On another note, I’ve had the Ghost Grey F4 since it was released. I was never too impressed with the speed/performance . Never had any issues with the EDF unit so never pulled it out. When I did the swap last weekend, the stock EDF unit had the 1750kv motor but a 12 blade fan. Could that the be the reason for the lack of performance?
Thanks
I have 2 F-4's and both have the 9 Blade 3748-1750kv motor. Motions website does not have a 12-blade 1750kv EDF, only the 12 blade 3748-1650kv that came in my Stinger 90 (although the on line specs say it is a 3748-1450KV motor-must be what was in it originally when it came out) and a 9-blade 3748-1750kv that comes in the F-4 and in the F-18. Could the factory have stuck a 12 blade fan on a motor intended for 9 blades? Did you remove the motor from the fan housing and look at the markings and is it actually a 3748-1750kv motor, or did they stick the entirely wrong EDF unit (12-blade 3748-1650kv motor) in it at the factory.
All I can say is some-thins not right!! :triumph:
Best, LB
