  • f4u ausie
    • 1241
    • Melbourne
    Originally posted by Reptielenfreak
    I know i have a 90mm f22. so how does this phantom fly compares to the f22? Is it easy flyer, is it a heavy flyer, does it take off fast etc.
    Sorry should have read the question better.. i think i am only an intermediate pilot,, and dont find it hard to fly..if i flew an f22 i may say its easy.. but the f4 is heavy, needs to b flown fast,,or under power, in the turns,, .. it will fly slow in the straights, with flaps,, but would not want to turn that slow,, im sure u would have a foam pile of rubble,, it flys tracks very straight.. and looks awsome in the air.... i fly fast untill on final,, then hit full flaps, off the gas, let it settle, and adjust speed as req,, it did take a while to get flap elev mix right, still tweaking it after around 20 flights.. started as 6s,, now 8s.. i luv it,,, if u get one ,, do check all elev servo linkages, appears to b its only weakness.. have fun b safe
    • farmflyer01
      • Jan 2022
      Is CG in manual supposed to be measured with gear up or gear down? I I maidened my 8s version on Sunday and had 2 smc 6300's as far forward as canopy would allow and still showed to be tail heavy with gear up. I put 2 flights on in this position and they were decent but I was having a yaw oscillation almost like a gyro was turned up too high, but there was no gyro. Any tips?
        • 5415
        Book CG is at best a starting point and after flying move it to suite. That said when I set a point it’s always with the gear down so I can easily check it sitting on the bench.
        • f4u ausie
          • 1241
          • Melbourne
          Hello farm flyer,,, hope u r well.. if u watch the original motion vids,, pilot ryan cut front of cockpit away,, (he likes nose heavy) i found the need to do same,, and i think the reason is, the original fans had plastic fan surround... my original 1835 kv 6s setup, and the new 1350 kv 8s,, have aluminum fan surround,, heavier than original... hence the need to move batteries forward 4 factory cg... which is awsome starting point im now at 175mm cg,,, bit nose heavy.. others hugh r at 200 i use hrb 4s 6000,, couple pics Click image for larger version
ID:	409336 Click image for larger version
ID:	409337 Click image for larger version
            • 4869
            Hey Y'all,
            Check out Hugh Wiedman's Navy VF-84 F4B Phantom EDF in the latest issue of the AMA magazine.
            A beautiful repaint with all new 8S setups.
            Congrats, Wildman!
            She's a looker with a cooker.
            Best, LB
              • 2715
              Originally posted by Elbee
              Hey Y'all,
              Congrats, Wildman!
              Best, LB
              Why thank you Steve, I haven't even seen the issue yet. 8S is certainly the sweet spot for these F4's, and I just upgraded the Spektrum Ar637t in both 8S F4's to plus. Although I felt it couldn't possibly fly any better, it somehow managed to do just that.
              Definitely my favorite and easiest flying EDF.
              • Ks.jetflyer
                • 131
                I purchased mine when they first came out. I put in a different edf but kept everything else. Last year I tried using hv lipos, noticed no cell count but everything worked. About a minute into flight lost power, but managed to get partial power and safely landed. No more hv liops. Took it out last weekend, still no cell count. About 2min. into 3rd flight it started losing power. Turned a short final and landed. Checked batt, still had 3.78 per cell. I'm thinking my esc might be dying. Any thoughts or ideas would be appreciated. TIA
                • f4u ausie
                  • 1241
                  • Melbourne
                  Hey guys hope ya all well.. im wanting yo put either a centre or after burner int my f4 (seems a cheap fun upgrade) new learning to b had.... for me.. i no the difference, between them physically,, but not visually.. hopeing for some advice, which to purchase.. looks easy to install????? And will it reduce flight time? Thanks
                    • 2715
                    Your ESC is not identifying the number of cells in your pack indicated by the # of beeps This is critical as all ESC's by default have a "low voltage cutoff" based on # of cells so your lipo pack isn't drained to zero and ruin the pack. When that level is reached, the ESC reduces power or even pulses the power to let the pilot know their pack is dangerously low. So your ESC would rather crash your aircraft than drain your lipo!!! :face_with_symbols_o
                    I've switched to HiV packs exclusively. Of 30 ESC's, only a couple identified a 6S HiV pack charged to 4.35 v per cell as a 7 S pack, resulting in loss of power and reaching the erroneous low voltage point around 3.7 volts per cell. With my Castle ESC's you're able to program them to either ignore the low voltage cutoff completely or program them for HiV. No HH or FMS ESC's failed to get it right but a couple Freewing ESC's got it wrong, those being older ones. You can look up the programming Manuel for your specific ESC and either remove or reduce the low cut off voltage and use HiV packs.
                    On the other hand, if your ESC is not getting the correct # of beeps to match a fully charged normal lipo, the ESC is defective!! You may also notice on a properly performing ESC, if you plug a discharged 6S pack in that is at around 3.5 v per cell, it may only beep 5 times, as the ESC is assuming you are putting a fully charged pack in that is 21 volts and that's a 5S. The low voltage cutoff is then based on a 5S pack. So sometimes these "smart" ESC's ain't so smart when they're buried deep in the ground after causing a "lawn dart".
