obviously the 4s 2200 fit ok, CG wise and added weight. How was the temp of the battery after the flight?
                          Danny
                            4S is all I've ever ran in mine.
                              • 2818
                              • Arlington, TX
                              Danny
                              Was no problem to fit within the GW/CG envelope of the aircraft. On 6S, I actually did have to add a decent amount of weight to the nose to get it to CG on the mast. Remained exactly on the mast with 4S.
                              Awesome! I think that’s going to be my preferred route for these 450s as well going forward.
                              • BWR
                                • Sep 2019
                                • 6
                                • Gravythe clown
                                  • Mar 2019
                                  • 711
                                  Guys you haven’t, do the tail mod F106DeltaDart did. It made all the difference in the world. My tail gain is right where all my 450 microbeasts are at now. Between 27 and 30 and rock solid. Also now that my tail is under control I can see it working on 4s as I tried it at 50% throttle on 6s and I hand good tail control.
                                  im going to get a talon 60 before I put it all back in
                                  I also made some shims so when I put her back into the fuse it will sit level instead of leaning to the left.
                                  she’s going to be a sweet flier.
                                  Gravy
                                  • Gravythe clown
                                    • Mar 2019
                                    • 711
                                    Ordered a talon 60 for mine. So when it comes in mine will get put back together. Can’t wait to give her a full shakedown.
                                    gravy
                                    • CM_Aero
                                      • Nov 2018
                                      • 183
                                      • Central Texas
                                      Removed the mechanics from the fuse today and adjusted the belt tension. Now it rotates a lot better. Installed the Microbeast and took it for a test flight. Major tail wag. Going to mod the linkage per the suggestion and see what happens. Talon 60 on order as well. Note: CHECK ALL SCREWS! A ton were loose and without thread lock. Thats why I asked a few days ago if these are flown at the factory as stated by MRC.
                                      Anyone know the correct programming rates for the servos? Can't seem to find that info. Thanks
                                      • Gravythe clown
                                        • Mar 2019
                                        • 711
                                        The tail mod works wonders.
                                        here’s what I have on the emax servos.
                                        gravy
                                        • Gravythe clown
                                          • Mar 2019
                                          • 711
                                          Well tomorrow I’ll giver her a good shake down.
                                          got my Talon60 today and installed it. My rpms are 1500 for ideal up and 2300 for flight. Did a test hover outside of fuse and all was good. Put her back in and buttoned it up. Did a test hover then in the fuse. Sounds like some fuse vibration. I might add something to lock the frame in, in the dog house. We’ll see after I put her through a good flight.
                                          ill report back tomorrow.
                                          gravy
