Minwax Polycrylic
  • #81
    That's what I did with my F-16. Sanded off all the "flowers", filled cracks with watered down spackle, sanded smooth, then several coats of polycrylic.
    • #82
      When a clear canopy gets scratched up, a coat of Varathane will make it look almost like new. Only the larger scratches will still show a little. Wipe it down with alcohol first. Doc
      • #83
        I've also heard using a floor wax, like Future, will really clean up a canopy and make it shine.
        • #84
          Yep..I use Future on my plastic model aircraft canopies; fills fine scratches and leaves a high gloss shine. Dip them in a container of Future, place on a paper towel to absorb excess, let them dry overnight. Bam!
          • #85
            Look what Home Depot is carrying on the shelves now. I'll be trying this out on some scrap parts, but I don't expect any issues. So glad they are doing matte now.
            • #86
              Are you sure that's water based? It doesn't look like their water based spar varnish.
              Roy B.
              • #87
                Hey Pat, I see on the can that it says "indoor" the Spar Varathane is outdoor, water based and has a UV protectant as well.
                Here's a picture of it, I've also seen it on Amazon.
                • #88
                  Yes, it is the indoor version, and yes it is water based. Didn't even think to see if they had the Spar outdoor version. I will be going back to take a look. They just changed their entire display, and Minwax and Varathane both have much more variety. They said Minwax is doing a matte version too.
                  • #89
                    Yes, they do, I have that on the P51B, here's a before and after shot
                    • #90
                      As I have stated, I threw my Minwax clear coat away when I discovered Varathane. The quality of Varathane is SO much greater than Minwax. Of all the things I don't like about Minwax, the fact that it is crunchy is no. one. Varathane remains flexible. Varathane has exterior. They have flat, matte, simi gloss and gloss. I am SO sorry I ever mentioned Minwax! Doc
                      • #91
                        I hear you Doc. Did the P-51B before I knew about Varathane, now I use it exclusively as well.
                        • #92
                          Same here Doc! I use only Varathane now.
                          • #93
                            Gman... I use your technique of rubbing it on the plane to remove the mold release resistance. Works great! I now apply it, at least the first coat, with a folded up paper towel instead of a brush or foam brush. Doc
                            • #94
                              Pat, how did this one work out for you? I'm curious because that's what my Home Depot has as well and I'm looking for a good MATTE sealer for blending in the glossiness of some of Callie's adhesive decals with the rest of the airplane.
                              Have any of you ever tried airbrushing your various Varathanes?
                              • #95
                                Two words Alpha, "well ventilated" it atomizes like there's no tomorrow. That's why I went back to brushes, got more in the air than on the plane.
                                The product that Pat is showing is indoor paint, you want the Spar Varathane with the UV protectant in it. Especially if its a plane with a dark color such as the Bearcat
                                • #96
                                  Works like a hot damn doesn't it Doc?
                                  • #97
                                    Sure does. Varathane not only looks great, but also secures your decals, pinstriping and paint. Doc
                                    • #98
                                      So I went back to Home Depot yesterday, and they do not (yet I hope) carry the Spar outdoor version. :(
                                      Since I really need something matte, I went ahead and got a pint of the new Minwax matte polycrylic.
                                      • #99
                                        will be picking up some varathane spar version asap
                                        • Check it out, if you can't find it, Amazon.......
