Depends on the BEC that is integral with the ESC and the current draw of the servos. As the start and stopping of the servo takes more energy that a straight run it is very easy to over tax most BEC when asking for the servos to see a power command 333 times a second. This is common for digital servos most analog servos only see a frame rate of around 50 times a second. Whenever I use a gyro I like to add a larger one than supplied, if it is an ARF/BNF type model. Or at least add more cooling.
These are two families of ESC with large BECs I like, the Talon and Gecko
As I don't know what you have I can't say one way or the other. Again I wish MotionRC would spec their equipment. I know somebody in the supply chain knows this engineering data.
All the best,
Konrad
All the best,
Konrad