                      • 2715
                      Hey guys hope ya all well.. im wanting yo put either a centre or after burner int my f4 (seems a cheap fun upgrade) new learning to b had.... for me.. i no the difference, between them physically,, but not visually.. hopeing for some advice, which to purchase.. looks easy to install????? And will it reduce flight time? Thanks ​​​
                      OK mate, here's my 2 cents. This is really just a personal choice and balancing time/effort/cost. While Kallend has designed some great AB's you can do yourself for less cost, I have been lazy and just buy them from the RC Geek. The burner for the F4 is called his 90mm multi-burner (specify what diameter 90mm motor you have, 6S or 8S), one cone fitting on the motor that splits into 2 like a Y. Each side has a cable to a controller that flickers each burner independently so it looks like 2 jet engines and you press a button at whatever throttle position to program when you want the flickering to start. Takes only moments to install but it's not cheap, about $95. You can send him (Chris Wolfe) an email and ask him about getting it to Aussie Land. I think HH and FMS are his affiliates so you might get them over there.
                      Hate to admit it, but I have his burners in 14 EDF's, and only my A-10 does not have his burners. But the "Scale Police" had to keep me locked up for over a month to keep me for putting them in. Wouldn't leave home without them. ​​​​​​​
                      Also helps to line the exhaust nozzles with aluminum AC tape for great reflectability (that's not even a word ).​​​ Very bright even in our South Florida glare. ​​​​​​
                      Easy to install, does not reduce flight time, but may slightly affect top speed, so if you're trying to break the sound barrier, you might leave them off. ​​
                        • 2715
                        What the burners look like and lining the nozzle with AC Aluminum tape:
ID:	410653 Click image for larger version
ID:	410655 Click image for larger version
                        • f4u ausie
                          • 1241
                          • Melbourne
                          Hugh thanx so much.. as per normal,, a responce from u comes with informatian,, fun and detail.. i watch chris(lots) was sad when pumpkin hit the dirt.... the info i was looking 4 has been found thanx again hav fun b safe.. florida reminds me of queensland ... the weather.. Watch lotsa boat rampstuff miami...,, (just good weather)
                          • Ks.jetflyer
                            • 131
                            Thanks for your imput. Confirms my thinking. Putting in a new hv esc. Don't want to loose a well experienced F-4.
                            • Fighterpilot
                              40 yrs. of flying
                              • Jun 2018
                              • 15
                              • Kenner, Louisiana
                              Has anyone hooked up a drag chute on their Freewing Phantom? Would be neat as hell to pop open upon landing.
                              FMS P-51B 1400 mm
                              Durafly T-28
                              1875 mm B-17 (lost in midair with FW-190 at Bomber Field)
                              Flyzone DE Havilland Beaver
                              Durafly 1200 mm F4U Corsair
                              • f4u ausie
                                • 1241
                                • Melbourne
                                Steve hodges.. aka rc jet dude.. did great rendition.. its on u tube
                                • Flyer771
                                  • Nov 2024
                                  • 4
                                  • UK
                                  I've just bought the Freewing F4 from MotionRC Europe. Does anyone still have the set of stl 3D files for the cockpit set, etc that MotionRC used to have on their website. I've asked them, but they say they no longer have or offer them. They pointed me to this forum. Please either PM me, or put the files up here. Thanks
                                    • 4869
                                    Buy F-4 Phantom II 3D Printed (3DPUP) Cockpit Set online at Motion RC. Order online with fast delivery.
                                    F7,
                                    Welcome to Hobby Squawk, Sir.
                                    Glad to have you onboard.
                                    I scanned through the Official Freewing F-4 Phantom Thread and I did not find the OEM STL files.
                                    However, Motion shows that they have cockpit sets still available at this time.
                                    I bought one in days of yore and it is really a nice addition.
                                    The set is resin printed and paints up nicely.
                                    Best, LB
ID:	413914 Click image for larger version
                                    • Flyer771
                                      • Nov 2024
                                      • 4
                                      • UK
                                      Thanks LB, your cockpit detail looks great and I'll have to consider getting one. However, it's a shame that nobody seems to have the original stl files they can share as I have a fine 3d printer which produce excellent results.
                                        Elbee commented
                                        Editing a comment
                                        I do not remember that those files were ever posted here. I downloaded most STL that were offered by MotionRC in those days, I would think I would have those in that case. In any event. at least there are a few sets left, but those are still $30.00USD.
                                    • f4u ausie
                                      • 1241
                                      • Melbourne
                                      Gday flyer 771. Don't b afraid. Post pics. As u go.
                                      We. Would luv to see some.. it's like an arrow
                                      • junkersju52
                                        • Nov 2024
                                        • 4
                                        Hey guys!
                                        Quick question.. Whats the best afterburner for the Phantom in your opinion?
                                        Thanks a lot!
