  • Airguardian
    Post Stall Svengali
    • Aug 2020
    • 1664
    • Catalonia
    Back to the Su-35!
    • Airguardian
      Post Stall Svengali
      • Aug 2020
      • 1664
      • Catalonia
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1664
        • Catalonia
        • paulrkytek
          • Jun 2019
          • 526
          • North of England
          Sharp Nose Su video
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1664
            • Catalonia
            Congrats!
            Nice success! :D
            She's now officially become Sharp-35 !
            • paulrkytek
              • Jun 2019
              • 526
              • North of England
              SHARP SU35M
              Modified the canopy for a more conventional jet look:-
Name:	SHARP SU35-2.jpg
Name:	SHARP SU35M-1.jpg
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1664
                • Catalonia
                • Airguardian
                  Post Stall Svengali
                  • Aug 2020
                  • 1664
                  • Catalonia
                  I think I outdid myself with this one...
                  • Airguardian
                    Post Stall Svengali
                    • Aug 2020
                    • 1664
                    • Catalonia
                    • Airguardian
                      Post Stall Svengali
                      • Aug 2020
                      • 1664
                      • Catalonia
                      You guys are all too silent!
                      • SanExup
                        • 912
                        • Western Wy.
                        I bet the owners pool is shrinking since replacements aren't available.
                        • kallend
                          • 1863
                          Flew mine 2 days ago. Friend had his cell phone.
                          • SanExup
                            • 912
                            • Western Wy.
                            I did get to see one in the flesh the other day.
                            I kept thinking, I wonder if they would ever do a new Su35. Twin 80s.
                            • kallend
                              • 1863
                              If they do, I hope they don't make an overweight pig like some of the recent offerings.. . . .
                              • SanExup
                                • 912
                                • Western Wy.
                                They did kind of hit a sweet spot with the SU.
                                • Airguardian
                                  Post Stall Svengali
                                  • Aug 2020
                                  • 1664
                                  • Catalonia
                                  Agreed. I hope they make a bigger one but keep the weight in check!
                                  In the meantime, I come with new exciting Flanker goodies for y'all to enjoy, hehehehe...
                                  • fredmdbud
                                    • 450
                                    If they do come out with a new version of the 70mm Su-35, it will most likely be made of EPO, not EPP (correction: EPS). This will result in a heavier plane - that's what happened when they re-did the F/A-18E with thrust-vectoring (V2). On the other hand, they would upgrade the EDF's to in-runners.
                                    • fredmdbud
                                      • 450
                                      New livery in the works ...
                                      • kallend
                                        • 1863
                                        Originally posted by fredmdbud
                                        If they do come out with a new version of the 70mm Su-35, it will most likely be made of EPO, not EPP. This will result in a heavier plane - that's what happened when they re-did the F/A-18E with thrust-vectoring (V2). On the other hand, they would upgrade the EDF's to in-runners.
                                        The recent offerings also seem to have a lot more injection molded plastic parts ,which add weight. Example, the 70mm F-35 V3, which comes out heavier than the 80mm Mirage 2000 although both are EPO.
                                        • fredmdbud
                                          • 450
                                          Ready for it s debut at the field.
                                          2nd life of a wear-and-tear “FrankenFlanker” (mix of grey and desert fuselage parts) to a Test Pilots livery.​
